Author Topic: Am I the only one who finds it ridiculously hard to put stabilized keys back on?  (Read 2622 times)
Offline RoflCopter4
I've just spent the past 30 minutes struggling in vain to put the space bar back on my Apple Extended Keyboard and I'm just about ready to break it in half over my knee and smash it to tiny little bits with my bare hands. Why is this so difficult? Am I retarded?
Acer KB-101A with Blue Alps | HHKB Pro 2 | '85 122 Key IBM Model F | '86 1390131 "Silver Label" Model M | AEK M0115 with Orange Alps | Focus FK-2001 White Alps | Chicony 5181 with SMK "Monterey Blue" Switches | Dell AT101W | Unicomp "Ultra Classic" | Razer Blackwidow 2013
Offline jacobolus
The AEK II at least (I can’t remember about the AEK) has a particularly difficult spacebar to put on. I recommend removing all the nearby keycaps (i.e. the whole bottom letter row and the two command keys) and if that’s still a challenge, maybe the case as well.
It definitely shouldn’t take a half hour though. :)
Offline kaotikb
 I think it seems harder on some keyboard while others just go on easily. I also put stabilized keys on first and then do the rest.
Ducky 1087 (Green ALPS) |  CM QFR Stealth (MX Brown) | Unicomp Ultra Classic |Poker II (MX Brown)  | IBM 1391401 1991 | IBM 1391401 1989 | Ducky Shine 3 White Edition (MX Brown) | G80-3700(MX Black) | Corsair K70 (MX Brown) | Varmillo VA87MR (Gateron Red)
Pointing Devices:  Microsoft Trackball Optical (Ceramic bearings Installed)  | Sanwa MA-TB39BK (Larger Ceramic Bearings Installed) | Elecom M-XT2URBK | Kensington Slimblade | Logitech Trackman Wheel | Logitech Trackman Marble Plus
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
Once you find the best way to do it, it certainly goes much quicker. For spacebars, I find it much easier to put on with the case taken off so nothing is impeding your view
Offline Hzza
I spent about a half an hour trying to get the stabs back on my Apple Standard the first time, I can do it a bit quicker now but it's still super fiddly. I would definitely recommend doing it outside the case though.
Offline RoflCopter4
Wow, I can't believe I didn't think of that. I guess I thought it would be harder to remove the case but apparently it's just 4 phillips head screws. I took the case off and got the key on in a couple of minutes. Thanks all.
Incidently, do you guys prefer to snap the stabilizer bar into the board and try put it into the key or do you put it into the key and try to snap it into the board?
Offline jacobolus
Definitely easier to snap the wire into the clips on the plate first.
Offline hwood34
  • underwater squad
  • #1 CL stan
+1
Offline RoflCopter4
Huh. I would agree that it's easier to snap it onto the plate first the vast majority of the time, but I only finally got the stupid spacebar on by doing it the other way around.
Depends on the clips and the board.
On something like an IBM, you have to attach the wire to the key and guide the wire into the clips as you push the stem down. And on the weird ones like the XT spacebar, you can get into weighted thread loops and such.
A very small flat head screwdriver can be very handy.
But, speaking theoretically, I really wish that wires would just go away completely.
- D Trump 2026-10-24
Offline jacobolus
If you give up on the stupid QWERTY/ANSI/IBM layout, you can live this dream! There’s no reason any keyboard key needs to be bigger than 1.5u.
