Author Topic: [GB] Octagon 75% Kustom Keyboard  (Read 350538 times)
Offline tjweir
Re: [GB] Octagon 75% Kustom Keyboard
« Reply #550 on: Mon, 02 March 2015, 12:13:33 »
What do you want to know? I will push the sources the next days after some more testing.
The source should be good enough I'd say.
Awesome!
Offline zennasyndroxx
  • It's good to be back!
« Reply #551 on: Mon, 02 March 2015, 12:15:48 »
I NEED MUH WINDOWS MEDIA KEYSSSS
oh yeah, anyone know korean here? written korean
Offline xauser
« Reply #552 on: Mon, 02 March 2015, 16:45:14 »
If you want to try tmk firmware on your Octagon follow this link tmk firmware
Have fun!
Offline tjweir
« Reply #553 on: Mon, 02 March 2015, 17:14:26 »
Have fun!
Awww yeah!
Thanks.
Edit: going to have to dust of my C skills and try to add support for the Viper.
« Last Edit: Mon, 02 March 2015, 17:17:10 by tjweir »
Offline swornxin
    • Nailed Down Custom Pins
« Reply #554 on: Wed, 04 March 2015, 12:41:36 »
Got my stabs assembled, my switches are on the way.  Have a surgery scheduled for next Friday, so I'll probably get all the modding done while I'm in bed.   :))
All the photos being posted are really motivating me to get this done on my own.
Octagon - 62g Cherry tactile greys
Phantom - 65g Cherry tactile greys
FC660M - Cherry blues
KC60 - Gateron browns
Offline JaccoW
  • Fire Typer!!
  • Keyboard is Lava!
« Reply #555 on: Wed, 04 March 2015, 14:00:23 »
Have fun!
Awww yeah!
Thanks.
Or the Orion if you are at it  :rolleyes:
|||My other keyboards :
x
Offline tjweir
« Reply #556 on: Wed, 04 March 2015, 14:38:18 »
Have fun!
Awww yeah!
Thanks.
I started the Viper already, I don't have an Orion, but how hard can it be? (tm)
Offline whizzard
  • whizzard got ur gizzard
    • LOOTKEYS BLOG
« Reply #557 on: Sun, 08 March 2015, 11:38:10 »
I just installed the rest of the LED's into this board... before I just did the Alpha keys.  The amount of customization is really crazy.  I am still trying to figure it out.  From lighting up with keypresses, breathing, and all the different rows being different if you want.... its really cool.
One thing that I have learned for the future though, is that the color of the LED doesn't seem as important as the translucency of the key itself.  White keys shine bright in the chosen color, but painted keys barely let light through at all, and its hard to tell the color.  This is self-evident to most people, but didn't occur to me  :rolleyes:
Seems like the light is more an ambient tone underneath darker color keys, and shines right through white ones.  Just thought I would share that, in case someone hasn't messed with LED's before.  And also keep in mind, I have only tested it on the current keyset that I have.  I have a GB set coming and I am curious to see how it looks under those lit up.
One thing that duck knows is that people like having lots of options when it comes to lighting thier kbs!
Offline TLSC.wipeOut
  • "Who dares, wins"
« Reply #558 on: Tue, 10 March 2015, 18:56:15 »
Anyone know how to get the LEDs to work in a way where you press the button then it lights up and fades out slowly?
OTD 456GT with Lubricated 68g Gold Spring MX Clears and GMK Dolch Keycap set
WTB: KMAC2 kit
Offline Synjin
« Reply #559 on: Tue, 10 March 2015, 19:19:00 »
There is a tiggle for lighting mode for different sections of the KB that is accessed via programming software.
Offline Data
« Reply #560 on: Tue, 10 March 2015, 20:05:36 »
There's a way but I haven't figured out the correct sequence yet.
You need to set the LED controls in the 02D mapper first. Then it's a matter of pressing the right keys to get it in that mode and set the speed.
