Author Topic: APL Model F Unsaver, starting at $1 + shipping  (Read 8264 times)
« on: Sun, 11 January 2015, 23:02:00 »
Offline vivalarevolución
Re: APL Model F Unsaver, starting at $1 + shipping
« Reply #1 on: Mon, 12 January 2015, 06:52:22 »
OMG.
« Reply #2 on: Mon, 12 January 2015, 06:58:16 »
That seller turned up out of nowhere with all this rare vintage IBM...
Offline berserkfan
« Reply #3 on: Mon, 12 January 2015, 07:04:55 »
We need EzraHiliyer to make us some faux unsavers to meet demand.
Offline fanpeople
« Reply #4 on: Mon, 12 January 2015, 07:08:45 »
Wow, I am going to bid stupidly on this  :p
Offline berserkfan
« Reply #5 on: Mon, 12 January 2015, 07:20:35 »
That's why I consider it so important to solve the Model F production problem.
Model F feels the best and rare layouts get ridiculous bids.
I'm tempted to offer a bet on this. Rather than try to bid for something that will go for way more than I want to pay, I want to try and make money by betting on the insanity of geeks...
Offline Defect
« Reply #6 on: Mon, 12 January 2015, 08:26:27 »
So how much should I expect to pay for this?  Over 300?
« Reply #7 on: Mon, 12 January 2015, 08:28:03 »
Nah, $3.50 max ;)
Offline Defect
« Reply #8 on: Mon, 12 January 2015, 08:46:51 »
Nah, $3.50 max ;)
$3.5k?
« Reply #9 on: Mon, 12 January 2015, 08:52:13 »
$2K would not surprise me, but it might go for half that.
- D Trump 2026-09-28
Offline The_Beast
  • I like wood ಠ_๏
« Reply #10 on: Mon, 12 January 2015, 09:07:03 »
Offline MGH
« Reply #11 on: Mon, 12 January 2015, 11:03:28 »
O.O drool...
Offline Touch_It
« Reply #12 on: Mon, 12 January 2015, 18:50:13 »
$275 is my guess.  The look of these is growing on me.  Doubt I'll ever get one even though I thought the same about a 4704 107 key.
Offline AKIMbO
  • HHKBro
« Reply #13 on: Tue, 13 January 2015, 19:54:15 »
Is this the model that can be converted to usb with Soarer's converter?
| KBD75 (box reds)
Offline The_Beast
  • I like wood ಠ_๏
« Reply #14 on: Tue, 13 January 2015, 21:21:10 »
It is. I have one and a converter, just need some time to tear it apart and get it installed. Not sure if I want to tho since it looks like it just came out of the box. But I said that about the M15 I have too....
Offline berserkfan
« Reply #15 on: Tue, 13 January 2015, 22:37:57 »
Fohat, we need you! (Get some Model F122 and make a faux unsaver out of it, would you?)
Offline orihalcon
« Reply #16 on: Tue, 13 January 2015, 23:58:24 »
Hmm, I am pretty sure that this one can’t be used with a Soarer’s Converter.  Some Unsavers have the same plug as the F122, which probably would work, but the seller’s pictures definitely show the large serial connector type, suggesting a completely different protocol.  Kind of reminds me of the F Bigfoot versus the XT Model F.  They look the same other than the connector and case size, but the protocol is definitely different.  Here are some closeups of what the connectors look like: http://deskthority.net/workshop-f7/to-save-an-unsaver-t8957.html?hilit=unsaver
Offline Parak
« Reply #17 on: Wed, 14 January 2015, 00:49:42 »
Yep, this requires a replacement controller - Soarer's will not work here.
« Reply #18 on: Wed, 14 January 2015, 07:25:04 »
No way. I do not intend to cut any Model F internals, even though I have hacked away at the case more than once. That faux-SSK Model M was only partially successful, and I simply folded the unused part of the membranes underneath without cutting them.
It is my belief that you cannot cut or alter the internal assembly of a Model F.
That is why the XTant project is the most intriguing option to emerge so far.
Offline orihalcon
« Reply #19 on: Wed, 14 January 2015, 18:26:14 »
I still think you can cut a model F and have it work fine assuming that you use an Xwhatsit controller or similar.  Original controllers may not work because they might look for resistance in addition to capacitance, and you can't change the current threshold like you can with the Xwhatsit.  The Xwhatsit works with any board that you can connect it to, so it clearly isn't affected by the length of the tracts going to each key, so cutting the PCB and reconnecting should work just fine.
