Author Topic: [ebay] All metal Alps keyboard w/ Dolch keycaps  (Read 2528 times)
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
Re: [ebay] All metal Alps keyboard w/ Dolch keycaps
« Reply #1 on: Tue, 30 December 2014, 21:54:20 »
Damn, want those dolch caps so much.
« Reply #2 on: Tue, 30 December 2014, 22:19:33 »
From what I remember, those caps are thin and pad printed.  I posted one of these a while back, but the price was high.  If you want some nice Dolchish Alps caps, I recommend some of the old Toshiba laptops, preferably of the broken variety.
And three Windows caps?
Offline faceyourfaces
« Reply #3 on: Tue, 30 December 2014, 23:49:18 »
Yeah, what's up with that?
Offline Touch_It
« Reply #4 on: Wed, 31 December 2014, 09:41:03 »
I require at least 4 windows keys to consider a board.  With that being said, the keyboard does look pretty cool.  IDK if this is the same keyboard or not, but this one, or a similar one has been floating around before.
Offline vivalarevolución
« Reply #5 on: Wed, 31 December 2014, 12:33:07 »
Hey, thanks for moving the slash/question mark key, guys!
Offline didjamatic
« Reply #6 on: Fri, 02 January 2015, 22:14:34 »
I wonder if you could shift the spacebar to the right and move the windows keys over there.  If you could, I would be all over this board.
