Author Topic: Realforce 105u ps/2 not working?  (Read 2903 times)
Offline Conditioned
« on: Tue, 18 November 2014, 11:03:08 »
I have a Realforce 105u and it works fine in usb but I would -really- like to use it in the ps/2 port. I have tried it with a regular adapter ofc (making sure the adapter works with other keyboards) but no go. Does it simply not work in the ps/2, do I need a special ps/2 adapter? Anything else I'm missing?
Antec p183, I5@4.01 ghz, 6Gb Kingston Ram,1200w Corsair psu, Intel 80 gb ssd, 3TB Storage (Seagate), Asus Essence STX with AKG K701, Gigabyte 480 gtx, Dell 2048 WFP 24" + Benq xl2410t 120hz 23,6", Razer Deathadder 3g with Goliathus Control, Netgear Wnr 3500 running Tomato USB w/ 500 gb storage
Offline FrostyToast
  • Litshoard
Re: Realforce 105u ps/2 not working?
« Reply #1 on: Tue, 18 November 2014, 12:06:52 »
Ps2 is not by default enabled. You have to go into your bios and enable it there. A keyboard with ps2 should also work in the bios itself regardless of whether or not you enabled it.
Quote from: elton5354
Offline Hyde
  • White Tofu Extraordinaire
« Reply #2 on: Tue, 18 November 2014, 16:25:04 »
I'm not expert in this but I believe the keyboard need to have its own converter.
i.e.  Filco, Das Keyboard 3... etc.
Since the adaptor you slap on probably only change the connector head but doesn't actually change how the data is being output.
So you'd need a converter that actually converts the data.
« Last Edit: Tue, 18 November 2014, 16:26:58 by Hyde »
Offline BlueBär
« Reply #3 on: Wed, 19 November 2014, 04:26:56 »
Did you restart your computer? PS/2 is not plug and play and needs a restart.
Offline kaiteoki
« Reply #4 on: Wed, 19 November 2014, 05:43:21 »
Topres cant even go nkro with a ps/2 adapter. Its hardware limited.
Offline Grendel
« Reply #5 on: Wed, 19 November 2014, 12:35:25 »
Topre RF boards don't support PS/2 via a passive adapter, you would need an active USB-PS/2 converter.
- I'm game !
Offline Conditioned
« Reply #6 on: Tue, 06 January 2015, 11:34:47 »
Oh I didnt even realize there was such a thing. Thank you very much sir! And ofc all others who replied here, sure appreciate it!