Offline swornxin
« Reply #561 on: Sat, 14 March 2015, 20:53:59 »
Well I think I royally screwed up my first build.  Put all the switches into the plate first and now I can't get everything to line up.  Taking them out isn't working very well.
EDIT:  Okay, I've figured out how to get the switches out of the plate.
« Last Edit: Sat, 14 March 2015, 20:57:02 by swornxin »
  • "Who dares, wins"
« Reply #562 on: Sun, 15 March 2015, 00:40:14 »
hmmm ok ill play around with it more i guess xD
WTB: KMAC2 kit
Offline Dreamre
    • kbdlife
« Reply #563 on: Sun, 15 March 2015, 01:34:59 »
So, does the PCB come with any preinstalled firmware? Or would I have to install my own before using?
Offline Data
« Reply #564 on: Sun, 15 March 2015, 12:07:30 »
Yes, it comes with a default layout and most keys work properly out of the box. You will need the Windows driver, boot loader, and 02D Mapper to customize it further.
Offline tjweir
« Reply #565 on: Sun, 15 March 2015, 12:55:38 »
Built my Red Octagon - Potato Warning - http://i.imgur.com/87YfQw8.jpg?2
xauser's tmk fork is making this awesome - https://github.com/xauser/tmk_keyboard/tree/octagon
« Reply #566 on: Sun, 15 March 2015, 13:01:23 »
I also added support but it is untested
94216-0
Offline tjweir
« Reply #567 on: Sun, 15 March 2015, 13:05:22 »
Windows only?
Offline swornxin
« Reply #568 on: Sun, 15 March 2015, 18:40:13 »
I would definitely love to try this out.  It worked perfectly with my Phantom.  The only issue I'm having is that you can't choose different layouts (ie. 1.5u CTL & ALT).  With the Phantom layout, you can choose between ANSI 84, ANSI 87, etc.
« Reply #569 on: Sun, 15 March 2015, 19:37:40 »
Yeah I still need to fiddle with it
Offline Dreamre
    • kbdlife
« Reply #570 on: Mon, 16 March 2015, 20:58:02 »
Is there a setting to adjust debounce?
Edit-
Hours later, I figured it out!
« Last Edit: Mon, 16 March 2015, 23:47:05 by Dreamre »
Offline tjweir
« Reply #571 on: Wed, 18 March 2015, 13:56:35 »
My octagon is humming along nicely thanks to xauser's TMK port.
Thanks xauser!
Offline whentheclouds
« Reply #572 on: Wed, 18 March 2015, 14:00:08 »
anything wrong with the Duck firmware aside from being in Korean?
Offline tjweir
« Reply #573 on: Wed, 18 March 2015, 14:02:58 »
I wanted things in tmk that Duck's does not offer, mainly media keys.
Also, the only windows machine in our house is my wife's work laptop, far easier to tweak layouts with tmk and dfu-programmer on my mac.
« Reply #574 on: Wed, 18 March 2015, 17:57:27 »
thanks for the info, didn't realize duck's firmware is not cross platform. what programs do the media keys work on?
Offline tjweir
« Reply #575 on: Wed, 18 March 2015, 19:08:04 »
For me, I have play/pause, volume up/down, mute, next and previous track on layer 1.
The are global, so they work all the time.
« Reply #576 on: Wed, 18 March 2015, 19:14:51 »
foobar already let you set (global) shortkeys, just curious if other programs like VLC/MPC-HC/Spotify support your approach and whether they would clash if you have, say, VLC and Spotify on at the same time
Offline tjweir
« Reply #577 on: Wed, 18 March 2015, 19:38:47 »
Oh I don't use spotify, so maybe it won't work.  Sorry. N
Offline tjweir
« Reply #578 on: Thu, 19 March 2015, 08:00:06 »
I just installed Spotify, and if it's running, play/pause will control Spotify, volume up and down affect the global volume, next/previous do not affect Spotify.
HTH.
