Author Topic: HashKey: a dedicated 1-key keyboard for the hashtag  (Read 3392 times)
Offline Belfong
« on: Tue, 25 November 2014, 21:02:53 »
What a strange idea:
https://www.kickstarter.com/projects/1000610379/hashkey-a-dedicated-1-key-keyboard-for-the-hashtag
Will anyone buy into this? Seriously?
If it were wireless and uses mechanical switch, then I might consider. It will be like a key chain as well as a bluetooth clickable key!
Re: HashKey: a dedicated 1-key keyboard for the hashtag
« Reply #1 on: Tue, 25 November 2014, 21:06:09 »
This project will only be funded if at least £15,000 is pledged by Tue, Dec 23 2014 4:00 AM AEDT.
Really?!?!
And it's not even a mechanical switch!
I would suspect that quite a few GH members could design something similar with, say, a Teensy and a slightly larger key chain base in their spare time.
Offline Belfong
« Reply #2 on: Tue, 25 November 2014, 21:09:39 »
And it's 17 pound sterling and 7 pound sterling for WW shipping!
« Reply #3 on: Tue, 25 November 2014, 22:57:17 »
apple-looking product, check.
social media aimed, check.
has strong burly man doing VO, check.
gimmicky product, check.
Thinkgeek are you listening?
Offline Coreda
« Reply #4 on: Tue, 25 November 2014, 23:07:59 »
Because pressing Shift+3 is so hard... lol
It's almost inexplicable how various silly KS ideas end up being funded, but I think some see it as a low investment for a quick laugh. Look at that potato salad campaign, raised something like 15k. At least in that case the money was used to fund an annual potato festival.
Sounds like a regular British dude tbh
Offline Data
« Reply #5 on: Wed, 26 November 2014, 12:08:23 »
Disgusting.
Offline 0100010
  • Not Sure
« Reply #6 on: Wed, 26 November 2014, 12:24:45 »
Failed up front simply because they refer to it as a hashtag.
Offline osi
« Reply #7 on: Wed, 26 November 2014, 12:31:55 »
Put this on reddit mech keyboards. They'll love it
« Reply #8 on: Wed, 26 November 2014, 12:33:57 »
Put this on reddit mech keyboards. Ripster'll love it
FTFY
Offline ConscienceDrop
  • a-are these pbt?
« Reply #9 on: Wed, 26 November 2014, 12:36:33 »
not even mechanical
pig disgusting
Offline JPG
  • Model F is my new passion!
« Reply #10 on: Wed, 26 November 2014, 13:11:44 »
Hey my keyboard is revolutionary! When I hit the key to the left of 1, it does a hashtag with only 1 key! That's right.
Here's an example: #
One key hit, you see!
Yep, that the strength of my keyboard. And it's also a model F, so I can destroy any stoooopid hashkey I see with one big smack of my keyboard.
And no hand needs to be lifted, so it's a more ergonomic version of the hashkey too. It also has all the other keys that you need and it does not look like a mac thing, so it's even better!
So support the new revolution and buy a model F! Once you try a model F, you can't go back!
« Reply #11 on: Wed, 26 November 2014, 15:05:04 »
Exactly!
Everyone knows it's really an octothorp.
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #12 on: Thu, 27 November 2014, 17:01:01 »
Pound key, it's a pound key and IT'S RIGHT THERE.  IT'S SO EASY.
« Reply #13 on: Thu, 27 November 2014, 20:41:40 »
I've often wondered - pound as in weight, or pound as in UK currency?
Offline lightsout714
« Reply #14 on: Thu, 27 November 2014, 21:03:24 »
I just puked.
« Reply #15 on: Thu, 27 November 2014, 22:49:35 »
I just puked.
Hopefully not on your keyboard :eek:
