Author Topic: JD40 question  (Read 1532 times)
Offline Skuloth
JD40 question
« on: Sat, 11 October 2014, 13:40:08 »
I'm currently trying to figure out how possible it would be to add bluetooth functionality to a JD40. I've seen people working on adding bluetooth to other keyboards using a teensy 2.0, specifically modded HHKBs however they have significantly more space internally for extra parts. I have an idea about what I'll need hardware wise in order to get this to work, however I'm not entirely sure if I have enough space to work with.
Can someone with a JD40 in hand take a picture of the side view of the keyboard for me? I know that they have roughly .5 inches of space between the top and bottom plate but I'm curious how much space is between the pcb and bottom plate. In addition would anyone be able to comment on whether or not using longer spacers between the top and bottom plate seems like a good or bad idea?
Planck w/ Zealios
Re: JD40 question
« Reply #1 on: Sat, 11 October 2014, 13:50:35 »
If you need more space you can always just get longer standoffs to increase the distance. Only downside is you won't be able to use the gasket that comes with the titanium ones.
Offline Skuloth
Re: JD40 question
« Reply #2 on: Sat, 11 October 2014, 14:06:23 »
Not having the gasket isn't a huge concern. I'm worried longer standoffs may make it uncomfortable to use, but that is something I'll have to figure out when I get the keyboard in hand. Hopefully someone will able to able to get me a side view of the keyboard so I can get an idea about how much space the pcb will take up and how long I would need to make the standoffs.
Planck w/ Zealios
