Author Topic: fave keycap pullers  (Read 12859 times)
Offline a Horde of Penguins
fave keycap pullers
« on: Wed, 08 October 2014, 17:16:33 »
my first set of keycaps is currently on its way to me and i was wondering what are yalls favorite keycap pullers and why?
Offline Razor Lotus
Re: fave keycap pullers
« Reply #1 on: Wed, 08 October 2014, 17:45:03 »
I think some of the favourites here would be this kind:  http://tigerimports.net/sunshop/images/products/large_14467_MKPuller_1_large.jpg
Simple and easy to use. They come shipped with some keyboards out there already and you can get a generic one for quite cheap.
If you want a fancier version of that you can try this: http://geekhack.org/index.php?action=dlattach;topic=38029.0;attach=12962;image
I heard that ring pullers are generally disliked because they risk scratching the side of the keycap. I personally prefer those ring pullers but recently Ive switched to the wire ones
Offline esoomenona
  • Gnillort?
« Reply #2 on: Wed, 08 October 2014, 17:47:13 »
« Last Edit: Fri, 04 September 2015, 18:17:26 by esoomenona »
Offline ComradeSniper
  • HHKB Pro
« Reply #3 on: Wed, 08 October 2014, 18:02:00 »
The MKC puller is my favorite. Functionally it offers nothing over any other wire keycap puller, though.
Offline Michael
  • Formerly Bro Caps
« Reply #4 on: Wed, 08 October 2014, 18:10:52 »
For the price, the best keycap puller in existence. If you don't own it, get on my level.
http://elitekeyboards.com/products.php?sub=access,keytools&pid=leokp
Agreed.
« Reply #5 on: Wed, 08 October 2014, 18:16:08 »
is it large enough to pull off the space bar? seems like thats gotta be awkward, do people just take it off last with their hands.
Offline esoomenona
  • Gnillort?
« Reply #6 on: Wed, 08 October 2014, 18:18:03 »
« Last Edit: Fri, 04 September 2015, 18:09:57 by esoomenona »
« Reply #7 on: Wed, 08 October 2014, 18:19:24 »
That is my favorite, too.
I do the spacebar last, with my fingers, after I have removed the surrounding keys.
For zero cost, if you need it in 5 minutes, there is always this:
but the "store-bought" ones have thinner wires and that is much better
« Last Edit: Wed, 08 October 2014, 18:22:48 by fohat.digs »
- D Trump 2026-10-24
Offline Sent
  • Simplistic Serenity
  • ¯\_(ツ)_/¯
« Reply #8 on: Wed, 08 October 2014, 18:20:35 »
Yup, this thing.  A nice wooden one may be nice but eh.
Offline Zeal
    • Zeal Generation Inc.
« Reply #9 on: Wed, 08 October 2014, 18:22:23 »
Not a fan of the MKC Puller. It's got a short handle and overly head heavy IMO. Also mine ended up breaking at the brazed? end where the wire + turned SS connects after very light use (less than 5-10 keyset swaps). I also know another person's MKC Puller breaking at the brazed wire connection.
In general though, you can't go wrong with wire pullers.
« Reply #10 on: Wed, 08 October 2014, 18:29:06 »
I like the MKC metal one. It's got a good weight to it without being all fat and huge.
Offline Belfong
fave keycap pullers
« Reply #11 on: Wed, 08 October 2014, 19:13:25 »
I find myself holding the wire puller instead of the plastic holder when pulling. Which is why it doesn't matter what the top part is made of.
« Reply #12 on: Wed, 08 October 2014, 20:40:27 »
hamblet keypuller is the best keypuller
http://geekhack.org/index.php?topic=45795.msg967098#msg967098
just a note to say i've used this on most every mx keycap type on clear switches and even the tightest of caps came right off, it's like a keycap crowbar
« Last Edit: Wed, 08 October 2014, 20:58:13 by SpAmRaY »
Offline heedpantsnow
  • Old enough to know better
« Reply #13 on: Wed, 08 October 2014, 20:47:48 »
I have a Filco one that I got years and years ago in Hong Kong; it's similar to the Leopold one that's been linked.
Always freaks me out a bit when i can't find it....maybe I need a backup!
I'm back.
