Author Topic: [IC] Calling all 1800 lovers - Aluminum Case, Plate, Leeku 1800 PCB  (Read 49236 times)
Offline DrHubblePhD
  • I am star stuff
Re: [IC] Calling all 1800 lovers - Aluminum Case, Plate, Leeku 1800 PCB
« Reply #50 on: Mon, 08 December 2014, 19:00:22 »
+1 for white PCB and steel plate, make this think shake the desk it sits on ;)
Offline Elrick
  • Hype Master
  • Keyboard Orgasmist
« Reply #51 on: Mon, 08 December 2014, 19:15:17 »
Reading your post is very entertaining, Elrick. It's my new way of learning English.  :))
Please know that I am essentially a Mine Worker on a remote site sending in my version of English, which is actually quite eloquent because I hardly use any 4-letter expletives (try to keep it down to a minimum).
So yes you shall get my degraded form of Australian English from the bottom end of town where we normally communicate via grunting and swearing on a daily basis  :thumb: .
Offline Elrick
  • Hype Master
« Reply #52 on: Mon, 08 December 2014, 19:17:19 »
Also I'd like to ask your opinions on plate materials.  Just to get an idea on demand.
SS, Alu or Polycarb. which one would you choose?
Definitely Stainless Steel because anything else would be sub-standard and that's not what we are about here on Geekhack.
Offline quochung1989
  • Vintage Cherry Collector
  • Frenzy Classic.
« Reply #53 on: Mon, 08 December 2014, 19:43:27 »
Thanks for registering interest, everyone!
I think we already have enough to make a push for non-green pcbs.
I personally think red is just as ugly as green.....so I'd say we go with white.
Feel free to voice your opinion though.
I wanna red pcb & alu plate. But alu case is quite heavy, so i think i 'll use cherry case instead. I hope they 'll fit cherry case :)
Offline MGH
« Reply #54 on: Mon, 08 December 2014, 20:13:37 »
Registering interest in a 1800 style Plate and PCB, I have a plastic 1800 case I'd like to put this in ;D
Offline yicaoyimu
« Reply #55 on: Mon, 08 December 2014, 20:42:06 »
How easy is it to put the assembled PCB/plate into a plastic 1800 case? The usb port is in the middle on Leeku PCB while both 1800 cases I have (G80-1838 and G81-7000) have the wire on the right. Is there a lot of interior space to direct the wire from middle to right?
EDIT: I just observed there seemed to be USB port place on the right too. Does the PCB support both USB port position?
« Last Edit: Mon, 08 December 2014, 20:44:29 by yicaoyimu »
« Reply #56 on: Mon, 08 December 2014, 20:48:32 »
If you're using it with an original case, you only use the USB port for programming. Then you solder a USB or PS2 cable to the four cable pins.
Offline MGH
« Reply #57 on: Mon, 08 December 2014, 21:01:24 »
Would it perfectly fit with a G81-1800 case? I heard you have to shave some things off but I'm not sure if you have to with this PCB
Offline minh278
  • In life we will only fall, How far will we fall?
« Reply #58 on: Mon, 08 December 2014, 22:03:17 »
I would be down to buy a white pcb fer the Leeku 3000 with the backplate.
Keyboards:  Final Fantasy XI XIth Anniversary keyboard (topre 45g) | Realforce Rgb (topre 45g, Eva Noctilucous keyset) | Mionix Zibal 60 (mx black, Vortex doubleshot) | Greymark (white alps) | IBM model M (found in the trash!)
Offline Karura
  • Professional Canadian
  • SKidata life.
« Reply #59 on: Tue, 09 December 2014, 06:09:04 »
BTW, why do you guys like 1800 over 3000?
Also, any chance of getting a white 3000 PCB + plate combo?
I would love to upgrade my G80-3000
  • Frenzy Classic.
« Reply #60 on: Tue, 09 December 2014, 06:27:31 »
« Last Edit: Tue, 09 December 2014, 06:44:03 by quochung1989 »
Offline MOZ
  • KING OF THE NEWBIES
  • Busy making stuff
« Reply #61 on: Tue, 09 December 2014, 07:05:44 »
I like the 1800 over the 3000, for the layout, for one it provides a layout similar to modern laptop keyboard layouts. Also my work involves a fair amount of usage of the arrow keys, and they just feel at a more natural location for me on the 1800.
Offline yuiop
« Reply #62 on: Tue, 09 December 2014, 07:08:22 »
It should fit G81 case.  I'm not sure about shaving things off.  Maybe someone else could answer it.....
for the same reason people prefer TKL over full size board?
