Author Topic: Unpopular Keyboard Opinions  (Read 2594161 times)
Offline granola bar enthusiast
Re: Unpopular Keyboard Opinions
« Reply #5950 on: Sat, 02 April 2022, 16:45:58 »
i despise the PE foam mod, it ruins the uniqueness in switches and boards and makes every single board sound like marbles.
It can sound good but you ideally don't want 15 boards all sounding the same with hundreds of dollars of price difference
Offline Maledicted
« Reply #5951 on: Sun, 03 April 2022, 21:08:57 »
Wouldn't know, wouldn't care.  ;D
I imagine that counts as an unpopular opinion on its own.
Offline CaesarAZealad
  • Racc
« Reply #5952 on: Sun, 03 April 2022, 21:43:01 »
I agree with a small caveat. There's certain boards it works for, but seeing people just cram it into everything is annoying. I love some thock, but not every board has to thock.
Hell I recently got an ASK and that board has some amazing thock without needing a single strip of foam.
One, Two, Three, Four, Five, Six, Seven, Eight, Nine, Ten, Eleven, Twelve, Thirteen, Fourteen, Fifteen, Sixteen, Seventeen, Eighteen, Nineteen, Twenty... Yeah that seems about right.
"Ask your mother how good I can use more than two fingers." - Caesar, 2023
Offline NoteMakoti
  • for sale, baby shoes, never worn
« Reply #5953 on: Tue, 05 April 2022, 14:31:00 »
The problem with saying "It makes most boards sound the same!" is that the kind of person who not only buys multiple boards, but cares how they sound and wants them all to sound different is a minority of a minority, even in the keyboard hobby.
The sound "meta" sucks, tbh. It's morphed into financial cope; A way for people who haven't burnt themselves out on hype yet to go "THIS is why this board is worth [insert hundreds of dollars]!", but the truth is that you can make anything sound good with a bit of work. Much less work than even 3 years ago, back when MX switches were all made with crappy loose/scratchy molds and hollow traymounts were all the rage. The gap between those premium boards with lots of love and care put into them and budget boards with off-the-shelf unmodded switches and maybe a mod or two is more narrow than ever.
Offline jacobalbertus1
« Reply #5954 on: Tue, 19 April 2022, 13:27:14 »
topre is overpriced rubber domes with a spring capacitive PCB, cheap capacitive controller cheap to make I can make model f ones in low quantity for less than 20  and those use a pro micro and JLC PCB parts rubber domes CHEAPER than a thrift shop dell l100 case made of plastic CHEAP dye-sub PBT keycaps not that expensive
Model f 122 USB industrial paint (daily), model f xt inbox almost nos Ellipse approved, NOS model m ssk , Model F 77 for class (special needs I was told I had to use a mech or a key beeper by the school) model m 1391401 silver label ( this was a factory messup where they stuck a 139101 sticker on it and sent it with a ps/2) model m 1390131 model m unicomp industrial case modded  and a model f at
Offline bkrownd
« Reply #5955 on: Wed, 20 April 2022, 19:12:11 »
  The feel of keycaps under my fingers:
"cherry" profile: floppy little plastic flakes like typing on a tray of "Kaboom!" breakfast cereal
Signature SA: the satisfyingly rock-solid quality feel of precious agates
« Reply #5956 on: Wed, 20 April 2022, 21:07:01 »
i think the 65%'s that have the same blocker for the arrow key cluster on the win key cluster look extremely bad and a 65% won't have symmetry anyways
« Last Edit: Sat, 23 April 2022, 16:40:41 by granola bar enthusiast »
Offline HungerMechanic
« Reply #5957 on: Thu, 21 April 2022, 09:44:17 »
Topre EXPOSED!
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #5958 on: Sat, 23 April 2022, 12:33:42 »
Stepped caps lock is overrated
« Reply #5959 on: Sat, 23 April 2022, 13:12:14 »
I LOVE stepped key caps.
