Author Topic: A tour through the Cherry MX Factory  (Read 7013 times)
Offline Moralless
« on: Tue, 28 October 2014, 03:58:34 »
Saw this posted on Reddit and was amazed at the QC that Cherry has for their switches and thought you guys would find this interesting aswell.
Offline Oobly
Re: A tour through the Cherry MX Factory
« Reply #1 on: Tue, 28 October 2014, 04:20:18 »
So I wonder how Kailh's facility compares?  ;)
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline Zeal
    • Zeal Generation Inc.
« Reply #2 on: Tue, 28 October 2014, 04:38:30 »
I was going to post this, but you beat me to it. Those temperature stress tests are definitely cool!
Offline jacobolus
« Reply #3 on: Tue, 28 October 2014, 04:41:38 »
Would be nice if Cherry could publish some of those force curves as measured from actual switches at different stages of their lifecycle.
Offline notsonerd
  • Here for the secrets
  • Light My Fire
« Reply #4 on: Tue, 28 October 2014, 04:43:02 »
Dammit. I literally just saw this and was going to make a post. I was really impressed by how thorough their testing process is, and man does laser-engraving look cool. That's a 20 year-old factory, too. Hot damn.
KBParadise V60 with Cherry MX Browns | Corsair K60 with Cherry MX Reds
Offline Moralless
« Reply #5 on: Tue, 28 October 2014, 04:44:08 »
Agreed, I find it interesting how they use the laser engraving to determine which keys are faulty, the laser engraving also made me curious how doubleshot keycaps are mass produced aswell.
Offline jacobolus
« Reply #6 on: Tue, 28 October 2014, 04:44:56 »
Anyway, thanks for posting! Really neat to see how the manufacturing works. I wonder if Matias could get someone into their manufacturing partners’ plants in China for a similar tour.
Offline jacobolus
« Reply #7 on: Tue, 28 October 2014, 04:46:54 »
That’s not what they said. They use various little robot arms &c. to determine which keys are faulty.
What they said was that the testing/assembly line is “smart”, so that it skips steps when they aren’t called for. For example, whenever anything goes wrong in testing, the keyboard skips the laser engraver so someone can manually check it out.
(Which makes sense. If you had a switch misaligned or something then you wouldn’t want to try to laser engrave the keycap.)
Offline Zeal
« Reply #8 on: Tue, 28 October 2014, 04:47:03 »
They didn't use laser engraving to determine which keys were faulty, it was the testing machine before it that would set it aside to be manually inspected instead.
Offline Moralless
« Reply #9 on: Tue, 28 October 2014, 04:50:16 »
I meant how they used the laser engraver to show which keys had failed, my bad.
Offline epzy
  • HHKB Fiend
  • ded
« Reply #10 on: Tue, 28 October 2014, 04:57:48 »
Interesting video, me likey.
Offline notsonerd
  • Light My Fire
« Reply #11 on: Tue, 28 October 2014, 04:58:23 »
According to the video, the keyboard doesn't even go through the laser engraving process until it passes every test.
Offline Oobly
« Reply #12 on: Tue, 28 October 2014, 05:13:10 »
On an interesting related note, I received a Cherry board with misaligned laser engraving. It's noticably higher on the caps on one side compared to the other. Most obvious on the F key row.
80999-0
So while their general testing and mechanical quality assurance is great, I can't say the same for their laser engraving. This board is in fact the worst of my mechanical collection (not enough support for the PCB so it flexes with each keypress and the whole board sags between the supports, thin PBT keycaps feel cheap, bridges in the switches instead of diodes so 2KRO, etc), but I bought it for switch harvesting anyway, so it doesn't matter, but I was expecting better from Cherry. A support plate would make a big difference to how it feels to type on, though, and would bring it up to "acceptable" level.
Offline Gunni
« Reply #13 on: Tue, 28 October 2014, 05:33:48 »
Wow, how interesting. I had idea of the effort/process they go through to test and validate their switches. It's quite amazing!
CM Storm Quickfire TK w/ Browns HHKB Pro 2
Offline notsonerd
  • Light My Fire
« Reply #14 on: Tue, 28 October 2014, 05:50:57 »
That's pretty noticeable, but I don't think it's a deal breaker. It does kinda suck that Cherry's quality doesn't reflect the testing done beforehand.