1800 is smaller and doesn't take up as much desk space and still has 99% of the keys.
It doesn't look like there's enough demand for 3000 pcbs to produce another batch in different color.
Offline Karura
  • SKidata life.
« Reply #63 on: Tue, 09 December 2014, 07:59:54 »
Thanks for the explanation! I just never used a 1800 before and wasn't aware of its smaller size.
I do have two G80-3000 keyboards though, one that has a broken PCB. I am definitely in for a 3000 plate + PCB combo.
Offline yuiop
« Reply #64 on: Tue, 09 December 2014, 08:27:47 »
If that's the case, 3000 plate+pcb will work very nicely for you :)
Offline iamtootallforthis
  • Something a lot Funnier
  • I like green stuffs.
    • WTB/WTTF Thread
« Reply #65 on: Thu, 11 December 2014, 08:31:39 »
The only thing I don't like about the case is the N C S over the LEDs. I think it would look better without that. I still want the board though.
Offline intelli78
« Reply #66 on: Thu, 11 December 2014, 14:45:26 »
I might be in for this. I also agree that the case would look better without the LED "legends."
Offline MOZ
  • Busy making stuff
« Reply #67 on: Thu, 11 December 2014, 14:55:38 »
How about legends from the original boards, "1 A (Barred Down arrow)"
http://deskthority.net/w/images/thumb/4/4b/RaptorGaming_86221.jpg/800px-RaptorGaming_86221.jpg
    • WTB/WTTF Thread
Offline Karura
  • SKidata life.
« Reply #69 on: Thu, 11 December 2014, 17:50:19 »
This is a pretty random question, but would it be possible to get something like the Raptor K1, then use the PCB to change it to ANSI layout?
Offline kin25
    • TXKeyboards
« Reply #70 on: Thu, 11 December 2014, 23:40:01 »
Sorry, You can't use ANSI layout. I also like the Raptor K1. but it's not possible.
« Last Edit: Thu, 11 December 2014, 23:42:00 by kin25 »
Offline Sygaldry
  • Edema Ruh
« Reply #71 on: Fri, 12 December 2014, 04:13:27 »
Are the Raptor K1 cases different, structurally, from the Cherry 1800 cases so that they can't take the Leeku PCB and Plate?
null
Offline kin25
    • TXKeyboards
« Reply #72 on: Fri, 12 December 2014, 04:31:12 »
right. the raptor has 2 usb hub port.
  • Frenzy Classic.
« Reply #73 on: Fri, 12 December 2014, 09:06:27 »
Oh. Awesome. Until now, i know this. Thanks for ur info
Offline TBone
« Reply #74 on: Fri, 12 December 2014, 14:48:16 »
Interested, but the price is scary...I want it so bad though.
Offline echo0
« Reply #75 on: Sat, 13 December 2014, 12:22:21 »
Interested in plate + PCB for both 1800 and 3000.
Offline Megaweapon
« Reply #76 on: Sun, 14 December 2014, 22:37:50 »
the backlighting modes are awesome
Is there a detailed description or video of this somewhere?
Ancer Research Groop DFK191ABA11 • IBM Model M13 Part 92G7461 (white) • Rosewill RK-9000
Matias Tactile Pro 3 • Apple Extended Keyboard II (ALPS)
• Rosewill RK-9000I
Offline exitfire401
  • The Force is Re/\l
« Reply #77 on: Sun, 14 December 2014, 23:21:57 »
Anymore updates on this?
  • Frenzy Classic.
« Reply #78 on: Mon, 15 December 2014, 00:13:27 »
Offline MOZ
  • Busy making stuff
« Reply #79 on: Mon, 15 December 2014, 02:18:54 »
Off the top of my head I remember these for the 1800:
- All LEDs on - All LEDS on at max brightness (Dictated by resistors used)
- Pulsing LEDs - The LEDs fade in/out
- LEDs on when typing - LEDs light up when you press a key
- LEDs off when typing - LEDs stay on when not typing, so as soon as you press a key, they turn off
- LEDs off  - No LEDs on, ever.
I'll update once again, once I get back home.
Offline DrHubblePhD
  • I am star stuff
« Reply #80 on: Mon, 15 December 2014, 05:44:20 »
The coolest one was a mode that increased the brightness the more you typed!
Offline kin25
    • TXKeyboards
« Reply #81 on: Tue, 30 December 2014, 22:39:03 »
The 2nd Proto TX1800 Black & Silver (SUS, AL, PC Plate)
85903-0
85905-1
85907-2
85909-3
85911-4
85913-5
85915-6
85917-7
After 3rd Proto Glay Housing, GB will be started. Sorry for late. ;D
Offline exitfire401
« Reply #82 on: Tue, 30 December 2014, 22:40:43 »
 :thumb:
Offline Karura
  • SKidata life.