- D Trump 2026-10-24
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #5960 on: Sat, 23 April 2022, 13:46:01 »
Dialing in the muscle memory to press the left side of the key has eluded me even after a few years of use :'(
Offline iri
« Reply #5961 on: Sat, 23 April 2022, 18:00:18 »
If I could parse this, I'd applaud you for destroying topre with facts and logic
-Ray Bradbury
  • Racc
« Reply #5962 on: Sat, 23 April 2022, 18:11:21 »
They look so good, but they're just get in the way. For caps lock I could definitely swing it because it'd prevent me from hitting caps during video games, but stuff like the enter would just fuuuuuck with me.
« Reply #5963 on: Sat, 23 April 2022, 18:34:21 »
i'm on the fence abt stepped caps, don't love it or hate but i will use it if it makes me accidentally press caps lock less, a few months back i ordered a  Mistel Keycap set from Amazon and it's stepped cap's was centered? weird
Offline Greywolf
« Reply #5964 on: Sat, 23 April 2022, 19:16:29 »
My opinions, worth what you pay for them:
- SA-P is the best key profile I have ever worked with.  SA non-profiled (all R3, for example) is a nightmare.
- The current backspace key needs to be two keys ( \| and ~`), The Backspace key needs to be (a 1.5u) just above the Return key,  Control directly left of 'A', and CAPS LOCK moved someplace where you won't hit it accidentally.
- Win keys make great remappable combo keys on non Windows boxes.
- All keyboards need Super, Hyper, Meta, AND Alt.
- Glowy is overrated unless and until you can get custom 2-shot backlit-compatible keys.  I wish I could find a set of Oblotzky ASCII caps (SA-P) in backlightable, but probably not in my lifetime.
- There should be two rows of F-keys [F1-12 and, above it, F13-24].  I'd say there should be a 2x5 bank of left-hand F-keys as well but I can do with having a separate keypad for that.
- Compact FF keyboards are HIGHLY overrated.  I have one and even mapped out it's a royal pain in the left patella to use.
- Artisan keycaps are HIGHLY overrated.
- The "Media Keys" on keyboards, with the exception of mute and the volume knob, really need to just be standard switch keys above the NP if one exists; or in a vertical row of 4 on the far right if not.
- Print Screen/Scroll Lock/Break need to be moved down one row.
- The 1800 layout is off-putting (but it might be worth a look).
« Reply #5965 on: Sat, 23 April 2022, 21:19:13 »
it's so true tho I get parts made for IBM model f's and beam springs all the time so I know what all the sensing electronics cost to make on a SMALL scale, we already know its much cheaper on a mass scale, all i don't know almost exact cost is the topre domes sliders plates and springs but that can be all that much if unicomp can pump out a model m for 100 with good profit than why is a HHKB 200 or more
Offline hvontres
  • Buckling Spring Enthusiast - Full Size Evangelist
« Reply #5966 on: Wed, 27 April 2022, 00:17:45 »
Well, it is a psuedo 1800, but I LOVE the extra row of F keys on my Boston (link in signature)
Henry von Tresckow
1986 Model M 1390131, 1987 Model M 1391401 , 1993 Model M2 Modded Reddragon k556(Test Mule) Boston Prototype x2 (Daily Drivers :) )
Offline bkrownd
« Reply #5967 on: Wed, 27 April 2022, 01:01:00 »
(....cries softly inside....)   :(
« Reply #5968 on: Wed, 27 April 2022, 08:40:18 »
i also think that you should never EVER use tactiles on a plateless board, all the bounce combined with the bump just feels too weird
Offline yui
« Reply #5969 on: Fri, 29 April 2022, 14:54:19 »
now you make me want to try to feel it, if only i had tactile switches around... and a pcb i was willing to "sacrifice"
Offline mljs54
  • Team Topre
« Reply #5970 on: Fri, 06 May 2022, 20:53:29 »
[wrong reply]
« Last Edit: Fri, 06 May 2022, 21:15:27 by mljs54 »
ReΛlforce 87UB EK
Offline Kevin-3992
  • kindlestar team
« Reply #5971 on: Sun, 08 May 2022, 10:43:48 »
This post is so helpful
Offline VaporKeebs
« Reply #5972 on: Mon, 23 May 2022, 04:05:09 »
r/budgetkeyboards is the new "stop gatekeeping our gatekeeping" corner.
