Author Topic: [GB] Octagon 75% Kustom Keyboard  (Read 350545 times)
Offline Data
Re: [GB] Octagon 75% Kustom Keyboard
« Reply #500 on: Sun, 22 February 2015, 00:45:49 »
It was Left Control.  All the others have the same LED orientation.
This build went better than I expected.  Everything just works.  Now I need to figure out the programming software.  :D
Thanks for putting this together Elton.  You da man.
Offline Sygaldry
  • Edema Ruh
« Reply #501 on: Sun, 22 February 2015, 02:14:17 »
Hey, so with so many of you receiving and building your Octagons, how are you all handling the right side keys?
null
Offline tbc
« Reply #502 on: Sun, 22 February 2015, 02:53:01 »
blanks... :)
Offline whentheclouds
« Reply #503 on: Sun, 22 February 2015, 06:33:43 »
i'll replace the tilde with "Home" and PRT Screen | Scroll Lock | Pause with / * - from the numpad, and the 4 subsequent keys will be
9
6
3
this ensures i get the correct profiles as well as complete symmetry, at the cost of butchering my numpad
Offline Data
« Reply #504 on: Sun, 22 February 2015, 13:49:23 »
Del
Home
Pg Up
Pg Dn
End
Right arrow
There's a slight profile mismatch but I really don't care. The only one that's obvious is Del.
Offline tjweir
« Reply #505 on: Sun, 22 February 2015, 13:57:28 »
Del
Home
Pg Up
Pg Dn
End
Right arrow
My home and work boards both look like this now:
https://geekhack.org/index.php?topic=65036.msg1584105#msg1584105
Offline Data
« Reply #506 on: Sun, 22 February 2015, 14:00:21 »
Del
Home
Pg Up
Pg Dn
End
Right arrow
Funky.   :thumb:
Offline whizzard
  • whizzard got ur gizzard
    • LOOTKEYS BLOG
« Reply #507 on: Mon, 23 February 2015, 23:38:53 »
I put together a build log / review / tutorial on this project on my site.  Here is the reference to the thread here on geekhack:
https://geekhack.org/index.php?topic=69177.0
Thanks to everyone who made this keyboard possible... I LOVE IT!
Offline radio_killah
  • Chinchillin'
« Reply #508 on: Tue, 24 February 2015, 00:01:32 »
Wait why not just link us straight to your sight from this post as well lol.
Offline Zeal
    • Zeal Generation Inc.
« Reply #509 on: Tue, 24 February 2015, 00:36:17 »
That yellow brush tip was supposed to be screwed into the syringe of lube :P I guess it can work as an independent brush as well..
Offline whizzard
    • LOOTKEYS BLOG
« Reply #510 on: Tue, 24 February 2015, 01:24:20 »
Yes, I screwed it into the syringe, that's why I found it so useful.   I guess I didn't make that clear though.
« Last Edit: Tue, 24 February 2015, 01:25:54 by whizzard »
Offline whizzard
    • LOOTKEYS BLOG
« Reply #511 on: Tue, 24 February 2015, 07:08:50 »
Another noobie question for you folks... I was trying to program my octagon with the firmware from the authors site (ducky0113 I think).  Anyhow, even though it is in Korean I can understand how it basically works, but when I try the option "Upload Firmware" I get the error that I don't have a DFU Programmer.  Am I doing this right?  I tried looking up DFU programmer and found no results on the board, and a few on google that seems to program firmware for chips but I have no idea if this is what I should use.   So it makes me think I am messing with something I shouldn't.  Since this is my first custom, I am trying to figure out how to program it to do what I need such as using a function key to switch the mapping out, or being able to launch a program from a keypress.
How do most of you go about programming your keyboards?  Thanks again everyone.
edit:  I noticed on the firmware site there was a key highlighted called a "Flip" key... what does this mean?
edit: after searching again, I think I found most of the information I needed, no idea why DFU programmer showed no results earlier.  I found a thread with a tutorial.
« Last Edit: Tue, 24 February 2015, 07:49:26 by whizzard »
Offline tjweir
« Reply #512 on: Tue, 24 February 2015, 07:53:21 »
Add the link to the tutorial, so others can solve the same issue.
Offline rainb1ood
  • so pretty so plastic
« Reply #513 on: Tue, 24 February 2015, 07:56:59 »
I'm going to need a tutorial for that as well
Offline tjweir
« Reply #514 on: Tue, 24 February 2015, 08:00:32 »
I had no issues programming my Viper, but I'm drawing a blank on what I actually did. :)
Offline whizzard
    • LOOTKEYS BLOG
« Reply #515 on: Tue, 24 February 2015, 10:56:32 »
Okay, I will post what I found... but it is a little outdated, though it worked for me.  May take a little while...
Offline whizzard
    • LOOTKEYS BLOG
« Reply #516 on: Tue, 24 February 2015, 11:31:06 »
Okay, I updated my build log / guide on my personal site to include the guides I used and I also link to the software you need.  If there are errors with anything please let me know, and I hope it helps everyone.  I did not write the guides, and they are a bit outdated but I was able to follow them to get going.
