Author Topic: Anyone here who is exclusively 60% and lower?  (Read 9374 times)
Offline dante
« on: Thu, 20 November 2014, 13:51:53 »
After a couple weeks of using my KBP 60% I thought I'd change it up and go back to tenkeyless ... NOPE.
60% is oh so comfortable and gives me so much more wiggle room.  My shoulders love it!
I'm thinking of cleaning house and unloading all my other boards larger than 60% (still undecided on 75%.)
Am I alone?
« Last Edit: Thu, 20 November 2014, 13:53:36 by dante »
Offline user 18
Re: Anyone here who is exclusively 60% and lower?
« Reply #1 on: Thu, 20 November 2014, 13:54:13 »
I can think of a lot of users who prefer to use a 60%, or a 60% with a separate numpad.
I'm heading towards this path, at least to see if I like it. Just need to find the time to actually build my 60% first.
Avatar by ashdenej
Offline osi
« Reply #2 on: Thu, 20 November 2014, 13:56:13 »
Unless you need dedicated F keys for gaming purposes, 60% is all you need!!!
Offline inanis
  • Truly Literally The Cloud
    • SEALWoodworking
« Reply #3 on: Thu, 20 November 2014, 14:01:52 »
I use a 60% as my daily driver. I don't see any need to go back to full size. I do like to type on my SSK from time to time though.
Offline geniekid
« Reply #4 on: Thu, 20 November 2014, 14:22:08 »
My experience is that 60% is adequate for general use and gaming.  Even on my TKLs and full-sizes where I have dedicated navigation keys I choose to navigate through a function layer because it is just more efficient in terms of how far I have to move my hand.
However, I find the lack of dedicated F keys to be noticeable when I'm coding as many IDEs make use of chords to perform functions and some chords that include F keys are very difficult to achieve if the F key is buried in a function layer (consider Ctrl+Shift+F6 for variable rename, for example).  Not impossible but my hand does have to contort more to hit 4 keys instead of 3.
The other area where I find 60% to be inadequate is when I'm doing accounting (taxes) or design (CAD) where I need a separate numpad.
« Last Edit: Thu, 20 November 2014, 14:24:06 by geniekid »
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #5 on: Thu, 20 November 2014, 14:25:31 »
I don't ever use the numpad, and the function row not very frequently, but I still use all the different sizes. It may have something to do with the way that I type, but I never use my pinkies for actual typing, just hitting shift and enter, so my pinkies are almost resting outside the mods sometimes, and my thumbs feel comfortable resting on the bezel below the spacebar when typing, so I use fullsize or TKL primarily for typing and 60% for gaming and casual use
Offline Jixr
« Reply #6 on: Thu, 20 November 2014, 15:15:55 »
The other area where I find 60% to be inadequate is when I'm doing design (CAD) where I need a separate numpad.
I use a pokerX for my DD at work and never have any problem doing cad work. num pad is nice, but Still prefer to work on a 60% both at home and the office.
Offline evolveS
  • ಠ_ಠ
« Reply #7 on: Thu, 20 November 2014, 15:40:41 »
60% 100% of the time bb
If you miss the fn row but don't need a full TKL, Margo and GON have come up with a solution.
"money comes and goes, but doubleshots are forever"
-a petty thief
Offline azhdar
  • Praise the AZERTY god
« Reply #8 on: Thu, 20 November 2014, 15:48:09 »
Using 60% 90% of the time for a while now , only time I go TKL is when I play PlanetSide2 (easier to plug a keyboard than rebind) .
And when I'm at work because it's a too old school environment to consider bringing in a "weird keyboard".
Azerty Propagandiste
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #9 on: Thu, 20 November 2014, 15:49:57 »
I haven't used a tkl in over a year.  I honestly can't remember the last tkl I used as a daily driver, it's been that long.
Offline Booper
    • omniclectic.com
« Reply #10 on: Thu, 20 November 2014, 15:57:42 »
60% all the way!
I never liked big keyboards and actually used the small Mac board for a while. I liked how compact it was and never could fully switch to a mechanical until I used a 60%
I sometimes miss the arrow keys as I use them often for work, but it only takes a half a second for my brain to register it needs to use the FN layer. Also works perfectly fine for the games I play.
boop!
Offline HPE1000
  • Keycap Paparazzo
« Reply #11 on: Thu, 20 November 2014, 16:03:37 »
60% is just about perfect for daily tasks. I don't have any strong feelings about 60% vs TKL though, as long as it isn't full size it's okay with me.
Offline johndavis33
« Reply #12 on: Thu, 20 November 2014, 16:09:44 »
I was surprised by just how little using a 60% affected me. Maybe it's because I switch keyboards so often, but I'll go between my hhkb and my giant model m and I'll be unaffected by the lose of space/extra keys.