r/mechanicalkeyboards is the new spot for budgetkeebs and GMK hate .
r/customkeebs is the only place worth visiting anymore... aside from GH.
My reasoning... post a nice custom board on r/mk with GMK caps and people will ignore it because "must be nice to be rich". Post the same board on r/ck where they legit have only 10% as many viewers and it'll get upvoted like crazy because they actually like nice stuff there.
Forget about budget keebs... they banned me for telling someone Gateron makes better products than Akko and their milky yellows are cheaper than most anything Akko sells. Got banned for "sharing my opinion as a fact" LMFAO but the mods will claim up and down I was harassing someone... too bad I got receipts from when a mod let me back in because "I dont see anything youve done wrong". LOL
« Reply #5973 on: Mon, 23 May 2022, 10:05:16 »
i agree with this, r/mechanicalkeyboards has over the years, converted from a reddit of individuals who were interested in the subject and wanted to help each other out, and now to some of those and the majority being those who are just there because "it's the new "trend"
« Last Edit: Mon, 23 May 2022, 12:22:23 by granola bar enthusiast »
  • Racc
« Reply #5974 on: Mon, 23 May 2022, 10:55:24 »
Imagine using reddit.
« Reply #5975 on: Mon, 23 May 2022, 11:57:10 »
I can't.
I have looked at it a few times but I can't understand it.
Offline Maledicted
« Reply #5976 on: Mon, 23 May 2022, 14:56:03 »
I can't.
It works for Googling specific information, just to read through previous conversations on there. Even that is a chore with how the comment section works on that terrible website. Basically totally unusable otherwise if you ask me.
Offline MIGHTY CHICKEN
« Reply #5977 on: Mon, 23 May 2022, 14:58:14 »
Sometimes when I’m looking for a normal person opinion I’ll just search something like “xxxx recommendation Reddit”
  • Racc
« Reply #5978 on: Tue, 24 May 2022, 23:18:08 »
I assume you use the opposite of what comes up on reddit, because dear lord are there some ****stains on reddit, and oh boy do they love to spread their god awful opinions.
Offline fortissim2
« Reply #5979 on: Tue, 31 May 2022, 10:06:13 »
r/mk is just a comedically large echo chamber of GMK groupbuys and generic-ass 60%s and 65%s. Basically, there's really nothing spectacular in that subreddit.
Offline selsik
« Reply #5980 on: Tue, 31 May 2022, 16:34:38 »
r/mk is pleb central, r/ck is the only place worth visiting anymore
i have zero interest in seeing the millionth GMMK pro with xda keycaps... if i have to see xda matcha or xda bee honey one more time i'm gonna vomit on my realforce r2
« Last Edit: Tue, 31 May 2022, 16:37:09 by selsik »
Topre >>> MX
« Reply #5981 on: Tue, 31 May 2022, 21:58:09 »
« Reply #5982 on: Tue, 31 May 2022, 23:59:41 »
R2 realforce  :-X
R1 87u best layout
Offline selsik
« Reply #5983 on: Wed, 01 June 2022, 01:50:25 »
lol you actually spent money on that horrid keycap set
arguably the ugliest light green i've ever seen
i don't have to vomit, the puke's already mounted on your keyboard
Topre >>> MX
« Reply #5984 on: Wed, 01 June 2022, 10:42:18 »
I also put it on a generic 65% for your viewing pleasure. Hope you noticed.
It's just for laughs, as I don't type on XDA profile.
