Author Topic: Unpopular Keyboard Opinions  (Read 2593255 times)
Offline bkrownd
Re: Unpopular Keyboard Opinions
« Reply #6150 on: Wed, 26 July 2023, 19:16:56 »
I throw up a little every time I hear the word "layers" in a keyboard discussion.  but hey, that's just me.  :D
Offline Seirin-Blu
« Reply #6151 on: Thu, 27 July 2023, 12:35:01 »
I mean you use layers whenever you type a capital letter or symbol on the num row, but I guess you can see what’s on the next layer of those so it’s a little different I guess.
Offline Sup
« Reply #6152 on: Thu, 27 July 2023, 12:53:32 »
Don't tell bro that he using layers daily on his phone otherwise he will throw up every time he uses it.
current
Coming soon
Offline CaesarAZealad
  • Racc
« Reply #6153 on: Thu, 27 July 2023, 16:41:02 »
Just use layers bro
« Last Edit: Thu, 27 July 2023, 16:42:36 by CaesarAZealad »
One, Two, Three, Four, Five, Six, Seven, Eight, Nine, Ten, Eleven, Twelve, Thirteen, Fourteen, Fifteen, Sixteen, Seventeen, Eighteen, Nineteen, Twenty... Yeah that seems about right.
"Ask your mother how good I can use more than two fingers." - Caesar, 2023
Offline bkrownd
« Reply #6154 on: Thu, 27 July 2023, 17:33:26 »
Not sure what you're referring to, but using cellphones does make me throw up for various other reasons.
Offline bkrownd
« Reply #6155 on: Thu, 27 July 2023, 17:42:58 »
Indeed, capitals create a practical limitation due to the number of keys you can reach from home row.  I don't enjoy holding shift to create a capital letter or number-row symbols either, but I don't see an obvious way around that one.  Fortunately most programs (hopefully all) are written so you don't have to key-combination any of the shift-activated characters at the same time.  Mostly thanks to gaming it is however common to have to do things like hold WASD/HJKL/arrows and hit various other keys rapidly.
Offline Rhienfo
  • GOTHETIGES
« Reply #6156 on: Thu, 27 July 2023, 17:49:26 »
//media.printables.com/media/prints/361107/images/3058616_9ea2a164-0f11-45eb-906c-f8baca2d629a/thumbs/inside/640x480/jpg/pain27bl.webp[/img]
Just use layers bro
Don't diss the pain27 it's perfectly usable, and the best australian keyboard ever produced
  • Racc
« Reply #6157 on: Thu, 27 July 2023, 18:21:29 »
Just use layers bro
Just use layers bro.
Offline Rhienfo
  • GOTHETIGES
« Reply #6158 on: Fri, 28 July 2023, 10:23:04 »
Yeah perfectly useable to me
Offline Subdromat
« Reply #6159 on: Wed, 16 August 2023, 02:18:02 »
While looking for an awkward switch with some reputation it has come to Cherry MX green. That RGB variant was hard to find. Not sure but vendors dont offer them anymore (RGB variant), maybe they out of life. Happy got 110 pieces for some clicky project.
« Reply #6160 on: Thu, 17 August 2023, 09:21:42 »
They look like little baggies of droogs. LOL
Offline VaporKeebs
« Reply #6161 on: Mon, 11 September 2023, 04:05:54 »
Any layout that reduces the need for stabilizers is superior to layouts that require more stabilizers.
Offline mohawk1367
  • Typing on: HHKB Pro Hybrid Type-S
« Reply #6162 on: Wed, 13 September 2023, 08:01:24 »
IMO more comfortable and convenient layout > number of stabilizers lol
weird opinion but definitely fits the thread
someone needs to make an aussie keyboard community called QMƎɹ┴⅄. get it? haha :D
Offline Mandan
« Reply #6163 on: Thu, 14 September 2023, 19:39:35 »
My IBM 84-key board now has 89 keys.  I split both Shifts and Insert in half, and the Big-Ass Enter into an extra 1u and 1.5u, and a 1.25u Enter.  The big 2u "+" key is now an Enter, using the wire-stabilized key from an early Model M board.  That and the space bar are the only stabilized keys on the keyboard.
The 1.25u Enter was a "just because I could" thing; I planned to use a 2u ANSI Model M Enter key.  But the tiny Enter turned out to be not-a-problem.  For that matter, the XT boards had a 1u Enter on a stepped 3u shield.
I've thought about splitting the 2u Enter on the cursor pad, but I'm fond of karate-chopping it, and I probably use it at least as much as the main Enter key.
