Author Topic: GMK 85|15 groupbuy (CANCELLED)  (Read 205980 times)
Re: GMK 85|15 groupbuy (orders open)
« Reply #200 on: Sat, 27 December 2014, 00:37:46 »
Anything that make the MOQ will be made. Though I will be severely disappointed if all that is are spacebars. I may extend out a couple more week, maybe it will help since so close to holidays.
I definitely think that would be helpful a few more weeks won't hurt anything.
A few more weeks and I'll be able to afford this set. I need time to work at the end of my winter break.
Offline renne
« Reply #201 on: Sat, 27 December 2014, 00:46:40 »
I understand that u always wanna bring something different to people. but what about change the legends back to normal? since the inverse beige color is already "something different". and I'm pretty sure that lots of people are interested in the color, but not the legends.
Offline MOZ
  • KING OF THE NEWBIES
  • Busy making stuff
« Reply #202 on: Sat, 27 December 2014, 01:08:21 »
The main set may be splited in modifiers and alphas, and the modifier set broken down into smaller subsets so prices may be reduced.
With GMK, that never works, because then all the orders get segregated and non of the sets meet MOQ. Having one big pack has had the best luck of meeting MOQ.
Offline asgeirtj
« Reply #203 on: Sat, 27 December 2014, 09:58:29 »
Will be disappointing if we don't get MOQ, maybe we need people in here to hype this up like the GMK Dolch was hyped :P  Ivan, if this won't get MOQ, will future potential sets also include r0 and r5?
Leopold FC900 w/ 67g Purple Zealios - Silver Duck Octagon w/ 62 Purple Zealios
Offline tjweir
« Reply #204 on: Sat, 27 December 2014, 10:31:33 »
I want to believe you're in Asgeir, an amazing band.
Offline asgeirtj
« Reply #205 on: Sat, 27 December 2014, 10:38:00 »
Sorry, just my name :)
edit: you're talking about Ásgeir Trausti, the Icelandic musician?  Well he has the same name as me, we're both from Iceland :)
Offline tjweir
« Reply #206 on: Sat, 27 December 2014, 12:42:04 »
edit: you're talking about �sgeir Trausti, the Icelandic musician?  Well he has the same name as me, we're both from Iceland :)
Yep,
Offline frostylove
« Reply #207 on: Sun, 28 December 2014, 01:41:34 »
I'm just wodering why there're so many people only want a spacebar.
Suhr Custom Standard Carve Top
Manson DL-1 Matt Bellamy Signature
Marshall JVM410H + 1960A
Lovepedal Kanji Enternity
Offline bueller
  • MX baller
  • Church of the Ergo Clear
« Reply #208 on: Sun, 28 December 2014, 01:50:24 »
You'll never be able to get GMK spacebars any where else for $3 each, I bought 20 last time and still put my name down for more.
Hell I traded a couple of GMK spacebars and some winkeyless mods for a Mint Gum clack earlier this year
Offline DanielT
« Reply #209 on: Sun, 28 December 2014, 02:24:46 »
Spacebars are cool, I wasn't around for the first GB but I managed to get all the crazy colored spacebars. A crazy colored spacebar makes the keyboard way cooler.
Offline Geroximo
« Reply #210 on: Sun, 28 December 2014, 12:26:53 »
May I ask what makes GMK spacebars so special?
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #211 on: Sun, 28 December 2014, 12:47:02 »
If you have old original Cherry sets from G80/G81, the 6.25 spacebar has off center switch mount which is unusable on most other boards... the GMK made ones don't have that problem so are compatible with pretty much everything but Leopold. Plus, fun colors.
Offline madhias
  • BS TORPE
    • Madhias' Flickr
« Reply #212 on: Sun, 28 December 2014, 13:42:08 »
That's such a nice set, but it will/would be a long way until we reach the MOQ. What about extending until June 2015 for example?
« Reply #213 on: Sun, 28 December 2014, 13:45:56 »
I don't like to drag things out. If something isn't going to make it in a reasonable time frame, odds are it never will. If it's close to MOQ I would probably make a short extension, but it all depends.
