Author Topic: ps2 to usb adaptor for model M  (Read 3052 times)
Offline Jixr
« on: Sat, 20 December 2014, 13:01:25 »
Hi everyone, I recently picked up a model m, and My motherboard does not have a ps2 connector.
So I bought a little ps2 to usb adapter, and my keyboard does not work.
keyboard may be broken, but are there any tricks or anything special you need to do when using an m with an adaptor?
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
Re: ps2 to usb adaptor for model M
« Reply #1 on: Sat, 20 December 2014, 13:17:37 »
Is it an active or passive adapter?
Offline Jixr
« Reply #2 on: Sat, 20 December 2014, 13:31:19 »
I'm not sure, it looks like this.
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #3 on: Sat, 20 December 2014, 13:32:30 »
Yeah, you'll probably need an active adapter
Offline Jixr
« Reply #4 on: Sat, 20 December 2014, 13:42:57 »
oh okay, well, I have a frys electronics about 15 mins away from my house, is there anyway to tell if one is passive or active?
http://www.frys.com/product/2703123?site=sr:SEARCH:MAIN_RSLT_PG
http://www.frys.com/product/6819986?site=sr:SEARCH:MAIN_RSLT_PG
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #5 on: Sat, 20 December 2014, 13:45:09 »
They both look like it, the second one definitely
Offline Jixr
« Reply #6 on: Sat, 20 December 2014, 13:50:50 »
okay cool, i got the one I had from there, but didn't know that there was any difference.
Thanks, I'll run over there and check it out.
My M i paid $15 for it, and its an 86 and im excited to see if it works or not.
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #7 on: Sat, 20 December 2014, 14:00:13 »
Wow, you got a good deal, what kind is it?
Offline Jixr
« Reply #8 on: Sat, 20 December 2014, 15:30:30 »
I dunno really, but here are some pics.
two for $15
https://geekhack.org/index.php?topic=66726.0
Offline Hypersphere
« Reply #9 on: Sat, 20 December 2014, 16:00:56 »
You definitely need an active adapter. There are two that I have tried that work. One is known as the "blue cube". The other is made by Adesso and has a keyboard and mouse adapter attached. I think I paid about $7 for each one.
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #10 on: Sat, 20 December 2014, 18:36:18 »
two for $15
oh yeah, that thread
« Reply #11 on: Sat, 20 December 2014, 19:53:26 »
http://techkeys.us/collections/accessories/products/usb-to-ps2-serial-multimode-adapter
My other Model M has a fixed PS/2 cable, and one of these adapters made that keyboard work on my Mac.
I kinda figure if that combination works, almost anything else should :p
Offline RoflCopter4
« Reply #12 on: Sat, 20 December 2014, 20:19:06 »
You can try one of those $1 Chinese y-cable adopters too. Some of them work and some of them don't and there's no way to tell whether one will or not, but they're one freaking dollar; buy a couple and one is bound to work eventually. The Blue Cube adapters are practically guaranteed to work but including shipping you won't spend less than $20 or so.
« Last Edit: Mon, 22 December 2014, 01:18:13 by RoflCopter4 »
Acer KB-101A with Blue Alps | HHKB Pro 2 | '85 122 Key IBM Model F | '86 1390131 "Silver Label" Model M | AEK M0115 with Orange Alps | Focus FK-2001 White Alps | Chicony 5181 with SMK "Monterey Blue" Switches | Dell AT101W | Unicomp "Ultra Classic" | Razer Blackwidow 2013
Offline Hypersphere
« Reply #13 on: Sun, 21 December 2014, 10:55:20 »
I can definitely vouch for the blue cubes; they have always worked for me. If you get the blue cube, pick up a 6-inch female-male extension cable as well. This is because the blue cube is a bit bulky, and it will block an adjacent USB port if used without an extension cable.
Offline Jixr
« Reply #14 on: Sun, 21 December 2014, 12:28:26 »
I found a Y adapter at frys, and it works
Typing on my m right now.
My '88 M works, but unfortunatly, my 86 two keys input the wrong key for some reason. possibly fixable.
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #15 on: Sun, 21 December 2014, 18:06:50 »
Short term fix, you could just use autohotkey
Offline RoflCopter4
« Reply #16 on: Mon, 22 December 2014, 01:19:14 »
It's never a bad idea to just spend the money and invest in a proper blue cube if the cheap ones are giving you trouble.
