Author Topic: Need help in my search of keycaps  (Read 1644 times)
Offline fierran123
  • Mechanical keyboard lover
« on: Wed, 31 December 2014, 01:33:49 »
Here is an image of the keyboard I'm using:
Here is a comparison of a standard sized 118 mm WASD keycap to the smaller 114 mm Das keycap that came with my board:
I'm looking to buy a keycap set, and I'm about to pull the trigger except for one small problem; the spacebar in every PBT keycap set I've found has been the 118 mm one - even custom keycap vendors have them only at that size.
Is there any way at all to get a hold of a 114 mm spacebar? I've been looking around for quite a while and found nothing, so maybe you guys have some ideas :p
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
Re: Need help in my search of keycaps
« Reply #1 on: Wed, 31 December 2014, 02:00:36 »
Here is a full set (unfortunately the only thing I could find) that has 3 different spacebars, one of which is a 6x
Offline fierran123
« Reply #2 on: Wed, 31 December 2014, 02:16:45 »
Thanks for the reply, are those keycaps PBT or ABS? I can't seem to find that information on their website :(
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #3 on: Wed, 31 December 2014, 02:20:57 »
ABS
Offline fierran123
« Reply #4 on: Wed, 31 December 2014, 02:25:53 »
Ah shoot. I'm guessing I'm out of luck for PBT caps then :/
