Author Topic: This is my design for a custom 60% board '0x3F' - thoughts?  (Read 7417 times)
Offline Dihedral
  • Mostly Harmless
« on: Fri, 28 November 2014, 08:40:30 »
0x3F
Edit: Now with function layer -
Function Layer
This is a project I have to make a custom board. It's fully symmetrical, and is like an ANSI board with some modifications to make it Brit friendly.
Inb4 non standard keycaps boooo - this is probably only going to be a one off.
http://tinyurl.com/dihedralcustom
It has an alt layer, fn layer and alt-gr (fn + alt) layer for extra functions. The specifics of these are on my desktop in a spreadsheet (im on mobile) if there is interest I should be able to get it posted in a few days.
Edit:
Version 2 with discrete insert key - delete is now alt + backspace
Edit again:
Version 3
Switched esc and caps to make it more normal.
« Last Edit: Sun, 30 November 2014, 07:06:58 by Dihedral »
Offline azhdar
  • Praise the AZERTY god
Re: This is my design for a custom 60% board. thoughts?
« Reply #1 on: Fri, 28 November 2014, 08:48:17 »
Interesting .
You don't have that much non standard key-sizing .
What are you trying to achieve with this layout ?
Azerty Propagandiste
Offline Dihedral
  • Mostly Harmless
« Reply #2 on: Fri, 28 November 2014, 08:55:23 »
Interesting .
Well I love 60% boards but I need my arrow keys. I dont use right mods so it stemmed from there.
Offline Signature
  • master of puppers
  • * Marketplace Moderator
  • snoozing
« Reply #3 on: Fri, 28 November 2014, 08:58:13 »
Interesting .
you could use the poker x layout where the right mods can work as the arrow keys.
Offline Dihedral
  • Mostly Harmless
« Reply #4 on: Fri, 28 November 2014, 09:04:12 »
Interesting .
I prefer discrete arrow keys and I like the look of this layout.
Offline ynrozturk
« Reply #5 on: Fri, 28 November 2014, 09:29:29 »
Why is ESC where it is.
IBM Model F | IMB Model M | Poker II MX Brown | Poker II MX Clear | Filco TKL MX Brown | Bastardized Razer Blackwidow TE MX Blue | Logitech G602 |  Cyborg R.A.T. 7 | | Logitech MX518 | Icemat  | Artisan Hien
Offline Dihedral
  • Mostly Harmless
« Reply #6 on: Fri, 28 November 2014, 09:36:05 »
Adding a link to V2 now, with some switched around keys.
Offline Data
« Reply #7 on: Fri, 28 November 2014, 11:18:35 »
"Escape" tends to be in the far corner for very good reasons.  Namely, it's the default keyboard command for Cancel in Windows.  You'd only need to hit it accidentally while typing once or twice before you developed an urgent need to move it.  I'd especially never put it anywhere near the home row.
« Reply #8 on: Fri, 28 November 2014, 11:32:20 »
uhhh
what are you smoking to take esc out of that corner
that's a recipe for disaster if i've ever seen one
and what is backspace doing above left shift
this layout makes the ergo freak in me die
and your arrow keys make no sense, since VIM only works with HJKL anyway
Offline Dihedral
  • Mostly Harmless
« Reply #9 on: Fri, 28 November 2014, 11:35:57 »
uhhh
I think you're right about the escape key. But I want the backspace to be accessible so the home row seems to be a logical place. It feels right when I've tested it at least.
Edit: removed accidental quote
« Last Edit: Fri, 28 November 2014, 12:11:28 by Dihedral »
Offline whentheclouds
« Reply #10 on: Fri, 28 November 2014, 11:41:02 »
i'm not as put off by the ESC as the 4 vertical arrow keys, just doesn't feel right. you can make your layout however you see fit of course, but i wouldn't dare to use this layout if i was given the board for free :D
Offline Dihedral
  • Mostly Harmless
« Reply #11 on: Fri, 28 November 2014, 12:06:41 »
I think the arrows will be fine with a bit of getting used to. When ive tested it,  it actually feels more comfortable than normal arrows! Personally i don't like the look of the FC660 type arrows so this seemed a better option.
Offline engicoder
« Reply #12 on: Fri, 28 November 2014, 12:33:19 »
Before DEC introduce the inverted T cluster on the LK-201, many boards had arrow laid out this way...I can definitely work, once your used to.
