Author Topic: Do any of you really type faster with a mechanical keyboard?  (Read 20269 times)
Offline Grundoko
« on: Tue, 13 January 2015, 00:01:17 »
I'm asking this question as someone who has greatly enjoyed the use of mechanical keyboards for years. I will say that without a doubt I enjoy typing on a mechanical keyboard more than any rubber dome or scissor switch. My current keyboard is a WASD v2 with Cherry Mx Browns, and I dearly love it. Yet I type more slowly on it than I do on a scissor switch keyboard. On my mechanical keyboard I can reach up to 120wpm with 1-2 mistakes per minute, or 110wpm consistently without mistakes. Yet on my Lenovo laptop with scissor switch keys, I can get 120wpm without mistakes, and can reach 125, and sometimes 130 with 1-3 mistakes per minute.
In the end, I'll take comfort over the slight speed increase, especially in long typing sessions. But the reason for this I think, is that the keys on my mechanical board are raised, whereas on my laptop keyboard, they are flat. I find that when typing at very high speeds, often the edge of my finger will nip the key next to the one I'm pressing, which doesn't happen nearly as often on the flat keys on my laptop. Another thing that may affect speed is travel distance. Scissor switch keys only travel about 1mm, which means less time pressing the key.
Offline SonOfSonOfSpock
Re: Do any of you really type faster with a mechanical keyboard?
« Reply #1 on: Tue, 13 January 2015, 00:48:09 »
Nope, same speeds no matter what. I might be faster compared to a really bad rubber dome, but I don't have one of those to test on. I just tried a decent rubber dome, scissor switch, and a Matias Alps board and I got the same speed on all three.
« Reply #2 on: Tue, 13 January 2015, 00:58:38 »
hhkb gives you +80wpm on top of your current wpm.
Offline flaming_june
« Reply #3 on: Tue, 13 January 2015, 01:49:00 »
Actually trolling aside, my HHKB did increase my wpm on speed test websites by over 20-30 wpm.  I've never been able to hit consistently over 100 wpm on any other mechanical or non, only hhkb pro 2.  Now of course, this wasn't conclusive testing, side by side, word for word after warm up.
« Reply #4 on: Tue, 13 January 2015, 05:24:48 »
I like to feel that I am typing faster on my mechanical keyboards (including HHKB), although really I just enjoy typing on them and could happily type on most of them for much longer than I could on a membrane keyboard.
Offline Oobly
« Reply #5 on: Tue, 13 January 2015, 06:03:11 »
Yes, just a little. But the comfort is more valuable than the speed.
The increase in speed comes from not having to bottom out and having a softer touch when typing. My hands feel "freer" :) And my ErgoClears with SA profile caps on feel divine, I have less fatigue on longer coding / typing sessions than with all the other cap profiles, spring strengths, switch types or mechanisms that I've tried and that matters a lot to me.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
« Reply #6 on: Tue, 13 January 2015, 06:34:51 »
For my use case using a mechanical keyboard has nothing to do with typing faster, not sure if that is the main goal of most people or not.
I'm so used to typing on my laptop keyboard when I'm home that there probably is no real speed difference between it and my daily driver mechanical I use at work.
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #7 on: Tue, 13 January 2015, 07:34:27 »
It's more of a comfort and style thing for me, but yes. When I have to use the keyboards at school it slows down mostly because of all the mistakes I make on rubberdomes
Offline ideus
  • Björkö.
« Reply #8 on: Tue, 13 January 2015, 07:37:52 »
I do type slower with my mecha than with a rubber dome keyboard just for the sake of the enjoyment of typing with it. Could you eat that ice cream you like the most quickly? Could you kiss your beloved girl in a rush?  8)
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #9 on: Tue, 13 January 2015, 07:45:51 »
You could try Cherry ML, which are low profile, short travel mechanical switches
Offline snipars
« Reply #10 on: Tue, 13 January 2015, 07:47:28 »
Nope, i'm much faster on topre
Duck Octagon + Gateron Black |HHKB Pro 2 | Poker 2 + Vintage Black + Tex case | Unicomp Ultra Classic | WASD V2 |
« Reply #11 on: Tue, 13 January 2015, 07:50:13 »
I type about 10% faster on a mech than I do on rubber dome.
