Author Topic: Xerox 820-II $100 + shipping OBO  (Read 3920 times)
« on: Tue, 04 November 2014, 00:43:48 »
Dorkvader seems to think Hall effect or vintage SMK from this old post.  The only other info I could find is with a low profile ITW Magnetic Valve, which this is not.  Could be a fun project for someone to revive.  The only one I know should know for sure what this has is HaaTa since it appears he has one.
http://www.ebay.com/itm/XEROX-KEYBOARD-UNTESTED-AS-IS-SEE-DESCRIPTION-/321572784898?pt=US_Vintage_Computers_Mainframes&hash=item4adf3b4b02
Re: Xerox 820-II $100 + shipping OBO
« Reply #1 on: Tue, 04 November 2014, 11:19:04 »
Yeah, here's the options in order of liklihood
1. honeywell hall effect (bent spacebar Ive only seen on HE and keytronic) ctrl keys and return key are the right shape/size. FOnt looks about right. Key profile looks right.
2. vintage keytronic Foam & foil. Bent spacebar. Thick spherical doubleshots, etc.
3. Vintage SMK (thick black spherical doubleshots, return key looks about right.
pretty sure its not vintage SMK because of the curved spacebar.
« Last Edit: Tue, 04 November 2014, 11:21:06 by dorkvader »
Offline jacobolus
« Reply #2 on: Sat, 22 November 2014, 19:32:09 »
Someone here bought this thing right? Has it arrived yet?
Seems like it went for $44 + $30 shipping. Not bad for a hall effect keyboard, if that’s what it was.
« Last Edit: Sat, 22 November 2014, 19:34:15 by jacobolus »
« Reply #3 on: Sat, 22 November 2014, 19:39:50 »
I believe Hwood got it.
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #4 on: Sat, 22 November 2014, 19:48:30 »
Yep, got it. Should be coming monday
« Reply #5 on: Sat, 22 November 2014, 21:08:34 »
You had better take pictures and disassembly.
I'll add this to the number of people to contact once hall controller is figured out.
Offline berserkfan
« Reply #6 on: Sat, 22 November 2014, 22:10:43 »
I like this. The more people are working on Hall Effect, the more shared knowledge there is, the better!!!
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #7 on: Sun, 23 November 2014, 00:00:30 »
I'll be sure to :thumb:. Really hoping this turns out to be hall effect
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #8 on: Mon, 24 November 2014, 13:04:19 »
Bruh
Maxi-switch vintage linears
pics to come
« Last Edit: Mon, 24 November 2014, 15:04:25 by hwood34 »
Offline jacobolus
« Reply #9 on: Mon, 24 November 2014, 14:33:29 »
SMK vintage linear
Those are some fine keycaps. How do you like the switches?
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #10 on: Mon, 24 November 2014, 14:37:08 »
SMK vintage linear
They kinda stick near the bottom on the return and are pretty heavy, so not a whole lot. I'll mess around with it a little more though
« Reply #11 on: Mon, 24 November 2014, 14:44:58 »
need a good pic of the spacebar.
So far there are three known manufacturers of curved ones. Microswitch, keytronic and (now) SMK.
Offline jacobolus
« Reply #12 on: Mon, 24 November 2014, 14:49:05 »
Is there actually SMK branding, or do the switches just look like SMKs? I think there were like 10 other similar looking switches.
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #13 on: Mon, 24 November 2014, 14:54:12 »
Really? No SMK branding, the only thing I see is "The Maxi-Switch CO" printed on the PCB
edit: just did a quick search, turns out these are probably maxi-switch vintage linears
« Last Edit: Mon, 24 November 2014, 14:56:30 by hwood34 »
Offline jacobolus
« Reply #14 on: Mon, 24 November 2014, 14:55:50 »
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #15 on: Mon, 24 November 2014, 14:57:32 »
Probably these then:
http://deskthority.net/wiki/Maxi_Switch_vintage_linear
yeah. Still an interesting find, just not crazy about the switches
« Reply #16 on: Mon, 24 November 2014, 15:10:27 »
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #17 on: Mon, 24 November 2014, 15:14:27 »
Damn, sorry.
Nah, it was still  good buy. The things really cool, and the switches aren't that bad. I'm gonna try and clean em out or lube them and see if I can make them a little smoother.
And what's the term for when tiny particles of solder collect on a metal? I just noticed it on the spacebar stab and was curious
« Last Edit: Mon, 24 November 2014, 15:16:23 by hwood34 »
Offline jacobolus
« Reply #18 on: Mon, 24 November 2014, 15:23:17 »
If you have some very hard (e.g. carbide-tip) flush cutters, you could snip a few loops of the spring off for each switch, and get something a bit less stiff.
Or I wonder if the spring is similar enough in size that you could use e.g. MX or Alps springs.
