Author Topic: HHKB Wakeup Function broken?  (Read 5212 times)
Offline Sygaldry
  • Edema Ruh
« on: Wed, 05 November 2014, 12:53:32 »
I have Dipswitch 6 toggled on but the board won't wake my computer from sleep.
Anyone else have this issue?
rMBP running Yosemite
HHKB Pro 2 Type-S
Edit:
Nevermind, I've figured out the issue.
Thanks for all the suggestions!
In the end it turns out that the HHKB doesn't play nice with USB hubs. I gave the HHKB it's own USB slot on my laptop and it all works fine now.
Now I'm just questioning why I sold my uber-decked out Thinkpad for this dinky Apple product with only 2 USB slots (worst design choice ever).
« Last Edit: Wed, 05 November 2014, 16:17:39 by Sygaldry »
null
Offline oscillik
    • music podcasts
Re: HHKB Wakeup Function broken?
« Reply #1 on: Wed, 05 November 2014, 13:04:49 »
I don't have this problem, running Windows 8.1 on a self-built PC.
Keymacs A620N-Rev.A with Alps SKCM Salmon switches
Offline osi
« Reply #2 on: Wed, 05 November 2014, 13:32:16 »
Not a problem in Linux or windows for me either.
Try deactivating dip 6 and setting it back to on. A dip switch not fully engaged can cause issues
Offline 0100010
  • Not Sure
« Reply #3 on: Wed, 05 November 2014, 14:10:51 »
DIP was changed while the keyboard was unplugged?
Offline jameslr
« Reply #4 on: Wed, 05 November 2014, 14:19:34 »
Not a problem on my Mac Mini running yosemite.
CM Novatouch | Filco MJ2 TKL w/ HID Lib | REΛLFORCE 87U 55g | CM QFR
« Reply #5 on: Wed, 05 November 2014, 15:28:39 »
I have this problem on an older Mac mini.
I tried toggling a few DIP switches, then I could wake up the Mac, but the firs time I tried to enter the password no keystrokes were recognised.
Now I just click the mouse to wake the Mac.
Offline Sygaldry
  • Edema Ruh
« Reply #6 on: Wed, 05 November 2014, 15:45:19 »
I tried toggling on and off, still not working
Yep.
Weird and a bit disappointing =/
null
« Reply #7 on: Wed, 05 November 2014, 15:47:01 »
Yep.
Did you unplug and replug the keyboard after changing DIP switch setting?
The changes do not take effect until you do.
Offline Sygaldry
  • Edema Ruh
« Reply #8 on: Wed, 05 November 2014, 15:51:11 »
Yep.
Have tried multiple times =/
null
« Reply #9 on: Wed, 05 November 2014, 16:15:31 »
Which key are you pressing to wake your Mac?
I usually used space or Shift (with the above results).
Offline osi
« Reply #10 on: Wed, 05 November 2014, 16:35:39 »
Try using it it Mac mode only with no other dips set (shoutz to cam'ron) including having 6 set to the off position
Offline Sygaldry
  • Edema Ruh
« Reply #11 on: Wed, 05 November 2014, 17:13:01 »
Tried everything you guys suggested but I think I figured out my problem!
The HHKB doesn't want to get along with my AmazonBasics USB 3.0 hub.
I gave my HHKB its own dedicated USB slot and wakeup works perfectly!
Thanks for all the help, guys!
null