« Reply #83 on: Wed, 31 December 2014, 01:03:21 »
Any idea on when the GB will start? I'm interested in the 3000 PCB and Plate.
  • Frenzy Classic.
« Reply #84 on: Wed, 31 December 2014, 01:32:27 »
  • NOT compatible with stock Cherry 1800 case/PCB
What case do you use with this PCB & Plate,Karura?
Offline Karura
  • SKidata life.
« Reply #85 on: Wed, 31 December 2014, 01:38:07 »
I want to use the 3000 PCB and Plate with the OEM Cherry housing  :thumb:
  • Frenzy Classic.
« Reply #86 on: Wed, 31 December 2014, 02:28:53 »
But yuiop said it's not compatible with stock Cherry in OP? I am worry about that. Same you, I wanna build PCB & plate with Cherry case :)
« Last Edit: Wed, 31 December 2014, 02:39:46 by quochung1989 »
Offline Karura
  • SKidata life.
« Reply #87 on: Wed, 31 December 2014, 02:43:35 »
Where does it say that? It says it's not compatible with the Leeku case, but is with the 1800 (so in my case, the 3000) cases.
"Supports stock Cherry 1800 case, NOT compatible with the alu case in 1)"
  • Frenzy Classic.
« Reply #88 on: Wed, 31 December 2014, 03:01:20 »
Sorry my bad. I read OP uncarefully :(
TX1800; PCB & Plate is not compatible with Cherry case/PCB. I thought that is PCB in optional
All PCBs in optional is compatible Cherry stock case. Thanks for your help to understand exactly.
Offline nuclearsandwich
« Reply #89 on: Wed, 31 December 2014, 03:02:37 »
Does this Leeku support Alps mount switches? If so is there a plate to go with them? Or at least a drawing of one?
Offline kin25
    • TXKeyboards
« Reply #90 on: Wed, 31 December 2014, 05:41:20 »
sorry. i have no alps plate.
Offline Karura
  • SKidata life.
« Reply #91 on: Wed, 31 December 2014, 14:27:11 »
So I'm still wondering, does the actual GB have a start date, or is it still in the IC stage?
    • WTB/WTTF Thread
« Reply #92 on: Wed, 31 December 2014, 14:30:05 »
Damn those cases look awesome but I still despise the NCS lettering for the LEDs. I would love to have it without that
Offline kin25
    • TXKeyboards
« Reply #93 on: Wed, 31 December 2014, 18:57:12 »
i will make 3rd proto Gray Housing.
GB will be started in January.
  • Frenzy Classic.
« Reply #94 on: Wed, 31 December 2014, 18:57:59 »
Sound good :thumb:
Offline kin25
    • TXKeyboards
« Reply #95 on: Wed, 31 December 2014, 20:52:31 »
Sorry...  :(
I will ask the factory to make without Lettering...
But it's highly unlikely.
    • WTB/WTTF Thread
« Reply #96 on: Wed, 31 December 2014, 21:02:46 »
Sorry...  :(
I don't think it'll stop me from buying if I can gather the gonna but it is just a personal preference.
Offline bazemk1979
« Reply #97 on: Thu, 01 January 2015, 22:17:39 »
I like it, damn I was waiting for the Light saver but I think this one might look better and hopefully does not have the software problems that the Light saver has as I read here on the forums. I'm in for 1 complete order: case,PBC,plate. Got few questions:
1. Will there be ridges opened on the plate around the switch mounting square holes so we can remove the top covers if we need to clean up, asking this cause today I ended up cleaning my TrikX that had around 20 keys that had chatter because of dust.....
2. The back of the keyboard looks exactly like my TrikX, is this the same guy that made the TrikX case that will be making this one?
3. Color options on the steel plate? or just silver?
I'm in on this one and if there is any type of vote for PCB colors, this is the colors I would go most: Black PCB or White PCB, not too crazy about the red PCB, but the green one simple screams like the old PCB's back in the old days, yellow also is horrible.
Offline kin25
    • TXKeyboards
« Reply #98 on: Fri, 02 January 2015, 00:24:50 »
1) can open switch without desoldering
2) same designer... you're right.
3) plate has 3 options (SUS. silver ALU. clear sanded PC)
* pcb color options... not yet.
Offline bazemk1979
« Reply #99 on: Fri, 02 January 2015, 10:20:32 »
cool I like the fact that is the same designer of the keyboard, I'm impressed with the TrikX design and heftiness.