I actually agree that there are way too many 65% keyboards posted on r/mk. I don't find it to be a space that caters to my preferences.
Offline Maledicted
« Reply #5985 on: Wed, 01 June 2022, 13:50:08 »
I liked both, although I don't think those caps go well with that case.
Offline bkrownd
« Reply #5986 on: Thu, 02 June 2022, 19:51:48 »
Looks very nice!
« Reply #5987 on: Fri, 03 June 2022, 10:36:49 »
Vintage keyboards are absoulout ****. Yall really need to start using newer keyboards. Get yo old ass head out of the ****in ground and start using the newer stuff.
« Reply #5988 on: Fri, 03 June 2022, 10:48:09 »
Hey, I never thought about that. Good idea !
Offline Maledicted
« Reply #5989 on: Fri, 03 June 2022, 15:09:38 »
Think of this in the reverse, which is what is actually the case. People typically try modern switches, feel there's something missing and/or have an insatiable appetite for something new/different, try vintage mechanisms ... discover they're vastly superior and then begin finding every opportunity to use vintage mechanisms instead because nothing else can compare anymore. I try other modern switches just to try to find something cheaper than buying Models F and playing the SKCM lottery that's at least acceptably enjoyable to type with.
Have you tried any good vintage switches? Would it be an accurate stereotype for me to assume that all you've ever tried is MX derivatives, and maybe some heavily abused Model M, and you've already determined that everything but your preference sucks?
If so, I was once like you. As many of us were.
« Last Edit: Fri, 03 June 2022, 15:38:42 by Maledicted »
  • Racc
« Reply #5990 on: Sat, 04 June 2022, 10:57:06 »
Hey you're that guy from like, two days ago, who made a whiny piss baby post about vintage computers or something. Bit of advice, come up with a less obvious alt.
« Reply #5991 on: Sat, 04 June 2022, 16:15:49 »
Looks very nice!
Thanks. I think the gray / smoky transparent cases go well with green sets [Matcha, Botanical], but it can be divisive.
Other people frequently use Dolch-like sets, including Modern Dolch. I've put MT3 3277 on a charcoal MK870, which looks good. But sometimes, the Dolch sets are too drab on charcoal, IMHO.
Offline Maledicted
« Reply #5992 on: Sat, 04 June 2022, 21:36:51 »
Looks very nice!
Dolch is great, but it can be over-done. Not that I'm some kind of keyboard fashionista anyway.
  • Racc
« Reply #5993 on: Sat, 04 June 2022, 21:57:06 »
Beige vintage caps are better than granite/charcoal/gray caps
« Reply #5994 on: Sun, 05 June 2022, 00:19:38 »
I feel like this is the popular opinion here, given the number of beige sets we've seen along with all the beige add-on kits.
  • Racc
« Reply #5995 on: Sun, 05 June 2022, 08:45:18 »
Probably. The more I read this thread the more I realize I have popular opinions.
« Reply #5996 on: Sun, 05 June 2022, 09:25:12 »
IIRC, KBDFans advertised the charcoal KBD67 Lite by using beige vintage-style caps. Actually, they were GMK Muted colour in tint, looked a lot like Artifact Bloom "Vintage."
This was back in R1.
I think it's fine, even great. But I tend to use such keycaps on black/white and especially white polycarb boards (e.g. 9009).
Offline bkrownd
« Reply #5997 on: Fri, 10 June 2022, 21:38:34 »
  Unpopular opinion #4209235:
  I've been hanging out here for a couple years and I just realized that I'm extremely "meh" about 99% of the keyboards people talk about.
Offline ideus
  • Björkö.
« Reply #5998 on: Sat, 11 June 2022, 21:45:38 »
This is correct. However, the question is if they should be ABS-DS, or PBT.
  • Racc
« Reply #5999 on: Sun, 12 June 2022, 13:52:17 »
I'm forced to use PBT. I melt ABS like a mother****er.
