Author Topic: [IC] One piece Al TKL case Not low profile and no exposed plate.  (Read 9965 times)
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« on: Sat, 27 September 2014, 17:41:40 »
I am contemplating building a TKL case that would resemble the traditional TKL cases that are composed of bottom half, plate, and top half as 3 discrete pieces.  What I am thinking of doing is a milled case like this but all one piece.  Possibly a second piece as a plate just to add weight to the bottom.  The plate would be integrated into the case and switch holes would have to be milled instead of laser or waterjet.  So due to large amounts of machine time I understand this will be expensive as it will require at least to setups.   One for the plate and above and one for milling out the bottom cavity below the plate.
This would in theory be compatible with any TKL plate with the same spacing as the PCB won't mount to the case but just be there soldered to the switches clipped into the plate.
Would anyone be interested in me persuing this.  It will be VERY expensive to mill.  Fair warning up front.
Offline feizor
Re: [IC] One piece Al TKL case Not low profile and no exposed plate.
« Reply #1 on: Sat, 27 September 2014, 17:51:50 »
How much are we talking about here, roughly?
Offline Melvang
« Reply #2 on: Sat, 27 September 2014, 17:58:21 »
No idea but it will probably be more than Photekq's Tek-80.  If I had to guess I would say ball park in the $500 range.
« Reply #3 on: Sat, 27 September 2014, 18:06:31 »
TEK-80 was £500 :p
Offline feizor
« Reply #4 on: Sat, 27 September 2014, 18:06:49 »
I guess you did warn us. Still keen to see how it turns out.
« Reply #5 on: Sat, 27 September 2014, 19:34:57 »
I am very interested in this. The idea seems just ludicrous enough to be totally worth it.  :D
Better start saving!
Offline tbc
« Reply #6 on: Sat, 27 September 2014, 19:45:40 »
why am i the only one that doesn't understand.....
if everything is one piece...how do you get the pcb inside the case?
« Reply #7 on: Sat, 27 September 2014, 19:47:35 »
yeah
that might be an issue
Offline The_Beast
  • I like wood ಠ_๏
« Reply #8 on: Sat, 27 September 2014, 19:49:58 »
yeah
I'm guessing a bottom plate will allow access to the PCB.
I don't see this being easy to solder in if I'm understanding what Melvang is proposing
Offline Melvang
« Reply #9 on: Sat, 27 September 2014, 19:52:06 »
The bottom would be hollowed out.  Hence the probable two setup fees for milling it.  One for the top cavities for key wells and one on the bottom for the intended PCB cavity.
Bit like I said any tkl PCB with the same layout as the "plate" will work.  The one issue I could see would be trying to allow different layouts like 1.25 vs 1.5 mods or ANSI vs ISO.
yeah
You are correct.  But the plate would allow easy switch opening as that might actually make machining cheaper.
Offline Elocutive
« Reply #10 on: Sat, 27 September 2014, 20:17:11 »
I would be interested depending on price. Starting up soccer reffing (highschooler, finding jobs to keep up with the addiction is rough!) so hopefully I will be ready. I would also want to see some design pictures before jumping in, but I like the premise!
LZCE- Black, red, ergo clears
Wanting Skeldon
Offline Melvang
« Reply #11 on: Sat, 27 September 2014, 20:19:21 »
Not trying to scare you away from this but I can almost garuantee it will be over $500 for just a case with no anodizing.  It will be a lot of machine time.
« Reply #12 on: Sat, 27 September 2014, 20:24:26 »
In case anyone is confused, my understanding is that this would be essentially an LZ board with the plate machined into the upper portion of the case. Unlike a kmac or similar where the case split is right on the side, the case would open on the back with a plate back there. I think this was cleared up above, but oh well.  :)
Offline 0100010
  • Not Sure
« Reply #13 on: Sat, 27 September 2014, 20:29:45 »
Something like this?  http://pyrolistical.github.io/ - just in TKL?
Offline Melvang
« Reply #14 on: Sat, 27 September 2014, 20:32:17 »
For the most part yes.  Though in my original thoughts there wasn't going to be a plate on the bottom.  Just the big hollow cavity.  Though it wouldn't be hard to incorporate.
Photekq
Offline Elocutive
« Reply #15 on: Sat, 27 September 2014, 20:32:17 »
I understand. I think of it as an investment; if I ever lose interest, or need a lot of cash quick, then this is something I could sell for the same price I bought it at because of what you just stated; you pretty much CANNOT get this anywhere else, even if you wanted to custom machine in. It would simply be too expensive. Of course, this is all going off of your block of text. I would really need to see some mock ups before I make a decision.
Wanting Skeldon
« Reply #16 on: Sat, 27 September 2014, 20:34:22 »
Sadly the idea you can always sell for what you paid doesn't usually pan out in reality unless their is a large desire for the item.