Offline Firebolt1914
  • POM Overlord
« Reply #14 on: Wed, 08 October 2014, 20:50:12 »
To be honest, my favorite keycap puller is one that works without damaging the keycap, which are many.
« Reply #15 on: Wed, 08 October 2014, 21:00:40 »
you guys think that the mechanical keyboards inc one is any good? looking to get it off amazon
« Reply #16 on: Wed, 08 October 2014, 21:33:38 »
It's only $3.99 from their own website and is shipped free...if you don't have a keypuller and want a cheap one I say go for it.
http://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=949
« Reply #17 on: Wed, 08 October 2014, 21:41:15 »
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #18 on: Wed, 08 October 2014, 21:43:04 »
Most wire keycap pullers are going to be about the same quality wise. I just use a techkeys one (I like the color :p).
Offline Richard Eul
« Reply #19 on: Wed, 08 October 2014, 21:44:56 »
I did the same with my Filco wire puller :D The only time I hold the handle is when I'm handling the spacebar, using two wire pullers.
I dislike ring pullers - it gives me the feeling that I'm grinding down the sides of the keycap when I insert them in!
« Reply #20 on: Wed, 08 October 2014, 22:16:29 »
I mean, we can all agree that plastic pullers are garbage, right?
Offline HendyZone
  • HHKB Elite
    • MechanicalKeyboards.co.id
« Reply #21 on: Wed, 08 October 2014, 22:17:30 »
Yeah +1 ;)
« Reply #22 on: Wed, 08 October 2014, 22:17:37 »
The ring type? Yes.
Offline intelli78
« Reply #23 on: Wed, 08 October 2014, 22:20:26 »
I've had one of these forever and it's still going strong.
The metal one I got from Massdrop crapped out after a couple weeks.
« Reply #24 on: Wed, 08 October 2014, 22:39:05 »
The ring pullers scare me almost as much as The Ring (movie) did.
I'm back.
« Reply #25 on: Wed, 08 October 2014, 23:55:47 »
I have a Leopold and a Poker one and I really like both but the Leopold one is probably my favorite.
Offline GL1TCH3D
« Reply #26 on: Thu, 09 October 2014, 07:18:54 »
I have a Poker one and it works pretty well.
I used to use ring pullers and those are AWFUL
Offline CommonCurt
  • One of the cool kids
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #27 on: Thu, 09 October 2014, 07:26:33 »
This is my favorite so far also. The skinny Poker2 one is second.
Some of Ye ole  Keyboards -->
WTB/WTS/WTT ---->
Offline epzy
  • HHKB Fiend
  • ded
« Reply #28 on: Thu, 09 October 2014, 07:34:36 »
happened with mine yesterday as well
Offline Zeal
« Reply #29 on: Thu, 09 October 2014, 07:38:26 »
That's 3
« Last Edit: Thu, 09 October 2014, 07:40:49 by Zeal »
Offline Belfong
« Reply #30 on: Thu, 09 October 2014, 10:18:50 »
I had one made by nubbs.. hand made!!! I am very proud of that classy puller. Just that I still hold the wire instead of the nice polished wood.
Offline nahka
  • Did you see that, Fio?
« Reply #31 on: Thu, 09 October 2014, 10:51:47 »
I really like the puller that comes with Poker 2 but I only use it for the larger keys. The plastic ring puller that used to come with Ducky boards seems the fastest to me so I use it for most keys.
  Poker II
    Reds
Offline RED-404
« Reply #32 on: Thu, 09 October 2014, 11:14:12 »
Top: Good and free.
Middle: Looks nice, but in reality is uncomfortable to use and has no grip.
Bottom: Better, good grip, free and holds multiple keys.
Offline 3Love
  • Bumpino Supremo
  • I want to become a great collector. Greedy!!!
    • https://geekhack.org/index.php?topic=63161.0
« Reply #33 on: Thu, 09 October 2014, 13:45:51 »
Wow, too many , haha
I♥Keyboard  I♥Clack  I♥Brobot  I♥Hammer
                          I♥♥♥friends
【WTB/WTTF】https://geekhack.org/index.php?topic=63161.0
KBD Collection: 356CL, 356.2, 356DGE, Koala, 356MINI, 356N, 356N-MK2, 356PAD, 360C, 456GT, FMJ, LZ-MXSE, LZ-RE, KMAC 1.0, KPAD, Duck Orion, Duck Pad, Exo, TEX and etc.
