Author Topic: WASD keycaps  (Read 1856 times)
Offline neverused
WASD keycaps
« on: Tue, 06 January 2015, 14:17:01 »
Hello,
I was long for some impressions of the standard keycaps from WASD. Are they thick ABS? How do they compare to other easily available keycaps? Do you personally like them? Why?
Thanks for your input!
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
Re: WASD keycaps
« Reply #1 on: Tue, 06 January 2015, 14:18:34 »
They're pretty thin and cheap feeling, though if you really need a totally custom set they're your best bet
Offline inanis
  • Truly Literally The Cloud
    • SEALWoodworking
Re: WASD keycaps
« Reply #2 on: Tue, 06 January 2015, 14:28:18 »
They are thin ABS with a UV coating. They aren't the best caps in the world, but I don't think there as bad as everyone makes them out to be. I have a few with some custom designs and I have no issues with them.
