Author Topic: Looking for a 60% ('ish) tenkeyless keyboard  (Read 2669 times)
Offline warflesj
« on: Wed, 12 November 2014, 06:47:32 »
-removed-
« Last Edit: Wed, 12 January 2022, 19:14:50 by warflesj »
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
Re: Looking for a 60% ('ish) tenkeyless keyboard
« Reply #1 on: Wed, 12 November 2014, 06:51:41 »
Well, 60% is one size, tenkeyless is another. Probably the most popular non-backlight 60% board is one of the pokers (poker,2,X) which is easily programmable. The V60 mini and the KBT Pure are good backlight options. I'm not sure if you want a totally 60% or tenkeyless form factor, the Leopold FC660 is sort of in between, like a 60% but with a short right shift, arrow keys, and delete/insert
Offline Oobly
« Reply #2 on: Thu, 13 November 2014, 13:37:03 »
The Leopold FC660 is a great "almost 60%" layout. It includes dedicated arrow keys and is only a tiny bit bigger than a Poker II. If you want programmability, though, there aren't too many choices. In order of programmability from least to most you have Ducky Mini, Poker II or a custom (GH60, GON NerD60 or similar). The Ducky Mini has a programmable Fn layer, Poker II is fully programmable, but limited in terms of where you can position the Fn and Pn keys, GH60 and GON boards are completely programmable, you can set any character or function to any keyswitch.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline tutuling
« Reply #3 on: Thu, 13 November 2014, 14:55:02 »
I agree the fc660 option would be great if you needed the standard cluster arrow keys on the right
Offline FrostyToast
  • Litshoard
« Reply #4 on: Thu, 13 November 2014, 15:00:23 »
Have you looked into 75% keyboards like the kbt race and the noppoo chocolate mini?
I personally hate the look if them, but they might be right up your alley.
Quote from: elton5354
Offline warflesj
« Reply #5 on: Fri, 14 November 2014, 02:55:16 »
-removed-
« Last Edit: Wed, 12 January 2022, 19:15:19 by warflesj »
Offline ArchieTect
« Reply #6 on: Sun, 16 November 2014, 00:19:36 »
edit, need to read closer
« Last Edit: Sun, 16 November 2014, 00:22:46 by ArchieTect »
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #7 on: Sun, 16 November 2014, 00:22:40 »
Thanks for the answers.
I'm open to both tenkeyless and 60% (thought they were the same  :D), just depends on if it's a good choice. Would still like to have the FN row but that's not really an issue.
Will look into the mentioned boards  :thumb:!
Well if you want a dedicated F row then 75% or TKL would be for you.
Offline dashing_girlboy
« Reply #8 on: Sun, 16 November 2014, 01:21:16 »
Maybe a 65% custom from http://www.gonskeyboardworks.com might interest you.
Offline warflesj
« Reply #9 on: Fri, 21 November 2014, 08:00:14 »
-removed-
« Last Edit: Wed, 12 January 2022, 19:15:36 by warflesj »
Offline ynrozturk
« Reply #10 on: Fri, 21 November 2014, 08:10:43 »
Poker II's are on Massdrop right now FYI.
IBM Model F | IMB Model M | Poker II MX Brown | Poker II MX Clear | Filco TKL MX Brown | Bastardized Razer Blackwidow TE MX Blue | Logitech G602 |  Cyborg R.A.T. 7 | | Logitech MX518 | Icemat  | Artisan Hien
