Author Topic: Cheapest tkl wrist rest?  (Read 4601 times)
Offline Bakgrund
« on: Mon, 05 January 2015, 13:11:50 »
What's the cheapest leather wrist rest designed for tkl keyboards? I'll be using it with my qfr if that matters.
Quickfire Rapid    Quickfire Rapid
Mx Browns          Mx Reds
Ducky thick PBT   Stock caps
Offline spale
Re: Cheapest tkl wrist rest?
« Reply #1 on: Mon, 05 January 2015, 13:21:10 »
Might be a long shot, buy Aliexpress had some cheap wrist pads.. Not sure about the quality, though.
Offline Bakgrund
« Reply #2 on: Mon, 05 January 2015, 13:25:18 »
Most of them seems pretty short, maybe it's worth spending a little extra. Are the filco ones any good? I saw that Keypop had some. http://www.keypop.net/product/filco-black-leather-white-stitch-wrist-rest
Mx Browns          Mx Reds
Offline davkol
  •  Post Editing Timeout
« Reply #3 on: Mon, 05 January 2015, 14:52:41 »
Ducky TKL rest from Ducky Nordic? Not the cheapest, but within EU.
Offline hoggy
  • * Ergonomics Moderator
« Reply #4 on: Mon, 05 January 2015, 15:35:19 »
I've moved the thread to the keyboards sub-forum.  Hope you don't mind.
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #5 on: Mon, 05 January 2015, 15:55:15 »
Graffiti rests are pretty comfortable and go for around or under $20
Offline Fragil1ty
  • Abre los ojos.
« Reply #6 on: Tue, 06 January 2015, 17:03:41 »
^ this.
I was going to suggest this, the only problem with the Grifiti wrist rests is that they tend to wear away rather.. quickly. That's the only downside to be honest, other than that, they are extremely comfortable and extremely cheap also.
你搞砸了
Offline Bakgrund
« Reply #7 on: Tue, 06 January 2015, 17:07:08 »
^ this.
Apparently a local store is selling Ducky tkl wrist rests for 279 SEK which is about 35 bucks, I've thought about it a bit more and I think I'd rather take something of high quality, but the question is if ducky really has high quality?
Mx Browns          Mx Reds
Offline davkol
« Reply #8 on: Tue, 06 January 2015, 17:11:20 »
Higher than Grifiti by design.
Offline daerid
    • Rossipedia
« Reply #9 on: Tue, 06 January 2015, 17:19:03 »
I just retired a full-sized Grifiti rest that I've had for about 2 years. Replaced it with the Big-Ass version: http://www.amazon.com/gp/product/B009LC9KPO/