Edit: Lulz at getting old, no idea who 90% of the artists are in the Top 100 on Spotify. :)
« Last Edit: Thu, 19 March 2015, 08:03:28 by tjweir »
Offline swornxin
« Reply #579 on: Thu, 19 March 2015, 17:05:33 »
Figured I would post this now, even though most are done their builds.  I went with Cherry tactile greys with 62g springs and clear switchtops.  My first build ever.  Waiting on the classic beige GB to happen until I get the caps on though.  Only an iPhone photo for now.  I'll try to update tomorrow when I bring it to work to use the backdrop for some photos.
« Last Edit: Thu, 19 March 2015, 17:07:05 by swornxin »
« Reply #580 on: Thu, 19 March 2015, 17:46:38 »
thanks. reading around a bit, it seems like media control keys only work for the last program you have active which seems like both a good and bad thing
Offline sethk_
  • Grand Master Wizard Pizza
  • www.kbdhub.com
    • My webstore
« Reply #581 on: Thu, 19 March 2015, 17:48:49 »
If you want to set hotkeys in Spotify, you might want to use a program called Toastify. I use it on my HHKB, and Ctrl + Alt + X = Pause, Ctrl + Alt + Z = Previous, and Ctrl + Alt + C = Forward. It seems to be pretty lightweight, and it also shows you the current song playing when you skip it, or pause.
« Reply #582 on: Thu, 19 March 2015, 18:04:27 »
good stuff, thank you  :-)
Offline Ouro
  • Laughable
« Reply #583 on: Fri, 20 March 2015, 19:23:02 »
How do you like those compared to Clears?
Offline swornxin
« Reply #584 on: Fri, 20 March 2015, 20:06:16 »
I don't notice too much of a difference to be honest.  I would have grabbed clears but they are sold out every where.  This was the next best option, since I planned on swapping the springs anyways.  I can't stand the tactile greys without the spring swap though.  I tried it for a bit on my Phantom and it was an awful typing experience after a week or two.
Offline rainb1ood
  • so pretty so plastic
« Reply #585 on: Thu, 26 March 2015, 19:19:19 »
I've been playing around with the 02 KeyMapper. I was able to change the layout but couldn't get the arrow keys to assign them, it keeps going back to "EMPTY"
So I flashed it back to the default by going to File -> New - > 02D Octagon Custom v1.x then saving it as a new hex file
After I flashed it the keyboard is now 'stuck' in DFU mode. When I unplug and plug it again without hitting the DFU key it still goes to DFU mode
When I flashed it manually in command prompt still no luck and keept getting this:
Code: [Select]
D:\Keyboard programming\DFU\dfu-prog-usb-1.2.2>dfu-programmer atmega32u4 flash main.hex
Checking memory from 0x0 to 0x6FFF...  Empty.
0%                            100%  Programming 0x7000 bytes...
[ X  ERROR
Memory write error, use debug for more info.
Am I in big trouble here?
EDIT: Fixed it, I did an erase --force
Code: [Select]
D:\Keyboard programming\DFU\dfu-prog-usb-1.2.2>dfu-programmer atmega32u4 erase --force
Erasing flash...  Success
Does anyone know how to get arrows keys to work? It only works when I use the default layout that 02D Keymapper has. When I use my own layout the "?" on the arrow keys keeps going back to "EMPTY" after flashing.
« Last Edit: Thu, 26 March 2015, 19:39:43 by rainb1ood »
Offline tjweir
« Reply #586 on: Thu, 26 March 2015, 19:55:24 »
I think you need the Korean Language pack or support for the arrows to look correct.
Offline rainb1ood
« Reply #587 on: Thu, 26 March 2015, 20:18:30 »
Yeah I just noticed the simplified guide (docx file) mentioning it as a bug. The solution I found was starting from scratch and not touching the arrow keys that are already assigned.