Offline matt-taco
« Reply #6164 on: Sun, 24 September 2023, 19:03:34 »
XT or 96 key layouts are 1000% the best layouts. If you get good with it, you won't have to use a mouse a mouse for most tasks, AND you don't have to move your wrist too!!!!
The only downside is getting used to toggling the numlock and the new position for the nav keys.
Offline ItIsWritten
« Reply #6165 on: Mon, 25 September 2023, 03:36:22 »
So they can be improved if they have a downside?
Verstuurd vanaf mijn SM-G986B met Tapatalk
Offline matt-taco
« Reply #6166 on: Mon, 25 September 2023, 08:45:30 »
What I meant by downside, was, a steep learning curve. Once you get over it, it is not a problem
Offline TomahawkLabs
« Reply #6167 on: Thu, 05 October 2023, 08:35:18 »
My unpopular opinion: Soldered switch PCBs are superior to hot swap. Hot swap is great for if you want to try out new switches or are into modding switches, but soldering provides additional mechanical fastening allowing for an easier time removing keycaps and doing general cleaning.
Always looking for Alps SKCM/SKCL switches. Feel free to DM.
AMD 5600x | RTX3080 | 2x 1TB NVME + 4x 4TB HDD | B550M Pro-P | 32GB RAM | RM850x | Node 804 | Schiit Modius/Magnius + Audeze LCD-2 | 2x Dell S3422DWG
GMMK 1 Full Size Barebones | Zealio 67g ; Apple M3501 handwired | Alps SKCM Damped Cream
SA: Camping
Offline mohawk1367
« Reply #6168 on: Thu, 05 October 2023, 08:37:19 »
How does it make it easier to clean?
Offline Rhienfo
  • GOTHETIGES
« Reply #6169 on: Thu, 05 October 2023, 09:50:43 »
Agree with this, It also makes boards sound better (I'm not 100% sure why, but I think it has to do with switches having gaps in between the sockets which sound can go through, rather than soldering which doesn't have those gaps)
Plus it's slightly cheaper and fun to do, for any custom I don't know why you wouldn't but that's just me. You probably should have a hotswap board for modding switches as you said anyway.
« Reply #6170 on: Thu, 05 October 2023, 14:43:00 »
I claim it is easier to clean because I can quickly take off the keycaps as the switches stay in the plate and PCB because it is mechanically fastened. On nearly every hot swap keyboard I have used or tried some of the switches will release from the plate before the keycap is pulled off. Spending the extra time removing the cap from the loose switch and putting the switch back adds extra work.
I do think that every enthusiast who is into modding/trying new things should have a hot swap board as a test bed.
SA: Camping
Offline Rob27shred
  • Insane in the Membrane! 👻
« Reply #6171 on: Thu, 05 October 2023, 19:49:31 »
I agree with this for the most part as well. Although, hotswap PCBs have come a long way from the "you'll get one fixed layout & like it days". Coupled with a well made plate the switches will stay put so I'm way more likely to get hotswap PCB with a custom nowadays. If a board turns out to be special to me in some way then I'll for sure make a soldered build for it. Overall I prefer soldered, but hotswap has grown on me a little after a couple good experiences with it finally.
Offline bkrownd
« Reply #6172 on: Fri, 06 October 2023, 04:29:23 »
*shrug*  I find hot swap keyboards convenient for cracking one out of the box, throwing 60-100 favorite switches and new keycaps on, and getting instant satisfaction.  (no, I didn't scare up the energy to lube anything except the stabilizers)
Offline LogLab
« Reply #6173 on: Tue, 10 October 2023, 23:07:00 »
60% keyboards aren't practical, even with the programmable layers. I liken it to people who build their linux distros "from the ground up". They're just senselessly creating a rabbit hole of unnecessary work.
For me I feel it's way more comfortable to use a layer I activate with my thumb to have the arrow keys right under my homerow than to have to do the movement of my hand from the homerow down to the bottom and back to the homerow, it gets tiring esp with arthritis. I use 42 keys tho as a daily driver so thats a whole nother discussion LOL
Edit: Just realized I replied to a 9 year old comment lmfao. Point still stands thooooo
Offline ItIsWritten
« Reply #6174 on: Wed, 11 October 2023, 01:55:53 »
The thing is though that that would work on larger size keyboards as well. So you don't need a smaller keyboard to do that. But it's only practical if you're touch typing. If your hands are AFK and you quickly need to find a specific button all the smaller sizes make that harder.