Offline R1N3
« Reply #12 on: Tue, 13 January 2015, 07:56:04 »
I used my gfs macbook to look something up yesterday because I didn't wanna get off the couch and it was sitting on the coffee table.
Honestly, I was still probably typing at least 80wpm
But at 40% accuacy. **** was so frustrating, but I got a giggle out of missing at least every other key
Offline Dee1
« Reply #13 on: Tue, 13 January 2015, 08:43:36 »
I type about the same speed on rubber domes and on mechanical keyboards.
Offline drewba
« Reply #14 on: Tue, 13 January 2015, 09:35:52 »
I switched from a rubber dome to MX Browns a few weeks ago. Since, I've been playing 5-15 races on typeracer daily. My typing speed has stayed roughly the same, ~100WPM but my accuracy has steadily increased to over 95%. Typeracer doesn't actually record your accuracy percentage as far as I know but I try to keep track after every race.
Offline Defect
« Reply #15 on: Tue, 13 January 2015, 09:49:43 »
It might increase your typing accuracy compared to RD membrane boards...since membrane boards require you to press the carbon contact all the way down and may fail to register some strokes, compared to mechanicals which actuate about half way.
I did some typing tests long ago and (I believe) my fastest was at tied around 118 out of 121 correct WPM (average over 5 attempts) using Topre 55g and 62g Linear.  RD was consistently lower, but not by much.
Offline Jotokun
« Reply #16 on: Tue, 13 January 2015, 10:24:17 »
I'm about the same. However, typing for long periods on a rubberdome does make my fingers ache so while I don't type faster, I can type for longer on a mech.
This is assuming it's a good rubberdome, like a Thinkpad keyboard or one of those Dell rubberdomes. I am a bit slower on that silver/black HP keyboard that seems to be in use everywhere, and I'm almost reduced to hunt & peck typing on non-Thinkpad/Apple chiclet laptops due to the sheer lack of travel.
85 IBM Model F "120" ANSI-Modded | 86 IBM Model M | Cherry G84-4100 | TG3 Data911 (MX Blacks) | 90 Apple Extended II (Linear modded Cream ALPS) | 95 Apple Extended II (Dampened White ALPS)
Offline daerid
    • Rossipedia
« Reply #17 on: Tue, 13 January 2015, 10:52:34 »
I honestly haven't measured. I haven't had a non-mechanical board in about 5 years so I couldn't really test either.
  • Live long and prosper
« Reply #18 on: Tue, 13 January 2015, 10:54:35 »
nah
it's just more fun... better experience...
tp thread is tp thread
« Reply #19 on: Tue, 13 January 2015, 10:56:26 »
nah
This guy gets it. HBD BTW!
Offline dante
« Reply #20 on: Tue, 13 January 2015, 21:59:17 »
An odd experience I have is when I buy a new keyboard or bring one out that I haven't typed on for a while I always type faster on it at that moment in time than 90% of my other experience.  I can't explain why.
Fingers have A.D.D I guess. :D
Offline DrHubblePhD
  • I am star stuff
« Reply #21 on: Tue, 13 January 2015, 22:21:47 »
I have increased my WPM significantly since switching to mechanical keyboards a around 5 years ago from around 45 to my current speed of 95 . Now if I go back to typing on rubber domes I just type a bunch of errors, which contributes to a pretty poor WPM.
Offline calvinhousecat
« Reply #22 on: Wed, 14 January 2015, 00:28:22 »
For me the additional comfort I believe gave me more WPM lol. I was hitting around 90 WPM on a rubber dome now I can get 105 on my MX blues.
Offline Sturmfrau
« Reply #23 on: Wed, 14 January 2015, 00:32:40 »
I did get a +20 wpm boost on HHKB but I was able to do that when I was using rubber dome and scissor switch keyboards. But the thing is, on the HHKB I do it effortlessly and more consistently than I do on a normal keyboard which leaves my fingers and wrists tired.
HHKB Pro 2 Black (Blank) | HHKB Pro 2 White (Blank)
Offline arakula
« Reply #24 on: Wed, 14 January 2015, 00:37:19 »
Faster? Not really. But with less typing errors, so yeah, the overall effect is "a bit faster".
And since I'm accustomed to it, typing on a rubberdome surrogate always gives me an uneasy feeling.
