Author Topic: Atomic build log  (Read 4496 times)
Offline joey
Atomic build log
« on: Tue, 06 January 2015, 18:49:29 »
Since I first saw the Atomic ~1 month ago, I knew that I wanted to build one.
So after a few days of thinking about it. I contacted Jack and set the ball rolling.
Anyway here is the final result:
Some may find the colours boring... but I prefer subtle over fancy!
This was my first time really doing any proper soldering. it mostly went without problem..
Apart from this little bit of wire causing a short:
Still getting used to typing on it, the bottom alpha row is the most confusing so far. Also the stabilisers for my 2u keys all seem to get jammed when I press on them. so that's something I need to figure out. (Right now I'm 2u stabless.. but it's working well enough)
You can find the full build pics here: http://imgur.com/a/3OcNf/
I had a lot of fun.. I want to make a case of some form for this. and after that.. I may look at doing something totally custom :)
Offline joey
Re: Atomic build log
« Reply #1 on: Sat, 10 January 2015, 13:24:16 »
Sorry for bumping my own post.. but it seemed to get un-noticed before and I think it may have just been unlucky timing :( (or maybe no-one cares about atomics :P)
Offline vvp
« Reply #2 on: Sat, 10 January 2015, 16:41:22 »
Interesting. Why do you have those 2u keys surrounded by 1u keys? What is the layout?
« Reply #3 on: Sat, 10 January 2015, 16:42:21 »
No idea what the atomic is, but awesome job! Looks damn cool.
Offline joey
« Reply #4 on: Sat, 10 January 2015, 16:55:28 »
The layout I'm using is http://www.keyboard-layout-editor.com/#/layouts/bdc1562e83fb828090be1420cdb82675
I plan to make some tweaks, changing Delete to FN, and maybe a few other things.
It's a set of plates you can buy here http://ortholinearkeyboards.com/atomic-top-plate-semi-standard
Offline vvp
« Reply #5 on: Sat, 10 January 2015, 19:57:53 »
The 2u keys are enter and shift. It makes sense now :)
Offline noobicus
« Reply #6 on: Sun, 11 January 2015, 14:03:21 »
I saw this when I was away from my computer so didn't get a chance to post!  :))
This is a cool build, and I had just stumbled upon the Planck and Atomic earlier that day, so it was awesome to see this pop up immediately.
The board looks great.  Any plans on making a case?
« Reply #7 on: Sun, 11 January 2015, 14:41:17 »
Interesting - straight columns.  I bet that will take a bit of getting used to...  That design looks strange as noted above but actually there's a lot of functionality on the right without adding much width and I could use it with your blank keycaps after just one look at the keymap (if I were used to ANSI :)))
Good work handwiring the matrix with bare wire with only one short too, looking forward to seeing what you come up with for a case :)
Offline joey
« Reply #8 on: Mon, 12 January 2015, 15:16:25 »
I do plan on making a case at some point but haven't spent much time thinking about it yet.
Probably get some acrylic cut.. or maybe two layers, one acrylic, one wood. Might look cool.
« Reply #9 on: Wed, 21 January 2015, 15:01:34 »
This is really cool. Just stumbled across it now. Thanks for sharing your matrix wiring :)
Offline joey
« Reply #10 on: Thu, 22 January 2015, 09:40:56 »
Thanks! :)
I'm in early stages of planning a new build.
I've been researching PICs as an alternative to a Teensy.
« Reply #11 on: Thu, 22 January 2015, 09:59:08 »
Looking forward to your new builds. Please post a build log when you finish up that board :).
