Author Topic: What is the best way to clean the space in between the switches?  (Read 7277 times)
Offline radio_killah
  • Chinchillin'
« on: Sat, 10 January 2015, 21:18:00 »
What ways have you discovered work best to clean your keyboards in between the switches? I tried a q-tip but that just kept getting caught on the switches and stickers and left tons of stringy cotton...  :blank: Any suggestions?
Offline Evo_Spec
  • (╯°ヮ°)╯︵⌨
Re: What is the best way to clean the space in between the switches?
« Reply #1 on: Sat, 10 January 2015, 21:23:33 »
i don't have stickers so i'm not sure but i use one of these and it works quite well.
GON NerD TKL DTA Edition
  • Chinchillin'
« Reply #2 on: Sat, 10 January 2015, 21:37:05 »
Looking for something that will get rid of the finer dust and also finger prints. Thinking about it though I don't even know how or why fingers would be in between the switches.
« Reply #3 on: Sat, 10 January 2015, 21:40:45 »
TechKeys keyboard brush.
https://ssl.redditgifts.com/marketplace/product/keyboard-brush/
Unfortunately they do not appear to be listed on TechKeys web site at the moment.
Offline cephelix
  • to buy or not to buy?
« Reply #4 on: Sat, 10 January 2015, 22:07:35 »
i've just used this
seems to work well. just make sure to dab instead of swipe the compound across....
ALi
Filco MJ2 TKL MX Browns | KC60 Gateron Browns
« Reply #5 on: Sat, 10 January 2015, 23:01:20 »
i've just used this
Review (including video) of something similar to that:
https://geekhack.org/index.php?topic=53330.0
Offline cephelix
« Reply #6 on: Sat, 10 January 2015, 23:03:44 »
i've just used this
That's the one...couldn't find the thread..thanks man
ALi
Offline sethk_
  • Grand Master Wizard Pizza
  • www.kbdhub.com
    • My webstore
« Reply #7 on: Sat, 10 January 2015, 23:05:29 »
I pull mine of and use qtips with isopropyl alcohol.
  • Chinchillin'
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #10 on: Sat, 10 January 2015, 23:55:44 »
I just pull the caps, turn upside down, and knock the big chunks out and put the keys back on.
  • Chinchillin'
« Reply #11 on: Sun, 11 January 2015, 00:50:19 »
Yeah that works for the big stuff but im talking small bits of dirt and finger prints/oils and stuff. I'm kind of picky like that.
Offline danwomansan
  • Also known by my real name, ********!
« Reply #12 on: Sun, 11 January 2015, 01:03:27 »
I use bunched up disinfectant wipes, and then a screwdriver to remove things that were too "in there" for the wipes to remove, like the horror of what seemed to be roach guts and bird poop on the spare keyboard I just cleaned last night.
it's pronounced "danw omansen", not "dan woman san"
Offline Coreda
« Reply #13 on: Sun, 11 January 2015, 01:26:39 »
I use strips of sticky tape, and remove all the keys. Probably not ideal but it gets everything, and use a wooden skewer to push between small gaps. Can't imagine how one would clean a board without removing the caps first.
Next time I clean the board I'll be using the DataVac mostly. Will be vastly quicker.
Offline Ngt
« Reply #14 on: Sun, 11 January 2015, 05:58:34 »
I like to remove all the caps and use a dry air can to blow everything out.
Regarding finger prints on the keycaps I only washed them once and it soaked them in hand soap and water then I brushed them one by one. I won't do it again. It took me ages to do because I dried them with a towel one by one also. In a full keycaps set it is horrendously long.
Offline spale
« Reply #15 on: Sun, 11 January 2015, 10:24:57 »
I guess I am the only guy that use a vacuum cleaner to remove the dust from keyboard.
For me its a long-time solution and the most effective  ;D
Offline Ngt
« Reply #16 on: Sun, 11 January 2015, 10:39:14 »
Do you remove the caps before?
Offline taylordcraig
« Reply #17 on: Sun, 11 January 2015, 11:19:50 »
The suction of a vacuum shouldn't be able to lift a properly seated cap off the stem.
Offline Ngt
« Reply #18 on: Sun, 11 January 2015, 11:43:10 »
Yeah that's what I wondered.
« Reply #19 on: Sun, 11 January 2015, 13:49:31 »
I use a cotton swab
Offline FluffynFuzzy
« Reply #20 on: Sun, 11 January 2015, 14:17:28 »
I use a cotton swab
I always happen to get the ctton caught on the switches somehow and have to wind up picking it out with my fingers...