Offline Snowdog993
  • Grace Under Pressure
  • Justifiably Clueless.
« Reply #25 on: Wed, 14 January 2015, 18:33:45 »
I think I type a little slower, but more accurately.  Compared to my black Lenovo KU-0225 rubberdome keyboard with the blue enter keys, I think I lose a word or two per minute.  Actually the Lenovo is not too bad at all to be honest.  (For now, anyway.)
Offline Nai_Calus
  • CLACK
« Reply #26 on: Wed, 14 January 2015, 18:44:45 »
I think I actually type slower, but that's more an issue of being used to the really low keycaps on the Acer rubberdome I had before, the height of the board I've got not working well with the extremely bad desk setup I've got right now that I can't do anything about, and Blues being too heavy half the time.
- IBM 4704 Model F 107-key "Bertha"
Other boards: Kinesis Essential, Infinity(G.Clears), Ergodox(MX Blues), Monoprice 9433
Eternally searching for Celestial Blue BS V2 and blue/purple Bros.
Offline Polymer
« Reply #27 on: Wed, 14 January 2015, 20:06:22 »
I think some people are associating them typing faster with the fact that they're typing more which is going to give them a boost in speed...Or they're now practicing typing which is going to get them better speed...The keyboard itself is not going to make someone type faster.
I suppose some might fit into some sweet spot for someone..just as scissor switch keyboards seem to work out better for some people...but I think overall, you're going to get about the same speed on just about any keyboard you use...
The difference to me is the experience...I enjoy using a mech keyboard a lot more than a normal keyboard.  The difference in quality is definitely perceivable and for me, the amount I end up spending per day to have a better overall computing experience is a pittance...I don't type faster, I don't think they're necessarily more comfortable to use..I just think when using it, you can feel the quality and it feels nicer to use.  They're more fun to use.
Offline Firebolt1914
  • POM Overlord
« Reply #28 on: Wed, 14 January 2015, 20:15:20 »
I think I actually type faster on my laptop because there's less travel time for each key. I type faster with a mechanical compared to a crummy rubberdome, because I'm not used to how the keystrokes feel
Offline johndavis33
« Reply #29 on: Wed, 14 January 2015, 20:17:20 »
Mechanical keyboards give plus 8 to comfy, not to speed.
HAVE AND WILL KEEP: HHKB - Printed white | Ducky Banana edition - Whites | Model M13 | Unidentified Goodwill keyboard - Simplified black ALPS
TOO BE SOLD: TG3 BL82 - Clears | Wheelwrite 5 - Buckling Springs typewriter
SOLD: Rosewill RK9000 - Blacks | QFR - Blues | Ducky G2 Pro - Greens |
IT WILL BE MINE: Northgate Omnikey - White ALPS
Offline Fragil1ty
  • Abre los ojos.
« Reply #30 on: Thu, 15 January 2015, 03:06:14 »
Can confirm.
你搞砸了
Offline GL1TCH3D
« Reply #31 on: Thu, 15 January 2015, 09:07:32 »
Well I definitely type faster on a mechanical keyboard because I'm not cringing every few seconds
Offline Touch_It
« Reply #32 on: Fri, 16 January 2015, 16:15:23 »
Honestly I doubt it.  From the limited testing I did, I got the exact same WPM as with the mech, albeit with a few more mistakes.  So I will say I honestly believe that it helps my accuracy.  This could have been attributed to using a keyboard I wasn't accustomed to though.
Offline jacobolus
« Reply #33 on: Fri, 16 January 2015, 16:27:49 »
Speed depends a lot on familiarity and personal preference.
For me, the range in typing speed between fastest and slowest keyboards (that is, among full-size standard ANSI layout boards) is about 40% difference, if you include time for correcting errors. Not any arbitrary “mechanical” keyboard is good for me though.
Apple scissor switches are much faster than $10 full-travel rubberdome boards though. From my laptop keyboard to the fastest external keyboard is probably only ~15–25% difference.
Using a better physical and logical layout and better firmware also makes a big difference: with a better layout (column-staggered, split and tented, with the right keycap profile, plenty of thumb keys, etc.) hand comfort is dramatically improved; with a better layout than QWERTY, many slow motions can be avoided; with better firmware with lots of shortcuts, macro recording features, etc., many computing tasks can be sped up dramatically; adding a trackpoint, trackball, or trackpad within easy reach of the key area also makes a big difference: moving your hand back and forth to a mouse/trackpad/trackball is slow and uncomfortable.