Click the Firmware section at the bottom of the menu for the guides and links.
CLICK HERE FOR THE BUILD LOG / GUIDE
If anyone has a more complete or updated guide to programming the 02_Keymapper software in English please let me know where to find it so I can add it to the guides... there is probably one out there somewhere, but I could not find very many.
« Last Edit: Sat, 28 February 2015, 23:10:12 by whizzard »
Offline rainb1ood
« Reply #517 on: Tue, 24 February 2015, 11:34:05 »
Thanks whizzard. You are a wizard.
Offline tjweir
« Reply #518 on: Tue, 24 February 2015, 11:51:35 »
If you have a .hex file, you can flash your Viper (I have not built my Octagon yet) with dfu-progammer:
> dfu-programmer atmega32u4 erase
> dfu-programmer atmega32u4 flash <HEXFILE>
I just updated my Viper now.
  • Chinchillin'
« Reply #519 on: Tue, 24 February 2015, 14:29:25 »
Dope guide. I will probably be using it later! Thanks a lot!  :thumb:
Offline whizzard
    • LOOTKEYS BLOG
« Reply #520 on: Tue, 24 February 2015, 15:04:18 »
You guys are very welcome... glad I could help!  :)
Offline whizzard
    • LOOTKEYS BLOG
« Reply #521 on: Wed, 25 February 2015, 21:37:40 »
Hey guys, quick question... I have a little trouble sorting through the group buy forums and telling what is available or not,  even with the sticky.  Anyhow...  anyone know if duck is making a new kit or has anything like that upcoming?  I had a lot of fun making the Octagon and probably want to grab another kit when it is available.
Offline whizzard
    • LOOTKEYS BLOG
« Reply #522 on: Wed, 25 February 2015, 23:23:41 »
After some spying and scouring I think I found the next probable duck kb... the Orion V2?  Am I right?  Looks very nice... keeping my eye out!
Offline tjweir
« Reply #523 on: Thu, 26 February 2015, 06:07:28 »
Offline whizzard
    • LOOTKEYS BLOG
« Reply #524 on: Thu, 26 February 2015, 13:24:41 »
It looks great... I have no doubt I will be in on that.  You hooked me with the Octagon and you have me wrapped around your finger now.  :))
Offline Data
« Reply #525 on: Sat, 28 February 2015, 15:33:06 »
So I have all the files I think I need.  I'm in the 02D Keymapper with my custom layout, but it won't let me save to a hex file.  When I click Save on the Save dialog screen I get a Run-time Error 76, then the application crashes to desktop.  I tried running it in XP compatibility mode (I'm on Win 8.1) with no luck.  Any ideas?
I had no problems installing the Atmel driver.  They keyboard works great, in fact I'm typing on it right now.  It's just those few keys that aren't quite where I want them yet...
Offline swornxin
    • Nailed Down Custom Pins
« Reply #526 on: Sat, 28 February 2015, 16:27:31 »
Yup, announced a few days ago.
http://kbdlab.co.kr/index.php?document_srl=1901745&mid=board_gb_outside
Damn.  I haven't even started the build on my first one, and I'm itching to get this one too.
Octagon - 62g Cherry tactile greys
Phantom - 65g Cherry tactile greys
FC660M - Cherry blues
KC60 - Gateron browns
Offline tjweir
« Reply #527 on: Sat, 28 February 2015, 16:52:20 »
Make an empty file, name it whatever.hex, and overwrite it with the hex file you create in the app.
Offline Data
« Reply #528 on: Sat, 28 February 2015, 18:28:50 »
I should have thought of that. Thanks, I'll try it when I get home.
Offline tjweir
« Reply #529 on: Sat, 28 February 2015, 19:02:14 »
Oh, and make it in the same directory as the O2D mapper exe.
That's how I've had to do it for my viper and butterfly numpad.
Offline whizzard
    • LOOTKEYS BLOG
« Reply #530 on: Sat, 28 February 2015, 19:07:57 »
The replies are all correct... like it said in the guide, put them in the same folder on your root drive if possible... I got the same error you are getting until I realized not to use the "default" name (02_Keymapper_map01.hex) or whatever it gives by default, and just put in "keys" or some small word and it worked.
Offline Data
« Reply #531 on: Sat, 28 February 2015, 19:46:08 »
Thanks.  While I'm working on that here are some photos.
I didn't have very favorable lighting today so I only took a few.  Album link
Offline Data
« Reply #532 on: Sat, 28 February 2015, 20:19:43 »
Yeah it worked great.  Thanks dudes.  :)
Any idea what "MFN" and "Ly Tg" do?  I assume the latter is some sort of Layer Toggle but I'm unsure how it works.
Offline whizzard
    • LOOTKEYS BLOG
« Reply #533 on: Sat, 28 February 2015, 20:51:55 »
Not too sure about MFN... but the other one is Layer Toggle I think.  I haven't really done a lot of mapping yet... the default is working well and I just set one layer for all the LED toggles.  Very nice looking keycap and layout you have there!