Offline Melvang
« Reply #17 on: Sat, 27 September 2014, 20:37:49 »
Photekq - I hope you don't mind if I link to your TEK-80 thread.
For reference these pics show the various pieces of his custom one off machined case, there are some CAD drawings in the OP of that thread.  And these pics are some of the glory shots after assembly.  Think of this with the only two pieces being the case itself.  Top half, bottom half, and plate all machined from one solid block.  With a possible weight plate in the bottom.  The most difficult part of the machining process is going to be the stab holes in the plate.  Switch holes won't be to much of an issue if I go with easy mod variants.
Offline Elocutive
« Reply #18 on: Sat, 27 September 2014, 20:40:43 »
True. It is something I will have to think a lot about, but my two favorite keyboards are the LZ-GH and the TEK-80, neither of which are available anymore, and this seems to be a sort of hybrid between the two.
Wanting Skeldon
« Reply #19 on: Sat, 27 September 2014, 20:42:04 »
Ahhhhhh, got it! Yeah, that would also be awesome. I'd be all over it either way, to be honest.  :thumb:
Yep, this is true especially in this case. Key sets will frequently retain their value, and quite a few keyboards do too, but given how expensive this will be I do not see that being the case.
Offline Melvang
« Reply #20 on: Sat, 27 September 2014, 20:42:56 »
Hell I may not even every have it built.  But CAD files will still be made.
Offline Elocutive
« Reply #21 on: Sat, 27 September 2014, 21:06:25 »
Well, I'm hoping that I wouldn't have to sell it ever. That was a just in case type of thing, and a case like this is my dream board- this case in black, phantom PCB, red LEDs, 62g reds, and the BroSet. Yum.
Wanting Skeldon
« Reply #22 on: Sun, 28 September 2014, 00:10:11 »
So it's like the LZGH ?
Offline Melvang
« Reply #23 on: Sun, 28 September 2014, 00:20:41 »
From what I can see yes but I haven't see one fully dissassembled and this is going to be TKL and not 75%
Offline LechnerDE
« Reply #24 on: Sun, 28 September 2014, 00:28:47 »
Interesting project!!
I'll follow this thread, but won't be able to afford one, if it gets ever build  :thumb:
Offline telegraphist
« Reply #25 on: Sun, 28 September 2014, 02:49:40 »
Totally makes sense: It's hard to envision.
I wish I could see an artistic sketch.
Offline Melvang
« Reply #26 on: Sun, 28 September 2014, 02:57:20 »
Working on that.
Offline Melvang
« Reply #27 on: Sun, 05 October 2014, 02:48:05 »
Here is a quick animation showing the case concept.  This is a very quick and dirty version.  The switch holes are wrong from what I am wanting to do.  Essentially I need to tweak the switch holes to allow milling them while maintaining corners with a tight enough radius as I really don't want to spend that much time filing each and every corner in the plate.  I was also toying with the idea of having ridges both side to side and top to bottom to increase the stiffness of the "plate".
Offline Elocutive
« Reply #28 on: Thu, 16 October 2014, 19:16:33 »
Any updates? And would this have the brass piece in the bottom like a 360c?
Wanting Skeldon
« Reply #29 on: Thu, 16 October 2014, 22:44:27 »
I still don't understand the consent. I need to see how PCB fits into this case.
« Reply #30 on: Thu, 16 October 2014, 22:47:21 »
There is no bottom plate to the case, or at the very least it would be removable.  So this would be the same as a standard case, except that the plate is "fused" to the top portion.  Does that make sense?
Offline Melvang
« Reply #31 on: Thu, 16 October 2014, 23:02:55 »
Pretty much.  Look up Photekq's Tek-80 on here and imagine that the brass plate on the bottom is the only access to the PCB.  You just need to make that opening big enough to reach it.  Yes soldering will probably be a pain in the ass but really with easy open switch holes how often will you really need to solder and desolder the switches.
Offline henz
  • What?
« Reply #32 on: Fri, 17 October 2014, 02:51:30 »
im loving it. 500 is a bit much though, when will it run in case of enough interest?
« Reply #33 on: Fri, 17 October 2014, 13:29:37 »
Melvang: You might be interested in a H-shaped switch hole design that was discussed in this thread. It allows a switch to be opened from the top, while also allowing a larger edge radius (size of router bit) and keeping the number of cuts to a minimum. As long as the CNC routing has enough precision, it is as sturdy as other alternatives.
Offline Melvang
« Reply #34 on: Fri, 17 October 2014, 14:31:44 »
Yeah I was going to go with something like number 3 in the OP of that thread.
Really come seeing the size of the block of raw material, $500 is starting to seem on the low side once you factor in setup costs, machine time, tooling, and other unseen costs.
I was getting a rough idea for material cost and 6061 T651 at 6" thick x 6" wife was about $212 per foot.
