Author Topic: Artisan/novelty Keycaps that fit SA profile Esc row?  (Read 4037 times)
Offline PunksDead
  • hspernks
  • keyboard poser
« on: Tue, 18 November 2014, 02:30:43 »
Random question and mods feel free to move this to the required thread,
Looking around at all the different artisan/novelty caps available but its hard to denote their profile compared with the heights of different keysets. Brocaps zombros looks to be the perfect height, is there any other artisan caps that fit a taller SA profile?
Thanks
Re: Artisan/novelty Keycaps that fit SA profile Esc row?
« Reply #1 on: Tue, 18 November 2014, 15:16:13 »
I mean, they'll all fit MX.
None of them are expressly tall, you'll just have to deal.
Offline PunksDead
  • hspernks
  • keyboard poser
« Reply #2 on: Tue, 18 November 2014, 18:09:43 »
Why even comment?
« Reply #3 on: Tue, 18 November 2014, 18:13:56 »
Thanks
I made a "chode cap" once, but it never hit the market :(
« Reply #4 on: Tue, 18 November 2014, 18:22:28 »
Why even comment?
Because sometimes the answer is no?
Offline FrostyToast
  • Litshoard
« Reply #5 on: Tue, 18 November 2014, 18:46:02 »
I am thinking that Nubbinator's heart keycap might work.
Definitely as tall, if not taller than SA itself, no idea if it will look alright beside it though.
Quote from: elton5354
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #6 on: Tue, 18 November 2014, 18:48:39 »
Zombros are near the right height, certainly the right thickness and width
Offline Oobly
« Reply #7 on: Thu, 20 November 2014, 01:13:12 »
Cinn Iron Man may suit SA profile, too. The base sits higher than the bottom of most MX caps, so it's relatively tall compared to most profiles.
Then again, most artisan caps are not made to suit a particular profile, some are taller, some are shorter, but very few actually match the height of any particular profile.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline PunksDead
  • hspernks
  • keyboard poser
« Reply #8 on: Thu, 20 November 2014, 02:19:10 »
Thanks for the info guys much appreciated,
Basically i have come to terms with SA being the perfect profile for my tastes. I enjoy a slight raised Esc rather than set low so this has become a little difficult to find. Thanks for your input guys i need to do some more stalking
<3
Offline PunksDead
  • hspernks
  • keyboard poser
« Reply #9 on: Thu, 20 November 2014, 02:20:12 »
« Last Edit: Wed, 16 December 2015, 10:58:10 by PunksDead »