Offline clay
  • No foams
« Reply #6175 on: Sun, 12 November 2023, 13:20:54 »
Just use layers bro
Imagine a 1-key keyboard, just like a switch and keycap keychain just that it functions as a real keyboard. Everything is a layer. Press the single key and an on screen menu shall pop out. Move your mouse to select the letter/number/symbol you want. Because hey, we like smaller keyboards since our 50 inch monitor has taken all the space on our airplane tray table.
P.S. jokes aside I hope I didnt offend anyone
Offline ItIsWritten
« Reply #6176 on: Mon, 13 November 2023, 04:48:05 »
Just use layers bro
Just use a hall effect switch with 200 levels...
Offline funkmon
« Reply #6177 on: Mon, 13 November 2023, 05:57:25 »
This is very pleasing to me. It's like one of those bad UI battles. Can we send one of these to  Chryros for a Waning video?
Offline wjrii
« Reply #6178 on: Mon, 13 November 2023, 08:46:33 »
See, the approach is all wrong here.  We've already made the move to the onscreen, so it's time for AESTHETICS.  I suggest a zero-key model with a classic 104-key footprint.
Offline Rhienfo
  • GOTHETIGES
« Reply #6179 on: Mon, 13 November 2023, 21:59:55 »
we need fake resin to accompany that.
Offline Exquite
  • GeekAnubis
« Reply #6180 on: Wed, 15 November 2023, 20:08:30 »
1. Just about every keycap set designed on pimpmykeyboard is ugly. When I see pictures of these keycaps on someones keyboards looks even worse.
2. SA keyset is horrible to type on and looks horrible.
3. I think model M and any other so called "vintage" keyboard is stupid.
4. If you think 60% keyboards are not practical well 40% are even worse. They seem like a major handicap.
5. I hate gamer looking or branded keyboards (razer, corsair, logitech, ect.)
I agree keysets designed by pimp is ugly for many people but SA does have many excellent sets such as SA SONG, ESPRESSO, and VIlEBLOOM. As someone started with cherry profile, SA looks quite weird initially. However, later on, I realized some colorways do fit the big fat legend and tall profile. The typing feel of SA SP also enhances any switches. Making tactile more tactile, linear more linear. The feel is also more smooth than gmk.
I'm a Color lover and a designer.
Offline funkmon
« Reply #6181 on: Wed, 15 November 2023, 21:27:55 »
That quote is from...a long time ago.
But also...how the heck does he think Model M is stupid?! appleonama get back in here and explain yourself.
Offline bkrownd
« Reply #6182 on: Thu, 16 November 2023, 00:49:39 »
SA is a satisfying manly man's door-slamming solid gemstone keycap profile.  Feels so good.
Cherry is like typing on cornflakes, and tastes worse.
Aaaaaand, if you didn't learn to type on a Selectric II your opinion is wimpy.
Offline mohawk1367
« Reply #6183 on: Thu, 16 November 2023, 07:49:52 »
1 and 2 are both true, but that the 3rd one is crazy... not everyone was around in the mesozoic.
Offline Exquite
  • GeekAnubis
« Reply #6184 on: Thu, 16 November 2023, 11:38:46 »
1. DSA is terrible. I hate using it, and won't buy from any group buys with DSA profile.
2. SA profile (sculptured, not uniform) is fun! They are my second favorite, after Cherry Corp or GMK thick ABS.
3. PBT is all hype. I prefer thick ABS by a wide margin. I can use PBT, of course, but I prefer thick ABS. Much, much prefer double shot ABS over dyesub PBT.
4. ErgoClears are just okay, but stock clears are better.
SA SP keycaps are really thick. I love that rigid feeling when typing.
Offline wjrii
« Reply #6185 on: Fri, 17 November 2023, 13:13:32 »
Some people in the hobby are trying desperately to recreate the typing experience of a membrane board; they just don't realize it.  The first Youtuber to pull together a GB for an aluminum case and Cherry-stem sliders on a "unified switch PCB with silent Topre-esque elastopolymer light linear actuators with solder-free one-shot swapping" is gonna make bank.
Offline bkrownd
« Reply #6186 on: Fri, 17 November 2023, 16:02:31 »
That's just insane in the membrane...   ;)
Offline Greywolf
« Reply #6187 on: Mon, 20 November 2023, 16:17:21 »
I just want to know why it is so damnably hard to find a keyboard which is/has
• mechanical switches
• TKL form factor
• UNIX key layout (i.e. ~` and |\ where Backspace always is these days, Backspace over the Return key, Control left of A, and Esc at the corner bordering TAB and !1)
I do not understand why this is not an appealing/desired layout, and it's really frustrating not to be able to find one.  I mean, I suppose I could try to make one...