What I'd like to see is a similar tour done through more mainstream and enthusiast name-brands like Corsair or Ducky, if this is even a thing.
« Reply #15 on: Tue, 28 October 2014, 08:34:06 »
Can we please make this a stop on Keycon 2015? We go to the motherland; the epicenter of one of the community's favorite switches. Plus I want to climb into the sound chamber.
Offline Flamingchook
  • There are no dumb questions, only forbidden ones.
« Reply #16 on: Tue, 28 October 2014, 08:37:57 »
I'm pretty sure Linus is also doing a Steelseries factory tour video that's related to their keyboards so keep an eye out for that.
MX: Filco Majestouch Metalic Blue 104-key w/ MX Brown, JD40 w/ MX Green, ErgoDox w/ MX Blue, GHPad w/ MX Blue. Topre: Realforce 87U 45g. BS: IBM Model M 52G9700 29-OCT-93
Soon™: GH60 w/ 62g MX Clear, [CTRL]ALT 60 w/ MX Green
Offline pharaoh
« Reply #17 on: Tue, 28 October 2014, 13:00:32 »
I was very pleased this morning when I checked my youtube subscriptions and saw they finally posted their tour vid.  Maybe they'll do one at Topre Corp. :3
hhkb type-s| jd40 | jd45 | keycool87
Offline _PixelNinja
  • C=Q/V=ε(A/t)
« Reply #18 on: Tue, 28 October 2014, 14:34:14 »
As much as that would be cool, good luck on that ever happening.
Offline Lastpilot
  • Power stance
« Reply #19 on: Tue, 28 October 2014, 14:44:09 »
Ooooooh~ Very nice! Thank you for sharing. :thumb:
Offline calvinhousecat
« Reply #20 on: Tue, 28 October 2014, 14:49:38 »
The level of assurance that their keyboard goes through is somewhat soothing to me.  :-*
Offline MOZ
  • KING OF THE NEWBIES
  • Busy making stuff
« Reply #21 on: Tue, 28 October 2014, 14:50:44 »
That's a really cool factory!
« Reply #22 on: Tue, 28 October 2014, 16:12:58 »
First cherry mechanical KB ever with M8 switches ("U WOT M8")
Metal case, used in the newspaper industry, like my hall effect one https://www.flickr.com/photos/dork_vader/sets/72157638463953404/
I'm really not sure why they thought it was so nice. The HE one would have lasted longer, apparently had better stabilizers, and also has a huge amount of random keys and things on it.
« Last Edit: Tue, 28 October 2014, 17:01:56 by dorkvader »
Offline _PixelNinja
  • C=Q/V=ε(A/t)
« Reply #23 on: Tue, 28 October 2014, 16:41:07 »
[...] And also has a huge mount of random keys and things on it.
Don't hate on dem macro keys son.
« Reply #24 on: Tue, 28 October 2014, 17:01:42 »
[...] And also has a huge amount of random keys and things on it.
I love them!
I use an IBM 122-key.
Offline pbtforever
« Reply #25 on: Tue, 28 October 2014, 18:13:55 »
Needs more PBT.
Offline Lastpilot
  • Power stance
« Reply #26 on: Tue, 28 October 2014, 20:26:45 »
Now if someone could just go tour the GMK factory... :cool:
Offline mikekey
« Reply #27 on: Wed, 29 October 2014, 03:05:28 »
lol, lederhosen
« Reply #28 on: Wed, 29 October 2014, 07:04:28 »
Yeah, that was a great video. The quality control over at Cherry is flabbergasting.
Offline Vintage
« Reply #29 on: Wed, 29 October 2014, 14:36:55 »
Cherry is a pretty amazing company. I'm impressed.
Im sure they are happy to let people see how they are tested now that their patent has expired.
CM QFR w/ MX Reds  | Logitech G900
Offline _PixelNinja
  • C=Q/V=ε(A/t)
« Reply #30 on: Wed, 29 October 2014, 16:23:40 »
At one point in the video Linus and Luke mention that Cherry is testing a new product. That kinda got me curious...