I have an extra F107 barrel plate assembly with PCB that did not come with a case which has some mild damage to a few footpads on the PCB that I would feel less guilty about cutting.  Not sure what to use to actually do the cutting since I'd want to make the cuts perfectly straight and without fraying the PCB...
Offline Jotokun
« Reply #21 on: Mon, 19 January 2015, 12:51:02 »
820$...
And now you can also buy a overpriced one with bin here: http://www.ebay.com/itm/IBM-104-key-Model-F-Space-Unsaver-keyboard-EXTREMELY-RARE/221666713846?_trksid=p2047675.c100011.m1850&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D27673%26meid%3D78bb1b96458a4e82897005f6d57b111a%26pid%3D100011%26rk%3D6%26rkt%3D6%26sd%3D251789001831
lol
Why would someone consider paying that much for one when it's been butchered? From the photo it looks like they cut the plate below the arrows for some reason.
85 IBM Model F "120" ANSI-Modded | 86 IBM Model M | Cherry G84-4100 | TG3 Data911 (MX Blacks) | 90 Apple Extended II (Linear modded Cream ALPS) | 95 Apple Extended II (Dampened White ALPS)
« Reply #22 on: Mon, 19 January 2015, 12:55:23 »
820$...
lol
it's not butchered it is modded from iso to ansi and has usb
« Reply #23 on: Mon, 19 January 2015, 12:56:52 »
I think that still qualifies as butchered.
« Reply #24 on: Mon, 19 January 2015, 12:57:22 »
You mean most people wouldn't do that mod anyways?
Offline snoopy
  • The Flying Ace
  • Gone with the Wind
« Reply #25 on: Mon, 19 January 2015, 12:58:44 »
But what happened with the down arrow?
Offline FrostyToast
  • Litshoard
« Reply #26 on: Mon, 19 January 2015, 13:01:25 »
It looks as though the centre key was turned into the down arrow to make for a more familiar layout.
Although I don't know why he removed the bottom key entirely.
Quote from: elton5354
Offline Parak
« Reply #27 on: Mon, 19 January 2015, 13:07:26 »
In my book, it's only butchered from a museum type sample if the mod performed is not fully reversible. In that case, this is quite reversible. The usb cable on the other hand looks kinda sloppy, and unless it's stress reinforced internally I would expect it to rip out of the controller, usb jack included.
Offline Jotokun
« Reply #28 on: Mon, 19 January 2015, 13:16:05 »
If it were only ISO to ANSI, sure. But there's no hole below the bottom arrow anymore. The plate was in some way modified, you can't put a barrel there. That's not reversible.
« Reply #29 on: Mon, 19 January 2015, 13:22:27 »
That's just something to cover it up, you could still put something there see the photo of the back.
87861-0
« Reply #30 on: Mon, 19 January 2015, 13:24:35 »
Still, looks like crap. And for a keyboard he's asking $800 for...
« Reply #31 on: Mon, 19 January 2015, 13:26:06 »
Definitely for the price it could have been modded with much more care.
Offline E TwentyNine
    • Some of My Keyboards
« Reply #32 on: Mon, 19 January 2015, 13:46:53 »
Gives it a closer feel to the more common inverted-T cursor key layout.  Same reason the ANSI mod was done.
Fully reversible, barrel was removed and the hole covered up.
That USB cable setup though looks potentially problematic.
« Reply #33 on: Mon, 19 January 2015, 15:18:22 »
I map both center arrow and down arrow to down arrow, to keep my finger memory retraining to a minimum.
Offline Ellipse
    • Brand New Model F and Beam Spring Keyboards
« Reply #34 on: Wed, 21 January 2015, 09:15:25 »
I'm the seller of the BIN listing.
Yep the mod is fully reversible.   That bottom cursor key spot is just covered with electrical tape.   Remove the tape,  open the plate sandwich,  put the barrel and pivot plate/spring back in,  done.
I can make adjustments to the current modified layout or even restore it to the original state for the buyer. It comes with the original keys and even the original controller for the sake of completeness.
Again the layout mod is fully reversible.
The USB cable is tied to the sandwich plate inside for strain relief.   Any other mod ideas on how it can be further strengthened?
« Last Edit: Wed, 21 January 2015, 18:30:50 by Ellipse »