Offline 00zeRO
  • mechanicalkeyboards.com
  • * Commercial Vendor
  • The 00verseer of Vault 77
    • Mechanical Keyboards
« Reply #34 on: Thu, 09 October 2014, 15:04:21 »
My personal favorite is this one:
http://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=712
Of course, I love our MK keypullers for their compact size, but the 'shoehorn' case slider/opener is superawesomecool!
Daily Driver: Typist A w/Midnight Dawn | Kailh BOX Clicks
Junktown 2: Now on eBay!
« Reply #35 on: Thu, 09 October 2014, 15:05:28 »
There's another one I need to get, don't have the WASD one.
Offline 00zeRO
« Reply #36 on: Thu, 09 October 2014, 15:06:35 »
They have improved the design from their previous version...
Offline jonathanyu
« Reply #37 on: Thu, 09 October 2014, 18:02:27 »
now i am going to buy this...
Offline wes1099
  • Technology and Dog Enthusiast
« Reply #38 on: Thu, 09 October 2014, 21:49:17 »
I <3 this guy:
[Leopold FC660C]     [GON NeRD 60]    [Infinity Keyboard]    [ Model M Silver Label]
[Topre 45g Silent]     [Gateron Black]    [Cherry MX Black]     [Model Number 1390636]
        [May 20, 1987]
Offline yasuo
  • spanengan puyeng newbie
« Reply #39 on: Thu, 09 October 2014, 21:56:52 »
I have old wasd keypuller and ringpuller :))
how to about topre puller :rolleyes:
« Last Edit: Thu, 09 October 2014, 21:58:56 by yasuo »
Logitech MK220 Colemak DH
« Reply #40 on: Thu, 09 October 2014, 23:37:54 »
its out of stock :(
Offline ynrozturk
« Reply #41 on: Fri, 10 October 2014, 08:35:14 »
I've been using my Filco puller forever. Works well, no complaints.
I have the one that came with my Poker II at work in case I need to use it for something. I like that one too because it's shaped like a key, but it's just a bit too small.
IBM Model F | IMB Model M | Poker II MX Brown | Poker II MX Clear | Filco TKL MX Brown | Bastardized Razer Blackwidow TE MX Blue | Logitech G602 |  Cyborg R.A.T. 7 | | Logitech MX518 | Icemat  | Artisan Hien
Offline 00zeRO
« Reply #42 on: Fri, 10 October 2014, 08:42:15 »
its out of stock :(
We will be restocking very soon. The shipment may even come today. :)
  • Live long and prosper
« Reply #43 on: Fri, 10 October 2014, 08:44:58 »
tp thread is tp thread
Offline suby4me
« Reply #44 on: Fri, 10 October 2014, 19:13:39 »
i just use the ducky one that came with the shine. i was using those plastic O shaped ones till I heard it scrapes your caps good. Before the ducky one, I just used two paper clips.  :))
current: poker 2 | HHKB pro2, Novatouch | off: das keyboard 4 | Ducky 3 TKL | death by coffee das keyboard mac ver. | razer blackwidow | whitefox | corsair K70 RGB
Offline Sniping
« Reply #45 on: Fri, 10 October 2014, 19:30:14 »
My MKC puller broke last week too.
My favorite is still a butter knife. I pull off keycaps a lot faster with the butter knife. The trick is to press the key directly below to give the knife more leverage while you "pry" the keycap off, which also stops you from torquing the stem too much.
« Reply #46 on: Fri, 10 October 2014, 20:29:24 »
could i get pictures? wanna see how you get the first cap
« Reply #47 on: Fri, 10 October 2014, 22:24:12 »
Offline yasuo
« Reply #48 on: Fri, 10 October 2014, 23:48:20 »
actually, ringpuller faster too
Offline b7ad
  • ゆめうつつ
    • mechblog
« Reply #49 on: Sat, 11 October 2014, 14:51:42 »
I got one of those MKC ones as I always thought they looked really nice, but mine broke a few months after getting it, one of the wires snapped right out of the bottom of the handle.  :rolleyes:
