Author Topic: What would you call a Cherry MX Brown with Black springs?  (Read 6694 times)
Offline nacitar
« on: Wed, 24 September 2014, 13:33:11 »
Cherry MX clear with the lighter spring is an "ergo clear"... what's a cherry mx brown with the heavier spring?  just "stiffer browns" or is there a more widely accepted name I'm unaware of?
Re: What would you call a Cherry MX Brown with Black springs?
« Reply #1 on: Wed, 24 September 2014, 13:35:10 »
There's a thread somewhere with many different variations named but my searchfu is weaksauce today.
Offline esoomenona
  • Gnillort?
« Reply #2 on: Wed, 24 September 2014, 13:41:41 »
« Last Edit: Mon, 21 September 2015, 14:06:17 by esoomenona »
« Reply #3 on: Wed, 24 September 2014, 13:42:38 »
I like to call those: MX Brown stem with MX Black springs ;).
But if I recall correctly, that feels a lot like a stock clear to me.
« Last Edit: Wed, 24 September 2014, 13:47:25 by CPTBadAss »
Offline nacitar
« Reply #4 on: Wed, 24 September 2014, 13:45:19 »
Without the significant tactile bump of the clear, though, it shouldn't feel much like the stock clear.  At least to my fingers, the brown/clear stems feel massively different even with the same springs  (I use ergo clears).
Offline E TwentyNine
    • Some of My Keyboards
« Reply #5 on: Wed, 24 September 2014, 13:46:53 »
Here's a list from the wiki: http://wiki.geekhack.org/index.php?title=Cherry_MX
It lists that as a "tacto-black".
« Reply #6 on: Wed, 24 September 2014, 13:47:39 »
This guy reviewed a bunch of different options and had this to say  ;)
F) Black spring with Browns – I did not like these. They felt like a bad version of stock MX Blacks. It was almost a linear feeling but a little catch at the bottom.  Occasionally I’d feel a bump but the bump really felt like a bad version of a cushion.
I knew I had saw some sort of list somewhere! Thanks for linking that.
Offline FrostyToast
  • Litshoard
« Reply #7 on: Wed, 24 September 2014, 13:48:27 »
I was going to guess tactile black as well.
Quote from: elton5354
Offline nacitar
« Reply #8 on: Wed, 24 September 2014, 13:58:41 »
Never saw that list before, thanks!
Offline Signature
  • master of puppers
  • * Marketplace Moderator
  • snoozing
« Reply #9 on: Wed, 24 September 2014, 14:04:34 »
MX Brack
« Reply #10 on: Wed, 24 September 2014, 14:16:26 »
MX Brack
Would that make the opposite combination an MX Blown?
Offline Signature
  • master of puppers
  • snoozing
« Reply #11 on: Wed, 24 September 2014, 14:18:21 »
MX Brack
Nah it would be MX bred
Offline Analogy
« Reply #12 on: Wed, 24 September 2014, 19:38:22 »
"Pointless"
Just get clears, the tactile bump feels better anyway.
Offline FrostyToast
  • Litshoard
« Reply #13 on: Wed, 24 September 2014, 20:19:45 »
MX Brack
Would the black spring make it mx slightly burnt bread?
« Reply #14 on: Wed, 24 September 2014, 21:13:11 »
MX Brack
bred?
I can't get behind that, that's black and red, for Jordan sneakers
like this
« Reply #15 on: Wed, 24 September 2014, 22:41:29 »
I'd call them ****.
Browns already suck as it is, but with a Black spring, the bump would be practically unnoticeable and would just feel dirty.
Offline Signature
  • master of puppers
  • snoozing
« Reply #16 on: Thu, 25 September 2014, 00:46:14 »
MX Brack
bred?
like this
DO not even get me started on the clear and black one. Mx Clack...
« Last Edit: Thu, 25 September 2014, 03:22:42 by Signature »
Offline JaccoW
  • Fire Typer!!
  • Keyboard is Lava!
« Reply #17 on: Thu, 25 September 2014, 02:03:43 »
I'd call them ****.
True, but "dirty blacks" is not really the most politically correct name we can think of. :P
Scratchy dips
|||My other keyboards :
x
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #18 on: Thu, 25 September 2014, 13:01:31 »
I would call that terrible.
Offline JinDesu
« Reply #19 on: Thu, 25 September 2014, 13:14:34 »
I'd call it a Cherry MX Brack.
Someday somebody will best me, but it won't be today, and it won't be you.
Proud owner of a Filco Majestouch Cherry MX Blue Tenkeyless, KBT Race S, & Realforce 101
Offline pr0ximity
« Reply #20 on: Thu, 25 September 2014, 14:43:21 »
A Black & Tan
Offline Lurch
« Reply #21 on: Thu, 25 September 2014, 14:55:27 »
Quote from: Flyersfan1
Offline FrostyToast
  • Litshoard
« Reply #22 on: Thu, 25 September 2014, 15:15:24 »
No that's what Sifo calls an MX Black
Offline JinDesu
« Reply #23 on: Thu, 25 September 2014, 15:18:01 »
So lacist!
Offline Signature
  • master of puppers
  • snoozing
« Reply #24 on: Fri, 26 September 2014, 03:43:35 »
Come up with your own jokes :(
Offline Roibhilin
  • Saver of Humens
« Reply #25 on: Fri, 26 September 2014, 09:23:12 »
coffee switches?
QFR | Poker II | Quickfire TK
Offline Defect
« Reply #26 on: Fri, 26 September 2014, 10:53:24 »
Black Spring = Panda.
In my own little world.
Otherwise just 80cherry browns.
« Reply #27 on: Fri, 26 September 2014, 11:57:04 »
coffee switches?
I like **** brown, but maybe Starbucks switches works.  After all, even if you add some sticky, sweet switch stickers or add creamy lube, it will still feel like ****.
Offline Roibhilin
  • Saver of Humens
« Reply #28 on: Fri, 26 September 2014, 12:08:35 »
coffee switches?
