Author Topic: Where to buy a Universal ten key less plate  (Read 1469 times)
Offline PocoLoco
« on: Wed, 17 December 2014, 17:07:10 »
Hello i would like to know if it is possible to buy a Universal tkl plate for my filco and phantom from any source whatsoever. I have been scouring GH for the past few days and it seems that the group buys are the only way of acquiring one. I am in dire need of one even so much as going to the extent of buying one from laser cutters. Any help or info would be much appreciated.
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
Re: Where to buy a Universal ten key less plate
« Reply #1 on: Wed, 17 December 2014, 17:51:36 »
You might just have to go to the classifieds (when you can). There was a UTkl plate GB a few months ago so some people may have extras from that
Offline munch
« Reply #2 on: Wed, 17 December 2014, 17:56:43 »
https://geekhack.org/index.php?topic=58571.0
the "MINT" ANSI 150 one - would this one work perhaps?
Offline strict
  • TKL Zealot
« Reply #3 on: Thu, 18 December 2014, 08:43:41 »
Sorry to say but that plate wont work on a Filco. The biggest reason being that it does not have the cutout about the arrow cluster for the Filco controller but also because his Filco wont support the ANSI 150 layout. The plate will work with his Phantom though.
Offline PocoLoco
« Reply #4 on: Thu, 18 December 2014, 11:04:35 »
I was hoping that plate would do for a filco tkl. So the search goes on. Im waitng on my phantom pcb to come until then ill look for one