Ducky Zero 2108S w/ MX Blues, Poker II w/MX Browns
  • Chinchillin'
« Reply #21 on: Sun, 11 January 2015, 15:08:23 »
I use a cotton swab
Exactly this is why I originally posted this asking. The cotton swabs also have a hard time picking up finger prints, oils, etc.
« Reply #22 on: Sun, 11 January 2015, 20:47:10 »
I use a cotton swab
Full circle  ;)
« Reply #23 on: Mon, 12 January 2015, 00:15:55 »
I use a cotton swab
Full circle  ;)
I've use cotton and ISO alcohol but it's not ideal. A lot of suggestions don't seem to meet the requirement of cleaning inbetween switches, I've experienced this first hand.
« Reply #24 on: Mon, 12 January 2015, 01:57:28 »
Not at all. I use it with the brush attachment. Every time I clean under the desk, I also go over the keys with it.
Offline Jersern
  • Australian Keyboard Modding and Repair Service
« Reply #25 on: Mon, 12 January 2015, 02:00:05 »
I usually use a slightly damp cloth and a brush to clean out any dust that's managed to get in the gaps. Works really well as long as you don't get it too messy.
Offline howthegodschill
« Reply #26 on: Tue, 13 January 2015, 00:06:03 »
I take off all of the keys, then use an acid brush in collaboration with my ED500 Datavac.
Offline jonathanyu
« Reply #27 on: Tue, 13 January 2015, 00:14:11 »
i always pull off all the keycaps and then use a vacuum cleaner to suck all the dust
  • Chinchillin'
« Reply #28 on: Wed, 14 January 2015, 09:25:36 »
http://www.amazon.com/OXO-Grips-Electronics-Cleaning-Brush/dp/B0050B6CYW
Just got this little pen in the mail today and I must say for 5 bucks it does exactly what I wanted it to.
The silicone tip is great for cleaning out dust and picks up oils. Thanks spamray for the suggestion.
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #29 on: Wed, 14 January 2015, 10:08:26 »
i've just used this
+1
You could also buy a mini vacum like a DataVac
Offline cephelix
« Reply #30 on: Wed, 14 January 2015, 10:09:33 »
i've just used this
+1
that is also true.can't remember how much it costs locally though. or if they even sell it locally.
ALi
« Reply #31 on: Wed, 14 January 2015, 10:15:20 »
Glad I could help. :D
  • Chinchillin'
« Reply #32 on: Wed, 14 January 2015, 11:36:20 »
i've just used this
+1
I got one of those too. $40 on black friday. Thing is freaking awesome.
  • Live long and prosper
« Reply #33 on: Wed, 14 January 2015, 11:39:39 »
leafblower
tp thread is tp thread
  • Chinchillin'
« Reply #34 on: Wed, 14 January 2015, 12:41:55 »
leafblower
Essentially. Just in a miniature form.
Offline ynrozturk
« Reply #36 on: Thu, 15 January 2015, 07:36:07 »
I use one of those dinky USB vacuum things which cost like a few dollars. They have a rubber tip which fits in very nicely between the switches, and it does a damn fine job, too.
IBM Model F | IMB Model M | Poker II MX Brown | Poker II MX Clear | Filco TKL MX Brown | Bastardized Razer Blackwidow TE MX Blue | Logitech G602 |  Cyborg R.A.T. 7 | | Logitech MX518 | Icemat  | Artisan Hien
Offline berserkfan
« Reply #37 on: Thu, 15 January 2015, 13:15:49 »
But question is, now long can this tool last? That silicon tip...
Offline FrostyToast
  • Litshoard
« Reply #38 on: Thu, 15 January 2015, 13:19:51 »
Don't vacuum cleaner generate static or something that could damage electronic components? No idea if it would be relevant to the simple design of keyboards, however I would like to know the effect of this.
Quote from: elton5354
  • Chinchillin'
« Reply #39 on: Thu, 15 January 2015, 13:24:12 »
As long as you are good to it it seems like it will last  a while. It picks up dust and small particles with easy and can be cleaned using just a piece of wet paper towel.
« Reply #40 on: Mon, 16 March 2015, 18:07:46 »
Got a Datavac today. All the good reviews are true, this thing is a tiny monster. It's got more than enough power, almost too much because I wish there was an adjustment to lower it. Well worth the $$ considering it costs about as much as 12 pack of canned air. A little worried about overheating because it's such a small unit with such a large motor it can heat up pretty quickly but who cares, this thing is awesome!
