Author Topic: Keycap Stabilizer Insert  (Read 2387 times)
Offline yomammary
« on: Thu, 16 October 2014, 08:40:06 »
I recently changed my original WASD keycaps for think PBT Leopold keycaps.
Problem is that the stabilizer inserts are bit loose on the keys and I mean all of them are pretty loose.
Do you guys know if there are inserts that would fit better my Leopold keycaps?
RF 87u 55g | Leeku 1800
Offline esoomenona
  • Gnillort?
« Reply #1 on: Thu, 16 October 2014, 08:44:51 »
« Last Edit: Fri, 04 September 2015, 11:15:17 by esoomenona »
Offline strict
  • TKL Zealot
Re: Keycap Stabilizer Insert
« Reply #2 on: Thu, 16 October 2014, 09:01:44 »
I've used little squares of scotch tape with great success before (adhesive side facing the insert  ;) )
Offline absyrd
  • CPT HYPE PADAWAN
« Reply #3 on: Thu, 16 October 2014, 09:06:27 »
I find cling wrap to be the best solution. You can shape it easily around the stem and adjust to fit and it won't move around or leave residue / be hard to get off.
Offline yomammary
« Reply #4 on: Thu, 16 October 2014, 12:33:10 »
Nice, I don't know why I didn't think of this!
Thanks for all the replies.
Offline yomammary
« Reply #5 on: Thu, 16 October 2014, 14:05:56 »
Scotch tape works surprisingly well ;D
« Reply #6 on: Sat, 18 October 2014, 03:24:19 »
Offline cinnamonrollz
  • buckle master 5000
« Reply #7 on: Sat, 18 October 2014, 21:53:46 »
I wonder if one could use playdoh for said problem.
« Reply #8 on: Sun, 19 October 2014, 05:00:35 »
It would get stuck inside the keycap.
A small ~1cm square bit of plastic, even from a plastic shopping bag or a ziplock bag, works fine, and is easily removed with no damage or residue to keycap or switch.
Offline yomammary
« Reply #9 on: Sun, 19 October 2014, 07:51:00 »
Thanks, I'll make sure to look into this topic next time I have a question.
