Author Topic: TKL MX blue Keyboards?  (Read 1927 times)
Offline Harms
« on: Thu, 08 January 2015, 23:02:18 »
Hi everyone, I'm looking for a TKL keyboard with cherry MX blues (with Cherry Stabs). A very specific criteria, but yea :P. Lastly I don't mind back lighting I guess; however, it would be better without it because it would keep the cost down. Thank you for the help everyone.
Offline abjr
    • abjr.org
CM QFR | magicforce 68 (Gateron) | magicforce 68 (Outemu) | Acros 6311-K
Offline Dihedral
  • Mostly Harmless
Re: TKL MX blue Keyboards?
« Reply #2 on: Fri, 09 January 2015, 11:47:46 »
Why cherry stabs? It will limit your options.
Offline strict
  • TKL Zealot
« Reply #3 on: Fri, 09 January 2015, 12:26:44 »
If you want to limit yourself to Cherry stabs, which IMO feel horrible, you're best bet is the KUL board posted by abjr.
If you are willing to go with Costar stabilizers, which feel 1000x better but are **slightly** harder to work with, then you could go for a Filco, WASDv2, or a Code. If you wanted to go cheaper and are willing to sacrifice some build quality, you could pick up a Cooler Master board as well.
Offline file_id
« Reply #4 on: Fri, 09 January 2015, 13:59:08 »
Another option would be the quickfire rapid-i .Think it's $119 at the moment on amazon.
DS3 White YOTS (Blue)|Poker 2 (Blue,Clear)|QFR Rapid-i TKL (Brown,Blue)|QFR Rapid TKL (Blue,Red,Brown)|KBP V60 (Blue,Clear,Matias Click)|Code TKL Clear|Filco MJ2 TKL (Blue)|Filco MJ2 Ninja Beige TKL (Brown)|Novatouch
« Reply #5 on: Sat, 10 January 2015, 01:50:53 »
Ducky keyboards use Cherry stabilisers.  Clipped, so some claim, which is supposed to improve the feel, although I can't really tell any difference between my Ducky Shine 1 and Ducky Shine 3.
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #6 on: Sat, 10 January 2015, 16:59:23 »
You'd be great with either a KUL or a Ducky
Offline Firebolt1914
  • POM Overlord
« Reply #7 on: Sat, 10 January 2015, 18:28:42 »
If you want backlighting go for the ducky, if not go for the KUL.
If you decide on costar stabs, there's other options.
