Author Topic: Why so much love for Poker II  (Read 2567 times)
Offline qihqi
« on: Mon, 29 September 2014, 16:29:38 »
(HHKB fanboys aside) When talking about 60%/TKL boards, Poker II seems like everyone's favorite. The most mentioned pro of Poker II is "standardized keysizes -> easy to customize". Is there anything else? For people who don't swap custom keys often, that along does not really weighs out the lack of dedicated arrow keys.
Offline esoomenona
  • Gnillort?
« Reply #1 on: Mon, 29 September 2014, 16:31:01 »
« Last Edit: Mon, 21 September 2015, 11:13:24 by esoomenona »
Re: Why so much love for Poker II
« Reply #2 on: Mon, 29 September 2014, 16:31:53 »
cheaper than the other options, reasonably good quality, layout makes sense, lots of aftermarket things exist for it, programmable, PBT keycaps...
should I go on?
Offline epzy
  • HHKB Fiend
  • ded
« Reply #3 on: Mon, 29 September 2014, 16:31:58 »
Layout, size & price mostly.
Offline esoomenona
  • Gnillort?
« Reply #4 on: Mon, 29 September 2014, 16:32:19 »
« Last Edit: Mon, 21 September 2015, 11:13:13 by esoomenona »
Offline ConscienceDrop
  • a-are these pbt?
« Reply #5 on: Mon, 29 September 2014, 16:33:58 »
its cheap, and available.
also aluminum cases and standard key layout.
I'm sure there are more in depth reasons why it was the model that caught on.
Offline Roibhilin
  • Saver of Humens
« Reply #6 on: Mon, 29 September 2014, 16:56:00 »
customizability and you dont need dedicated arrow keys
this is coming from someone who plays Dwarf Fortress a lot(arrow key+alphanumeric based controls) on a poker who also has a TKL
QFR | Poker II | Quickfire TK
Offline qihqi
« Reply #7 on: Mon, 29 September 2014, 16:57:20 »
F660M, Race, Pure... etc offers similar price range, programmability and quality. Seems like the only trade-offs is between standardized key sizes with arrow keys. Is that impression correct?
Offline pichu23
  • ୧༼ಠ益ಠ༽୨ FITE ME
  • ʕ ͡·ᴥ ͡· ʔ
« Reply #8 on: Mon, 29 September 2014, 16:58:53 »
yeah, pure is okay though. just a shorter right shift. some people prefer it that way.
Offline esoomenona
  • Gnillort?
« Reply #9 on: Mon, 29 September 2014, 17:00:50 »
« Last Edit: Mon, 21 September 2015, 11:12:46 by esoomenona »
Offline esoomenona
  • Gnillort?
« Reply #10 on: Mon, 29 September 2014, 17:01:58 »
« Last Edit: Mon, 21 September 2015, 11:12:33 by esoomenona »
Offline Tiramisuu
« Reply #11 on: Mon, 29 September 2014, 17:08:22 »
False Poker let's you program a full layer and make it the default.  colemak, dvorak etc.  Not quite fully programmable but close.
Keyboard error F1 to continue.
Poker 2, Gherkin, Lets Split, Planck, Filco
Offline Latin00032
« Reply #12 on: Mon, 29 September 2014, 17:53:05 »
The poker 2 is the peoples' 60 percent board.
Offline Sent
  • Simplistic Serenity
  • ¯\_(ツ)_/¯
« Reply #13 on: Mon, 29 September 2014, 17:58:03 »
It's generally pretty hard to go wrong with a Poker II.
Offline Tiramisuu
« Reply #14 on: Mon, 29 September 2014, 18:54:14 »
A symmetrical layout, bluetooth, fully programmable 60% that has alps or torpre is likely going to be nicer than a poker 2 but it is also going to be a custom job because it doesn't exist.
The poker seems like a good board to run until you can put together your end game board.   Unless the HHKB is your end game then you might just as easily go straight to it.   An HHKB plus a teensy and a bluetooth module could be very close to end game but at that point you can go fully custom and get precisely the board you like as you are spending a ton o' cash for a keyboard.
Offline Tiramisuu
« Reply #15 on: Mon, 29 September 2014, 18:55:22 »
... or you could go all out and try 40%.  Darn tempting truthfully.
Offline frosty
  • jukebox hero
« Reply #16 on: Tue, 30 September 2014, 00:35:13 »
The amount of cases compatible with it, the price, the stock pbt, programming options, dipswitch, easy to unassembled etc.
poker 2 for life