Offline radio_killah
  • Chinchillin'
« Reply #214 on: Sun, 28 December 2014, 13:48:32 »
How close to MOQ do you want it to be by the deadline? Also if the main sets don't hit MOQ I will probably just order more spacebars will you allow people to edit orders for a day or two before invoicing?
Offline Yslen
« Reply #215 on: Sun, 28 December 2014, 13:55:40 »
I'll pick up a load more spacebars if the mods don't make the MOQ. To answer Geroximo, they're special because there aren't any others like them. DCS spacebars are horribly sharp, Cherry originals aren't compatible with most modern boards, OEM, DSA and SA are the wrong heights/shapes etc. I'm using DSA at the moment because it's the best I have, still kicking myself for not getting a ton of GMK spacebars last time I had the chance.
Offline Synjin
« Reply #216 on: Sun, 28 December 2014, 14:19:06 »
I would like to pick up a ton more spacebars as well depending on how the other MoQ goes.
Offline CommonCurt
  • One of the cool kids
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #217 on: Sun, 28 December 2014, 14:27:07 »
Will this still end on Jan. 15th?
Some of Ye ole  Keyboards -->
WTB/WTS/WTT ---->
« Reply #218 on: Sun, 28 December 2014, 14:29:09 »
Yes, hopefully 15th which I had extended to from the original 1 January deadline.
Offline intelli78
« Reply #219 on: Mon, 29 December 2014, 07:46:47 »
Ooh man, I can't believe the mod pack is only at 80.  :( I'm willing to double my order...
Offline LechnerDE
« Reply #220 on: Mon, 29 December 2014, 10:53:24 »
Yeah, if I knew this mod pack would match my vintage cherry sets perfectly (colorwise), I'd order three of them...
« Reply #221 on: Mon, 29 December 2014, 10:56:35 »
For those that want to know if it will match old sets... post clear well lit picture with proper color calibration and I will tell you. Even still, at the worst case you will have a different tone on the nav and function row section... which will look like on purpose and is still fine in my opinion.
Offline intelli78
« Reply #222 on: Mon, 29 December 2014, 12:21:26 »
As we discussed before, just replace ALL the beige mods, problem solved, no matching needed.
« Reply #223 on: Mon, 29 December 2014, 12:46:17 »
Right, that is why numpad keys were also include so you can replace and end up with something uniform looking even if the other set is not 100% color match... for instance:
85725-0
illustrates my point, please excuse the hasty photochop.
Offline Karura
  • Professional Canadian
  • SKidata life.
« Reply #224 on: Wed, 31 December 2014, 02:46:14 »
The mod pack is definitely the best GMK pack to have ever come out.
It has been demanded many times by countless people. Would be a shame if it didn't make MOQ, get on it people!
Offline MrChunky
« Reply #225 on: Wed, 31 December 2014, 10:11:44 »
Second that. Its been a while since the last replacement mods were available to adapt cherry sets.
Offline quochung1989
  • Vintage Cherry Collector
  • Frenzy Classic.
« Reply #226 on: Sat, 03 January 2015, 08:12:09 »
Seem all is not suite for 1800 layout?
« Reply #227 on: Sat, 03 January 2015, 11:38:31 »
The Full set has everything you would need to fit 101/102 key 1800 (6 blank key for above numpad). Mods pack also would fit for 1800, but would have to use blank key for numpad + - key.
« Last Edit: Sat, 03 January 2015, 11:40:18 by IvanIvanovich »
Offline Elrick
  • Hype Master
  • Keyboard Orgasmist
« Reply #228 on: Sat, 03 January 2015, 17:06:32 »
Thanks for that, we need more sets like yours Ivan because you always show a little love for us 1800 desperates  :thumb: .
Offline taylordcraig
« Reply #229 on: Sat, 03 January 2015, 19:21:37 »
Sorry Ivan, is there a form to check our orders?
Offline cooldiscretion
  • Convicted guilty of being totally rad.
« Reply #230 on: Sat, 03 January 2015, 19:35:43 »
This makes me very sad that this probably won't make it by January 15th.  I had myself set on getting this keyset when I first heard of it.
I'm surprised that more people wouldn't jump on the opportunity to get these.