Offline mohawk1367
« Reply #6188 on: Tue, 21 November 2023, 06:40:12 »
• TKL form factor
most unix ppl just use hhkb or remap
Offline Rhienfo
  • GOTHETIGES
« Reply #6189 on: Wed, 22 November 2023, 23:24:07 »
• TKL form factor
It's because regular ansi is more popular, and a lot of people find that split backspace looks weird on a tkl.
Most solderable tkl pcbs have the option for it so you could always solder the layout.
Offline transeurasian
« Reply #6190 on: Sat, 23 December 2023, 04:35:50 »
I got 2 right hands.
Offline zlobin356
  • Hi! My name is zlobin!
« Reply #6191 on: Sat, 23 December 2023, 15:17:04 »
65 and 75 are senseless
HHKB (keyboard) is overrated (quality of case, inconsistency)
salvation is bad keyboard due usb cutout and qc
meletrix is bad budget option
vintage blacks are overrated
Collection state: OTD The Cheat, Tofu60 v1, Hal.6
« Reply #6192 on: Sun, 24 December 2023, 05:50:31 »
HHKB is overrated absolutely  :(
Offline wjrii
« Reply #6193 on: Sun, 24 December 2023, 09:18:47 »
Now, I've never tried one, so maybe I'm completely off base, but I've always kind of struggled to figure out how a rubber dome with early tactility that makes it hard not to bottom out is fundamentally different from a sheet of rubber domes that actuate upon bottoming out.  But then, I'm Team Clicky, so maybe my perspective is niche within niche.
Offline VimLover
« Reply #6194 on: Sun, 24 December 2023, 11:18:14 »
HHKB quality is amazing, and as a corollary unpopular opinion, HHKB is a leader in innovation with studio. So many 500+ dollar custom jobs out there that are just aluminum squares with the same bland layouts, HHKB actually out here trying new stuff and push the envelope.
Offline b21
« Reply #6195 on: Fri, 29 December 2023, 19:51:28 »
If you lube your switches with 205g0, you are muting and removing their sound profile, different linears will sound the same after. 105 on the railing is all that's needed.
Offline Rhienfo
  • GOTHETIGES
« Reply #6196 on: Sat, 30 December 2023, 01:09:10 »
I've tried a hhkb and it's pretty good, I don't see what you mean by inconsistency, and yeah it's a plastic case but it's pretty durable.
Vintage blacks aren't overrated but there are misconceptions about why they are so good. Good vintage blacks are good because they are broken in a lot from years of use, there are different molds and they are the first tooling but the break in is the biggest factor in why they are so smooth. That's why NOS vintage blacks are not worth your money, they are basically just slightly better hyperglides. Although a lot of this is based on batch variance.
Yeah 205 makes switches so sluggish, I have lubed 2 batches of switches with 205 and one is alright feeling and sounding (a batch of tangerines) and my batch of full milky switches is so sluggish, even the best switches in that batch are still kinda sluggish (I'm pretty bad at lubing with 205 so it might be a skill issue), they also sounded too muted as well.
3204 or dry based lubes like ro59 or ptfe powder are much better for switches.
Offline Rob27shred
« Reply #6197 on: Sat, 30 December 2023, 07:55:19 »
Sounds like you're overlubing with 205g0 TBH. That is the lube I use exclusively & have been doing so with all my linears for quite a few years now. They all still retain their sound differences IME, they are just a bit quieter than they are stock when using 205g0.
Offline argentstonecutter
  • Greetings, programs!
« Reply #6198 on: Mon, 01 January 2024, 16:02:57 »
1. 68 keys aren't enough. 84 keys are too many. I need all of DEL/HOME/PGUP/PGDN/END as separate keys, but the only key I use in the FK row is escape.
2. Outemu makes some damned good switches, and Gateron are boring.
3. A keycap set that only has "WIN" or a Microsoft logo on the OS key should be a war crime.
« Reply #6199 on: Mon, 01 January 2024, 16:09:23 »
1. I cannot stand 60% boards either, I don't think they look attractive what so ever and although using a HHKB was an enjoyable experience, I couldn't ever use it as my daily driver.
My reaction to 60% boards is to get flashbacks to 1980 and the adm3a and bit-encoded key layout and using Shift-RUB and Control-HJKL and growing wrist pain from the lousy mechanism. When the HHKB came out I was kind of excited and bought one sight unseen. It was a mistake.