The layout looks nice (very symmetric), but I'm with everyone else on the ESC placement....then again, maybe you use ESC often  ;D Version 3 makes a lot more sense.
I'm not a fan of CapsLock in general. Maybe ditch the Caps Lock all together and have custom firmware programmed to use shift double tap for Caps Lock, replace it with Fn and up arrow. Then this layout could work nicely and you'd have the inverted T cluster.
Like this:
82827-0
« Last Edit: Fri, 28 November 2014, 12:46:40 by engicoder »
« Reply #13 on: Fri, 28 November 2014, 13:14:29 »
Like this:
THIS
THIS IS SO MUCH BETTER
Offline Altis
« Reply #14 on: Fri, 28 November 2014, 13:16:05 »
I like the arrow ordering. Left-Up-down-right, unlike Vim which switches the down-up. It makes more sense your way because both left and up move the cursor in the backward direction, and down-right advance the cursor in the document. Thus the left two arrows move back, right two move forwards. So much more intuitive.
I never understood that about the VIM arrows. I think they were chosen arbitrarily.
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #15 on: Fri, 28 November 2014, 13:30:44 »
I would go with .25 stagger instead of .5 stagger to achieve more sane keycap sizes. This way you also get the added bonus of getting rid of stabilizers except on spacebar.
http://www.keyboard-layout-editor.com/#/layouts/a90aeb346d34935636075e4a8bab8321
4x space is a bit odd, but it could easily be changed to a 6x.
« Last Edit: Fri, 28 November 2014, 15:57:36 by IvanIvanovich »
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #16 on: Fri, 28 November 2014, 13:46:16 »
GON and CTRLALT it may have been were working on a board somewhat like this one with dedicated arrow keys on the bottom, can't seem to find it, forget what it was called.
Offline zshang
« Reply #17 on: Fri, 28 November 2014, 15:48:46 »
'Cuz the keyboard of the old computer (ADAM-3A) which VI was developed on has no discrete arrow keys and the arrow keys were just H, J, K, L
http://www.catonmat.net/images/why-vim-uses-hjkl/adm-3a-hjkl-keyboard.jpg
Offline Dihedral
  • Mostly Harmless
« Reply #18 on: Fri, 28 November 2014, 16:06:29 »
Like this:
Nice... but you've lost the symmetry!  That's an important part of the board.
Offline Dihedral
  • Mostly Harmless
« Reply #19 on: Fri, 28 November 2014, 16:09:04 »
Unless i screwed up badly that should be a 6.25x standard spacebar.
Edit: I checked it's a normal 6.25 bar.
« Last Edit: Fri, 28 November 2014, 16:12:09 by Dihedral »
« Reply #20 on: Fri, 28 November 2014, 16:21:06 »
I was referring to my own change suggestions. Lately I'm of the opinion that spacebars waste too much space where additional keys would be more useful.
Offline Dihedral
  • Mostly Harmless
« Reply #21 on: Fri, 28 November 2014, 16:23:37 »
I was thinking about that but boards with small spacebars just look a bit wrong imo. Also, I will use both thumbs for space, and split spacebars also look wrong so classic bars seem the way to go.
Offline engicoder
« Reply #22 on: Fri, 28 November 2014, 19:23:36 »
Like this:
I hear you. Your design was nice and balanced, and the side by side arrows work.
Offline Dihedral
  • Mostly Harmless
« Reply #23 on: Sat, 29 November 2014, 01:40:36 »
Unless anyone has any last minute suggestions, V3 seems to be the design yo go for.
Offline dusan
« Reply #24 on: Sat, 29 November 2014, 02:08:46 »
I don't think it is symmetrical, with respect to standard touch typing technique.
And I see no improvements in comfort compared to the normal character layout. To the contrary, due to the 0.5u stagger of the QWERTY row, at least seven keys (WERYIOP) will be more difficult. That's my guess from experiences with the matrix (ortho-linear) layout versus normally staggered layout.
Topre Type Heaven | Filco Majestouch w/MX blue | CM Storm QF w/MX green | Asus Echelon w/MX black | Razer Tournament 2014 w/Razer green, Keychron K1 w/Gateron LP red | TypeMatrix 2030 | custom 6x16 ortho w/MX black | Atreus 44 w/Kailh box white & Gateron Pro yellow.