Offline Data
« Reply #534 on: Sat, 28 February 2015, 22:37:22 »
From what I can gather, LyTg just toggles between Layers 1 & 2, as indicated by the activity light.  Press & release once to go into Layer 2.  Press again to return to Layer 1.  Pretty simple.
I haven't found a use for MFN yet.
Offline zennasyndroxx
  • It's good to be back!
« Reply #535 on: Sun, 01 March 2015, 00:52:10 »
Just finished assembling this. aw yis
92427-0
92429-1
Offline katushkin
  • Too Keycool for School
  • Just the guy
« Reply #536 on: Sun, 01 March 2015, 05:09:04 »
Offline tjweir
« Reply #537 on: Sun, 01 March 2015, 05:54:50 »
Great looking board, classic black on beige and those white on CMY are very nice.
Offline whizzard
    • LOOTKEYS BLOG
« Reply #538 on: Sun, 01 March 2015, 15:30:59 »
Your board came out great!  I wish I could have used that layout but I needed too many keys for what I do  :rolleyes:
Offline quochung1989
  • Vintage Cherry Collector
  • Frenzy Classic.
« Reply #539 on: Sun, 01 March 2015, 23:31:31 »
« Reply #540 on: Sun, 01 March 2015, 23:41:11 »
Thank you :D the beige looks pretty yellow IRL. needs retr0brighting :(
Thanks :) I use caps lock as winkey since i'm not gonna use caps lock all the time
CMYK 'll better, friend ;)
I know :( i don't have cmyk. need to find one now
That's so pretty :'(
thank you :) I'm thinking what leds to install.
Offline Data
« Reply #541 on: Mon, 02 March 2015, 08:07:40 »
Are there any guides to controlling the numerous LED functions?  My function keys appear to do different things every day and never the thing I expect them to do.
I've seen the demo video but without knowing WTF he's pressing to get those actions it's no use to me.
Also still wondering what MFN does.  It was apparently important enough to include in the default keymap.
Offline cannonking
« Reply #542 on: Mon, 02 March 2015, 08:26:31 »
Thinking about whether to use switch LEDs or not, can you set them to turn off/dim with a hotkey?
Offline whizzard
    • LOOTKEYS BLOG
« Reply #543 on: Mon, 02 March 2015, 10:25:37 »
Wish I could help more... like I said all I found in English were the guides I posted on my review.
You can try what I did and using the drop down menu part copy layer 1 to Layer FN1, and then modify layer FN1's top F1-F12 keys to all the LED controls.
Then just play around with them until you figure it out.  I know that MFN has something to do with the "function key" layers.  I haven't tested that key or needed it yet to know.  Possibly means "Main" or "Multi" Function key, "Macro" I dunno... I haven't used it yet.
To use layer FN1, just map one of your keys to "FN1" and while holding it, that toggles the board to the other keymap.
You can put anything you want to test in that layer and mess with it.  That is how I figured out the LED functions on mine.
« Reply #544 on: Mon, 02 March 2015, 10:43:57 »
btw, a full documentation of o2d's firmware can be found in this link below:
http://blog.naver.com/PostList.nhn?blogId=dudgnl2&categoryNo=15&from=postList&parentCategoryNo=15
that's o2d's own blog, i presume.
he briefly mentioned aboout mfn.
Offline Data
« Reply #545 on: Mon, 02 March 2015, 11:42:11 »
Thanks, that is actually helpful... after I translate from Korean.  :D
MFN apparently allows you to select multiple FN layer controls (FN1 thru FN3) with a single key by pressing it the desired number of times.  So press once for FN1 layer keys, press twice for FN2, and so on.  Hence "Multi-Function".
Code: [Select]
MFN: FN1, FN2, multi-function function keys available for all functions of the FN3
     Pressing once during the same maintenance and function of the FN1
     Click once during the same functions of the FN2 keep pressing twice in less than a second
     Press twice during the same functions of the FN3 keep pressing 3 times
     Continuous input recognition time is less than one second after pressing the key off of MFN,
Ly Ch will cycle through the 4 user layers.  Ly Tg toggles between User Layer 1 and 2 -- it doesn't work like MFN (with the multi-taps).
I'm still deciphering the LED controls...
Offline whizzard
    • LOOTKEYS BLOG
« Reply #546 on: Mon, 02 March 2015, 11:49:09 »
Thank you very much!!!  I was looking for this, but was confused by the Korean.  I translated the page and added it to my guide under the firmware section.
Here is a quick link to the translated page: HERE
Offline xauser
« Reply #547 on: Mon, 02 March 2015, 11:58:59 »
I have tmk firmware running on my octagon but only limited control of the rgb leds for now.
Offline tjweir
« Reply #548 on: Mon, 02 March 2015, 12:01:32 »
Oh cool, post more info when you can please.
Offline xauser
« Reply #549 on: Mon, 02 March 2015, 12:05:01 »
What do you want to know? I will push the sources the next days after some more testing.