However, there is one bug that I have for arrow keys setting but some people are not having this bug. As you can see the picture below, the arrow keys are shown as “?”. After u set on the “?” arrow keys on some of your layers, the data entry wont be recorded even u have saved the .hex file
Offline SuperSumo
« Reply #588 on: Fri, 27 March 2015, 22:40:55 »
I just found this thread and signed up on the board. Will this group buy happen again? The Octagon seems like the perfect keyboard and I would love to get one.
« Reply #589 on: Sat, 28 March 2015, 01:44:17 »
someone on the classifieds is selling their unassembled silver kit: https://geekhack.org/index.php?topic=67302.0. a 2nd GB, if it occurs at all, will not happen in the foreseeable future. if you simply want a 75% layout, there are also a number of alternatives but not so many, as 75% is quite unpopular compared to 60% and TKL
Offline rainb1ood
« Reply #590 on: Sat, 28 March 2015, 07:51:24 »
Can you add or change the color that the RGB LED in the PCB cycles through? So far it only cycles green, red, purple and blue. No yellow :D
Offline Data
« Reply #591 on: Sat, 28 March 2015, 13:35:29 »
It cycles through most of the RGB spectrum depending on what setting you have it on.  If you just want it to show yellow then you can dig into the RGB settings and mix your own from red & green.
Offline rainb1ood
« Reply #592 on: Sat, 28 March 2015, 13:50:18 »
Is there a guide for the RGB settings in the 02D keymapper?
Offline radio_killah
  • Chinchillin'
« Reply #593 on: Sat, 28 March 2015, 14:48:21 »
Have fun!
Is there a guide on how to use this?
  • Chinchillin'
« Reply #594 on: Sat, 28 March 2015, 14:54:30 »
Having issues connecting to the dfu...  :(
Offline SuperSumo
« Reply #595 on: Sat, 28 March 2015, 19:02:50 »
The only 75% boards I've seen with semi-standard key sizes are the Noppoo Choc Mini 84 and the Keycool 84.
I've also seen the Deck 82, but it has an odd layout (tilde down near space bar and off sized 1 key) and the the KBT Race 2, but it has odd key sizes for the keys on the right.
I can't find any Keycool 84s for sale and the only Choc Mini for sale has red switches. I was hoping for MX clears or browns.
Do you know any other alternatives that I don't know about? $400 is pretty steep for a keyboard, especially when it was originally on sale for $295+shipping+fees (were the shipping+fees really $100?).
Thanks for any input.
Offline tjweir
« Reply #596 on: Sat, 28 March 2015, 19:22:19 »
I have an MX-MINI PCB doing nothing right now. And once sprit starts shipping his 75% pcbs and cases, there should be some on the market.
I'll be selling a few for sure.
Offline snipars
« Reply #597 on: Sat, 28 March 2015, 19:28:40 »
Since i missed the groupbuy, would people who have the keyboard agree that $400 is a reasonable amount to pay for one?
this keyboard really looks perfect for me, i think the layout looks absolutely fantastic as well as the case & the fact that everything but the switches are pre-soldered
i plan on combining this with gateron blacks and GMK caps, it would be very costly but i'd be able to sell other keyboards to pay for it.
to people who have built your octagons - is this keyboard worth the money?
Duck Octagon + Gateron Black |HHKB Pro 2 | Poker 2 + Vintage Black + Tex case | Unicomp Ultra Classic | WASD V2 |
Offline tjweir
« Reply #598 on: Sat, 28 March 2015, 19:39:20 »
I bought two octagons, one for work and one for home. I am selling every other board I have due to the awesomeness of the octagon.
So yes (for me) worth it.
(Keeping one modded Apple M0110 because nostalgia and the TX1800 is coming still)
  • Chinchillin'
« Reply #599 on: Sat, 28 March 2015, 20:32:08 »
Can anyone tell me what DFU programmer build and octagon software version they used? I can update the firmware to the ATmega32U but then every time i go to upload a hex it says no DFU connected...
