Author Topic: GON NerD 2.0 Build log  (Read 8069 times)
Offline uprock7
« on: Mon, 29 December 2014, 13:59:07 »
Hey all, my first shipment from gon came in this month and I decided to document my build.
http://imgur.com/a/i9gV4#0
Ducky Mini (2014), Filco Magestouch 2 w/browns, Das Pro 3 w/browns (retired)
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
Re: GON NerD 2.0 Build log
« Reply #1 on: Mon, 29 December 2014, 14:02:46 »
Good stuff mang :thumb:
Offline naasfu
  • The Curator
  • CURSE YOU HE-MAN
« Reply #2 on: Mon, 29 December 2014, 14:03:22 »
Cool, thanks for sharing!  I really like that the NerD logo is embossed on the case now.  Looking forward to seeing more pics!  I have an earlier NerD TKL and love it a lot.
« Reply #3 on: Mon, 29 December 2014, 14:04:37 »
that settles it i'm saving for one
also maybe pm a mod about moving this thread to media, since it's gonna be mostly pics
MOD EDIT:
I LIKE TO MOVE IT, MOVE IT
SHE LIKES TO MOVE IT, MOVE IT
YOU LIKE TO (MOVE IT)
« Last Edit: Mon, 29 December 2014, 21:24:58 by infiniti »
Offline uprock7
« Reply #4 on: Mon, 29 December 2014, 14:05:18 »
i actually paid extra to have the logo on the right. it just seemed right.
« Reply #5 on: Mon, 29 December 2014, 14:10:27 »
yeah I've built up a few: they're nice.
That upper plate is a thing of beauty.
Offline Sent
  • Simplistic Serenity
  • ¯\_(ツ)_/¯
« Reply #6 on: Mon, 29 December 2014, 14:21:07 »
Looking forward to the completed project.
Offline madhias
  • BS TORPE
    • Madhias' Flickr
« Reply #7 on: Mon, 29 December 2014, 14:22:23 »
Will watch your build log too, since i have an open order at GONs.
The PCB looks gorgeous!
Offline heedpantsnow
  • Old enough to know better
« Reply #8 on: Mon, 29 December 2014, 14:23:48 »
Thanks for sharing!
I'm back.
Offline ckywylee
« Reply #9 on: Tue, 30 December 2014, 04:28:21 »
Good share, will watch your build log.
Offline naasfu
  • The Curator
  • CURSE YOU HE-MAN
« Reply #10 on: Tue, 30 December 2014, 15:02:35 »
Ah very cool.  It's a really great touch!
Offline uprock7
« Reply #11 on: Thu, 15 January 2015, 19:27:02 »
Progress!
http://imgur.com/a/k5o7V#0
now I have to wait for my next shipment from Gon...........
Offline DrHubblePhD
  • I am star stuff
« Reply #12 on: Thu, 15 January 2015, 19:44:33 »
I really love the etching! I should recommend to you though that instead of bending the pins to solder them that you use some tape instead. Often when you bend the pins like that before soldering the joint isnt quite as strong and if you were to try and desolder you would run into issues removing the solder between the bet part of the pin and the pad.
Offline sethk_
  • Grand Master Wizard Pizza
  • www.kbdhub.com
    • My webstore
« Reply #13 on: Thu, 15 January 2015, 20:38:55 »
How did you go about soldering the SMD parts?
« Reply #14 on: Thu, 15 January 2015, 22:09:45 »
Looking good!  Those white LEDs?
I'm back.
Offline Evo_Spec
  • (╯°ヮ°)╯︵⌨
« Reply #15 on: Fri, 16 January 2015, 00:07:06 »
I forgot to watch this thread the last time i saw it, watched!
Also are the LED's supposed to be soldered flat? i thought they were supposed to be on their side so that it shines directly into the PC layer.
http://www.gonskeyboardworks.com/manuals/129-nerd-side-ledsmd-led-soldering.html
GON NerD TKL DTA Edition
Offline DrHubblePhD
  • I am star stuff
« Reply #16 on: Fri, 16 January 2015, 05:48:36 »
No it's flat, the LEDs still shine predominantly out the sides.
Offline uprock7
« Reply #17 on: Fri, 16 January 2015, 13:11:45 »
these are the yellow leds. im planning on white leds for the switches.
im just using a $15 soldering iron from radio shack and a pair of tweezers to hold resistors/leds
i think soldering on their sides will get them a bit brighter, but i put the pcb in the housing and it is bright enough for my tastes. And because this was my first time soldering SMD leds, I decided to go with the simpler route.
EDIT: I did get my switches, switch stickers, switch leds, resistors, and stabilizers in the mail yesterday.