HAVE AND WILL KEEP: HHKB - Printed white | Ducky Banana edition - Whites | Model M13 | Unidentified Goodwill keyboard - Simplified black ALPS
TOO BE SOLD: TG3 BL82 - Clears | Wheelwrite 5 - Buckling Springs typewriter
SOLD: Rosewill RK9000 - Blacks | QFR - Blues | Ducky G2 Pro - Greens |
IT WILL BE MINE: Northgate Omnikey - White ALPS
Offline ithinkimkorean
« Reply #13 on: Thu, 20 November 2014, 16:12:36 »
I also have a kpad on the side that I pretend to need, but never use. :))
Actually, I only use it for left and right arrow when I want to unhighlight something.
Offline azhdar
« Reply #14 on: Thu, 20 November 2014, 16:13:49 »
Every time I get away from a 60% I look for the fn layer at least for the 2-3 first times before going back to nav cluster .
« Reply #15 on: Thu, 20 November 2014, 16:35:37 »
I use a poker with a numpad on the left side but the numpad is only there because I thing they're fun to use.
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #16 on: Thu, 20 November 2014, 16:54:29 »
GH60 all the time, except if I 'need' to play some game that requires arrows, function or something else frequently and doesn't provide ability to remap... then I plug in my G80-3600.
Offline Pemdas
« Reply #17 on: Thu, 20 November 2014, 17:15:04 »
98% of my keyboard use is my poker 2 and fc660c. Dedicated function layer/numpad is a waste for me nowadays, especially with a tiny workspace. 60% for life  :thumb:
Offline heedpantsnow
  • Old enough to know better
« Reply #18 on: Thu, 20 November 2014, 17:41:05 »
I have 3 Pokers and nothing else. Love 60%!
I'm back.
Offline vivalarevolución
« Reply #19 on: Thu, 20 November 2014, 19:21:56 »
My breaking point is the arrow keys.  I like my dedicated arrow keys.  Maybe I need a better FN key location.
Offline bueller
  • MX baller
  • Church of the Ergo Clear
« Reply #20 on: Thu, 20 November 2014, 19:26:38 »
60% all the way. My TKL has been bare of caps for over a month and will probably stay that way for quite a while. Thinking of doing a major cull soon actually, just going to wait till my Nerd60 is built.
« Reply #21 on: Thu, 20 November 2014, 19:40:09 »
Have you used one with an arrow lock mode like the Poker X?  When I'm going to do a lot of arrowing I just enable that and away I go. I use it in Lightroom and Excel mostly.
I'm back.
Offline SavvyBird
  • Savvy Caps
« Reply #22 on: Thu, 20 November 2014, 19:56:35 »
60%=100%
nothing better than 60  ;D
hi
Offline Sygaldry
  • Edema Ruh
« Reply #23 on: Thu, 20 November 2014, 20:48:11 »
I've been exclusively 60% for a while now but have been interested in the 75% layout for a while a la MX Mini.
The Duck Octagon will likely be my first 75% keyboard.
(to this day I have never tried a TKL and reckon that I never will)
« Last Edit: Thu, 20 November 2014, 20:52:50 by Sygaldry »
null
Offline ideus
  • Björkö.
« Reply #24 on: Thu, 20 November 2014, 21:25:47 »
I was in the understanding that you were a classic keyboards user. Interesting to learn that you are also into the 60 fever. Cool! I just cannot use anything above 66. Only reason I do 66 are the arrows, for those cases where I need them heavily like editing a large spreadsheet.
« Reply #25 on: Fri, 21 November 2014, 00:06:06 »
I've been a 60%er since the Poker X originally came out, pretty much exclusively. I just collect vintage stuff, don't actually use it really.
Offline pichu23
  • ୧༼ಠ益ಠ༽୨ FITE ME
  • ʕ ͡·ᴥ ͡· ʔ
« Reply #26 on: Fri, 21 November 2014, 00:07:50 »
60% all the way ! :)
I have 2 60% board, soon to be 3 :D
Offline Oobly
« Reply #27 on: Fri, 21 November 2014, 01:28:15 »
I use 60% at work, 46% at home :) Until I build my next prototype. Then I'll be 46% exclusively, although I may pull out my 60% now and then for the sake of nostalgia or taking pictures of keycap sets.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline RoflCopter4
« Reply #28 on: Fri, 21 November 2014, 02:27:55 »
I can't deal with anything less than a full board. I use Wolfram mathematica all the time and I enjoy having the numpad there for things. I especially like having a num enter key. I'm too lazy to push shift-enter to get the current line to compute. Pushing num enter is slightly easier.
Bah. Humbug.
Acer KB-101A with Blue Alps | HHKB Pro 2 | '85 122 Key IBM Model F | '86 1390131 "Silver Label" Model M | AEK M0115 with Orange Alps | Focus FK-2001 White Alps | Chicony 5181 with SMK "Monterey Blue" Switches | Dell AT101W | Unicomp "Ultra Classic" | Razer Blackwidow 2013
Offline StylinGreymon
  • Keyboard Hipstar
« Reply #29 on: Fri, 21 November 2014, 02:33:37 »
Within a few weeks of using my Poker II, I couldn't imagine even going back to my Filco TKL, much less a full-sized KB.
It's just too comfortable.
If today had been a hippo, then you'd really have to worry about tomorrow.
Offline beefjerky
« Reply #30 on: Fri, 21 November 2014, 03:52:46 »
Why not a 65% keyboard like the FC660M? Or a Filco Minila Air.