Offline Synjin
« Reply #231 on: Sat, 03 January 2015, 19:40:38 »
This would have been my first GMK set but it won't be anymore since people aren't jumping on it as fast as they should.
  • Frenzy Classic.
« Reply #232 on: Sat, 03 January 2015, 19:56:31 »
I really don't like blank  :-X. Hope you 'll have double shot kit for 1800 in the future :)
Offline Orca
« Reply #233 on: Sun, 04 January 2015, 09:43:04 »
Hi Ivan,
Can I request my invoice to be issued in Euros?
« Reply #234 on: Sun, 04 January 2015, 10:27:11 »
Sorry no, paypal charge too much penalty for currency conversion. I already get hit hard enough with my bank when I have to send payment to GMK in euro (which is what part of groupbuy fee is for, to buffer against currency conversion loss)... if only I could transfer euro from paypal to my US bank... sadly it's not allowed.
I realize that blank is not always most ideal, but when it comes to boards that are 'minority' cases I feel it's better to have blanks that have versatility for many other use instead. Add too many keys for specific non standard models and price goes up up up up.
Offline Synjin
« Reply #235 on: Sun, 04 January 2015, 10:33:21 »
If we are unable to reach moQ, might I add to my original order amount of the spacebars?
« Reply #236 on: Sun, 04 January 2015, 10:34:15 »
It will be possible to edit order at anytime up until it is paid.
Offline Synjin
« Reply #237 on: Sun, 04 January 2015, 12:27:10 »
Awesome, thanks Ivan ^_^
Offline frostylove
« Reply #238 on: Mon, 05 January 2015, 14:13:51 »
Ordered!
Hope we can make it :rolleyes:
Offline ideus
  • Björkö.
« Reply #239 on: Tue, 06 January 2015, 20:22:28 »
Ivan: What is the current orders count?
Offline MrChunky
« Reply #240 on: Wed, 07 January 2015, 09:43:12 »
Man, I really need those MODS.... Please god of group buys, let us hit the MOQ!
Offline Lurch
« Reply #241 on: Wed, 07 January 2015, 09:52:39 »
I'll pick up another set or two of this to help reach MOQ, if I can sell my GMK cyan set that I have coming in from feng.
Quote from: Flyersfan1
« Reply #242 on: Wed, 07 January 2015, 12:32:37 »
I there a way to check/change orders?
If the main set doesnt tip I'd love to get more mods.
And we need to tip these mods because EVERYONE NEEDS THEM.
« Reply #243 on: Wed, 07 January 2015, 13:17:11 »
I've never been able to get googledocs to keep live data over to a 2nd public form without personal info...
Yes, more sets need to be ordered... can stop order spacebar now.
Offline asgeirtj
« Reply #244 on: Wed, 07 January 2015, 22:38:56 »
Can anyone explain to me whats so special/useful about the mod pack?
Offline bueller
  • MX baller
« Reply #245 on: Wed, 07 January 2015, 22:44:30 »
You can go and buy any Cherry MY board with black on white alphas and then make a full set.
« Reply #246 on: Thu, 08 January 2015, 00:14:45 »
Yes, mods pack adapt old set to new boards... almost any board even odd ones like Filco minila, Pure Pro...etc, etc, etc. that has been basically impossible before. Or you could buy it with the full set on offer here to make a mostly monocolor board...
Offline Karura
  • SKidata life.
« Reply #247 on: Thu, 08 January 2015, 00:50:20 »
It's very important because too many sets (classic ones such as BSP's beige sets) are missing the proper keys for many layouts. With the mod pack, you're set to do whatever layout you want.
Offline CommonCurt
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #248 on: Thu, 08 January 2015, 01:24:25 »
The mod pack is a brilliant idea.  Just wish it was Text+Icons :(
Will still probably end up placing a order for them.
WTB/WTS/WTT ---->
« Reply #249 on: Thu, 08 January 2015, 12:19:06 »
I really wish this would happen. Is there an possibility we could open it up to other forums? GH/Reddit/DT/KBD, GH alone has trouble hitting GMK MOQs.
Also, if the main pack doesnt tip, I'd like a 2nd mod set in place. I think EVERYONE should do the same so we can get that thing made...