Offline Dihedral
  • Mostly Harmless
« Reply #25 on: Sat, 29 November 2014, 02:24:24 »
When ive tested the 0.5 stagger it feels fine, as natural as .25
Offline dusan
« Reply #26 on: Sat, 29 November 2014, 02:58:58 »
How did you tested it?
Offline Dihedral
  • Mostly Harmless
« Reply #27 on: Sat, 29 November 2014, 03:51:16 »
Drew out layout on paper and pretended to type. No keys felt hard to reach or hit accurately.
Offline jacobolus
« Reply #28 on: Sat, 29 November 2014, 04:24:18 »
Be careful with the non-standard row stagger. That **** is just as hard to learn as any non-standard (matrix, symmetric stagger, column stagger, sculpted with height differences between columns, or whatever) board, except with fewer advantages. Switching back and forth between your proposed keyboard here and a standard keyboard is going to cause lots of annoying mistakes I suspect.
I have a couple of keyboards with non-standard stagger (1/4u each between rows) but an otherwise standard layout, and I find it really frustrating to type on them. (But I’ve never tried for any extended amount of time, so maybe you can easily get used to switching back and forth. YMMV.)
Offline Daniel Beardsmore
  • RIP
    • Boring twaddle
« Reply #29 on: Sat, 29 November 2014, 06:54:52 »
Symmetry is an awkward one — is it worth it?
For example, you can't get the colour symmetrical unless you violate the basic colour design principles or rethink at least one key:
http://www.keyboard-layout-editor.com/#/layouts/49f0407972c859c8c37ba535555892d5
Bore Awards
Offline jacobolus
« Reply #30 on: Sat, 29 November 2014, 07:25:21 »
Which principles are those?
Offline Oobly
« Reply #31 on: Sat, 29 November 2014, 07:27:51 »
Personally, I don't see any real benefit of this over something like the FC660M for instance. The different stagger and positioning of the modifiers would take a lot of getting used to not to mention the inline arrow keys. FC660M keeps familiar positions and shapes of zones, so it's immediately usable. And if you get an extra left shift key you can fit almost any standard keycap set on it. Remapping the edit keys to home and end is the only improvement I would make to the FC layout.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
  • RIP
    • Boring twaddle
« Reply #32 on: Sat, 29 November 2014, 07:28:38 »
The rules for which keys are allowed to be an alternative base colour. Not everyone follows them — my OK-100M for example has one of the two (!!) backslash keys in dark beige instead of cream. In the case of the posted layout, I had to leave backtick/tilde in grey instead of blue, as you can see, as that's an entry key instead of a control or modifier key.
Space is typically the primary base colour, but the space cadet design deftly uses blue for space, which works well, but I just can't accept the idea of backtick being blue!
Bore Awards
Offline jacobolus
« Reply #33 on: Sat, 29 November 2014, 07:41:15 »
These “rules”, up through 1990, were basically: try to follow whatever colors the most recent IBM keyboard used. (Just like in the last 15 years, the “rules” for everything about computer/electronics design is: make your product look like whatever Apple’s product looked like a few years ago.)
Just like everything else about keyboard design: most of the ideas were totally unambitious and boring.
I say toss these color rules out.
« Last Edit: Sat, 29 November 2014, 07:43:35 by jacobolus »
Offline Dihedral
  • Mostly Harmless
« Reply #34 on: Sat, 29 November 2014, 10:35:45 »
The stagger doesn't seem an issue for me. But I will consider your points.
Offline Dihedral
  • Mostly Harmless
« Reply #35 on: Sat, 29 November 2014, 10:38:21 »
The improvements in the layout should improve my speed and I don't like the look of the FC660.
Offline dusan
« Reply #36 on: Sat, 29 November 2014, 11:34:31 »
Paper can help to quickly discard some wrong designs but can hardly help to confirm a correct design. Some  disadvantages in speed/accuracy can show up only under hard testing.
I couldn't notice any difference between the standard and the matrix layout -- I can touch type at 40 - 50 wpm on both. Only when I decided to improve my typing to 80 wpm I realized the disadvantages of the standard layout -- ZXCVB and even R and YP are harder to reach.
Offline Dihedral
  • Mostly Harmless
« Reply #37 on: Sat, 29 November 2014, 11:37:41 »
Fair point. Any suggestions for how to test?
Offline Dihedral
  • Mostly Harmless
Re: This is my design for a custom 60% board '0x3F' - thoughts?
« Reply #38 on: Sun, 30 November 2014, 07:04:04 »
Now with Function Layers in OP!
