Author Topic: Phantom plate case files?  (Read 2022 times)
Offline nandop
  • May your keystrokes always be true.
« on: Wed, 17 December 2014, 19:12:56 »
Hello fellow hackers,
I have a manufacturer that makes metal and acrylic goods 15 minutes from where I live and I was wondering if there is a way to acquire something that I can send or produce for them to make a case for the Phantom PCB.
I already have the plate design from the CAD Thread, so all I'm missing is what goes below that and encompasses the PCB. If I can't find it, I'll have to make one. That would be last resort, because I'm trying to save time. :D
Thank you for any help!
Sprit 60%, White MX 78g Au | Planck Ortholinear 40% Clear MX | Phantom TKL Browns 110g Au
Re: Phantom plate case files?
« Reply #1 on: Wed, 17 December 2014, 23:58:01 »
I asked and the skeldon phantom case files are not available
Offline AKmalamute
  • HHKB Scrub
« Reply #2 on: Thu, 18 December 2014, 00:33:20 »
MOZ had a file, didn't he? I've never seen it made but it should work for any 87key ... not so sure about, for instance, the 101key 7-bit layout but it would be a definite start.
HHKB-lite2, Dvorak user
Offline MOZ
  • KING OF THE NEWBIES
  • Busy making stuff
« Reply #3 on: Thu, 18 December 2014, 08:54:13 »
See my sig. I have used it to cut a case for myself and it works well.
Offline nandop
« Reply #4 on: Thu, 18 December 2014, 10:08:30 »
Thank you, MOZ. I have found the Universal.dwg file. What is a common price for the plate? I'll be getting quotes for steel. I'm thinking of making the other layers in acrylic, I like the exposed bottom.
Thanks again.
Thank you everyone that has helped as well. Sorry about the late response.