Offline Skuloth
« Reply #31 on: Fri, 21 November 2014, 08:21:33 »
Because caps lock + wasd = arrows is so much nicer than dedicated arrows. Also standard keycap sizes. I love my poker :D
Planck w/ Zealios
Offline Hypersphere
« Reply #32 on: Fri, 21 November 2014, 08:52:20 »
I go back and forth. While I much prefer the 60% form factor and layout of my HHKB Pro 2, I also enjoy the solid sound and feel of my RF 87u 55g or my IBM XT. However, when I am using these larger boards, I realize that I hardly ever use the F-row or navigation keys. In fact, I remap my larger boards to a HHKB configuration, and even when I am using a board that has arrow keys, I usually use Fn + the HHKB cursor diamond.
Offline beefjerky
« Reply #33 on: Fri, 21 November 2014, 08:54:28 »
I agree with you but for the person I quoted, it could be a solution.
Offline Telephasic
« Reply #34 on: Fri, 21 November 2014, 09:09:55 »
Only regret is buying a full sized board two months before scoring a Poker II.
Offline usno_oj
« Reply #35 on: Fri, 21 November 2014, 12:11:19 »
I would love keeping my Poker II I recently received from massdrop, but I haven't realized how often I used the function keys as well as arrow keys.
I guess I'll have to resort to a TKL or a 75%. Only thing bad about a 75% is that it's going to be hard to find key sets that fit.  :(
Offline Skuloth
« Reply #36 on: Fri, 21 November 2014, 12:12:47 »
Swap your caps to a function key and give it a shot before giving up. I thought I would have a difficult time transitioning since I use the arrows a lot when coding, but having access to arrows very close to the homerow without moving my hands is amazing. All my keyboards form now on will have wasd + caps = arrows.
Planck w/ Zealios
Offline eth0s
  • Peace & Love
« Reply #37 on: Fri, 21 November 2014, 12:16:06 »
I exclusively use my HHKB Pro 2 Type-S every day, all day.  But, I also use my RealForce Numpad almost every day too.  So I dunno what I am.  60% + 10%?
Offline frosty
  • jukebox hero
« Reply #38 on: Fri, 21 November 2014, 12:35:02 »
NO U R NT
Offline mason
  • have fun with her, ryan
« Reply #39 on: Fri, 21 November 2014, 17:53:52 »
The only keyboard I have right now is the Poker II and the only time that I only need the function keys to change the song or volume. I love how compact it is  :)
« Reply #40 on: Fri, 21 November 2014, 18:55:18 »
I was 60% only for awhile. Then moved to realforce 87u and realized my endgame is realforce 104ubdk. But still love my 60% forsure.
Offline Flyersfan1
  • Hi!
« Reply #41 on: Fri, 21 November 2014, 19:08:41 »
Realforce 104UB-DK is my favorite keyboard too! I would buy another one in a second if I could find one.  60% is fun for me to go every once in a while, but I always end up coming back to my realforce pretty quickly.
Quote from: Photekq
« Reply #42 on: Fri, 21 November 2014, 19:35:27 »
Awesome! Same with TheBinary, its his favorite too. :)
The only one I've ever seen lately is $350 on eBay.
60% is an awesome board for collecting though! Love my 60% for collecting.
« Reply #43 on: Fri, 21 November 2014, 20:48:39 »
you could say that
Offline Geroximo
« Reply #44 on: Sat, 22 November 2014, 06:52:53 »
Since I have the Poker II 60% , TKL feels HUGE.
« Reply #45 on: Sat, 22 November 2014, 10:00:48 »
Not really.  I may integrate that into my one 60%, the Kishsaver.  I just prefer to have easy access to those keys because I use them a lot, and having to hold down an FN key is annoying.  I will play around with some options.
Honestly, my most favored keyboards are basically a 60%, with the extra column on the right and the backspace key in the place of the pipe/backslash.  So a 65%?  I like the slight addition of layout flexibility.
Offline dante
« Reply #46 on: Sat, 22 November 2014, 10:15:17 »
For those who own the Poker 2 : Do you find that the FN key is too far to the right?  Which finger do you use to strike it?
Offline yasuo
  • spanengan puyeng newbie
« Reply #47 on: Sat, 22 November 2014, 10:18:34 »
i dont like 60% cuz arrow keys not make sense like pokerx ctrl fn win shift or wasd+fn
but spacefn may solved this :D
Logitech MK220 Colemak DH
Offline Skuloth
« Reply #48 on: Sat, 22 November 2014, 11:00:11 »
I use my left pinky to hit fn on my poker. I have caps lock swapped to an fn key.
Planck w/ Zealios
Offline KeyZero
  • Lovin' clear keys
« Reply #49 on: Sat, 22 November 2014, 11:25:50 »
I've been use to my 60%(also KBP V60 but clear) and I've been loving it since I don't need more keys. Being that I'm usualy on a terminal somewhere, the extra FN row isn't that useful and having Pageup/Pagdown be two keys away is damn nice.
KBV60 (Clear) User
