Author Topic: How do  (Read 2654 times)
Offline boingolover
How do
« on: Sat, 10 January 2015, 21:44:15 »
Hello!  First time poster, long time lurker.  I've been a fan of mechanical keyboards since the model M, though unfortunately I no longer own one.  Right now I have a Das Professional, a (recently broken) Goldtouch, and was also a participant in the most recent group buy at massdrop for the ErgoDox.  Looking forward to actually interacting with the people here!
« Last Edit: Sat, 10 January 2015, 21:51:23 by boingolover »
Re: How do
« Reply #1 on: Sat, 10 January 2015, 22:58:55 »
Welcome to Geekhack!
A good range of switches and layouts in those few keyboards.  Have you got a favourite?
Offline boingolover
Re: How do
« Reply #2 on: Sat, 10 January 2015, 23:20:15 »
Thank you!
As far as favorite switches, I LOVE Cherry MX Blues and buckling springs, but those aren't work friendly due to the noise and my heavy hand (I'm a software developer by trade).  I also love ergo keyboards and I was a big fan of the Goldtouch.  I've always loved the hinge design on those.  But I've always wanted a ergo mechanical keyboard, which is very difficult to find it seems.  Even if I could find an M15 in good shape at anything approaching a reasonable price, I've heard that the hinge design is prone to breaking so I'd be reluctant to use it on a daily basis.  And since Goldtouch doesn't seem to want to do the obvious thing and make a mech keyboard - the keyboard that the M15 should have been - I decided to give the ErgoDox a try with MX clears. I did consider the Kinesis Advantage, but i really like the truly split design of the ErgoDox.  At least in theory.  I've never seen one in person.  Right now I'm using an MS Natural at work until I can get my shipment, and I use the Das at home.
Offline Evo_Spec
  • (╯°ヮ°)╯︵⌨
Re: How do
« Reply #3 on: Sun, 11 January 2015, 03:21:36 »
Welcome to GH!
nice history of boards!
GON NerD TKL DTA Edition
Re: How do
« Reply #4 on: Sun, 11 January 2015, 05:43:36 »
Thank you!
The Ergo Dox comes up on Massdrop every now and again.  And there are a few Ergo Dox fans here on GH, but don't let tp4's raving fanaticism put you off :p
I use MX greens at work - no-one seems to mind :))
Actually if you like buckling spring, you might like MX greens - they are like a stiffer version of MX blues, and about the closest you can get to BS with a modern switch.
Offline boingolover
Re: How do
« Reply #5 on: Sun, 11 January 2015, 10:03:38 »
Even when I'm using the Das with blues working from home and I'm on a call with some of my coworkers, I get complaints ;)  That being said, the greens look pretty interesting.  They didn't offer the greens on the last drop, but if I end up liking the ErgoDox I might order another one for the house, and if greens are an option I would certainly consider them.
On an unrelated note, do the Captchas go away after enough posts?  I seem to be having trouble reading them.
« Last Edit: Sun, 11 January 2015, 11:01:02 by boingolover »
Offline zentic
Re: How do
« Reply #6 on: Sun, 11 January 2015, 17:55:00 »
Welcome :)
HHKB2 Dark&Blank |  Realforce 104UB-DK
Offline Evo_Spec
  • (╯°ヮ°)╯︵⌨
Re: How do
« Reply #7 on: Sun, 11 January 2015, 20:06:23 »
After about 10 posts
Re: How do
« Reply #8 on: Mon, 12 January 2015, 03:32:04 »
That's an interesting point - I don't know how well greens would go with an Ergo Dox!  Maybe the Ergo Dox is supposed to be easy on the hands, so a lighter switch would be better.  OTOH if you have strong fingers, than almost any switch should be fine.
Offline zentic
Re: How do
« Reply #9 on: Mon, 12 January 2015, 14:49:18 »
Welcome to GH