« Last Edit: Fri, 16 January 2015, 16:35:12 by jacobolus »
Offline viskin
« Reply #34 on: Sun, 18 January 2015, 12:51:27 »
I don't necessarily think that mechanical keyboards improve typing speeds though the switch actuation point is definitely quicker. I think it really is just a personal preference for enjoyment.
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #35 on: Sun, 18 January 2015, 13:23:36 »
no question isn't even close, plus my fingers don't hurt
not going to say it is the rule as i have a couple decent rubber domes..........., but on the whole YES
Luga G80-1865/MX Reds + Dolch G80-1813/MX Blues + G80-3700HQAUS + DK9008G2 Pro/MX Browns Thick PBT + DK9008G2 Pro/MX Clears Thick PBT +  QFR TKL/Ghetto Greens + Cherry G80-1800/MX Blues + IBM Model M SSK Bolt Modded + IBM Model M + IBM Model F + IBM AT F + Cherry G80-1000 (HAD)/MX Vintage Blacks + Razer BWU/MX Blues + Leading Edge DC2214/Blue Alps + Compaq MX11800/Browns + Chicony 5181/Monterey Blues + Chicony 5161/MX Black Cherry Clone + Focus 2001/White Alps + Chicony 5191/White Futabas + Olivetti ANK27-101 + Dell (Old Logo) AT101/Black Alps + NMB RT8255C+/Black Space Invaders + Unitek K260/Green Alps + Apple M0116/Orange Alps + AEK II M3501/Cream Alps + AEK M0115/Orange Alps + NEC  APC412/Blue Sliders + NEC APC410/Blue Sliders + Omnikey /White Alps + Wang/Yellow Alps (Omrons) + Laser/White SMK + Fame/Blue Aruz + AEK II M3501/Salmon Alps + Zenith ZKB-2R/Green Alps + Wang 724/Orange Alps + DK1087/Green Alps + Zenith ZKB-2/Yellow Alps + Dell Old Logo AT101/Salmon-Pink Alps + Leading Edge AK1012/White SMK's + Magitronic SK-1030/White (Linear) Futaba's + Packard Bell/White (Clicky) Futaba's + Datacomp DFK101/White  Alps + SGI AT101/Dampened White Alps + NMB AQ6RT-72511/Grey Space Invaders (Hi-Tek) + Datacomp/Blue Alps + Phillips 2812/White Space Invaders (Linear) + Dah Yang K251/Vintage MX Blues + Chicony 5161/DS Caps/Vintage MX Blue + Archie-NMB AQ659ZRT-725/Black Space Invader (Tactile) + IBM Model M 71G4644 (RD) Bolt Modded with Soarers Converter + IBM Model M Silver Label 1390131 + Cherry G80-1501/Vintage MX Clears + Focus FK8000/Linear Futabas + Gateway 2000 Anykey Programmable/Maxi-Switch + Dell GY13PVAT101/Dye Sub Caps/Salmon Alps + Chicony 5161/White Alps + AST K0B101/Slider over RD + Qtronix QX-32H + Everex/NMB RT8255CW+ Black Space Invaders-Split Erase + Tandon/NMB AQ659ZRT-101A/Beige Space Invaders + Cherry G80-11903 MNRUS/MX Blacks + Apple IIGS A9M0330/SMK Whites + WYSE PCE/MX Blacks + Chicony 5160AXT/Clicky Futaba + Cherry G80-0528/Vintage MX Blacks + Dell AT101/Linear (Modded) Black Alps+Topre 55g
Offline meztek
  • Keyboards! Keyboards everywhere!
« Reply #36 on: Sun, 18 January 2015, 15:20:31 »
If I use a rubber dome keyboard, chicklet or otherwise, I can type just about the same speed now as I can on my mechanical keyboards.  I measure it sometimes and I lose about 10WPM, from an average of 105WPM on my mechanical keyboards down to about 95WPM on a rubber dome keyboard.  Or on a keyboard which is uncomfortable or has a foreign layout.  However, I will say my typing speed has increased dramatically after I began mechanical keyboard ownership and use.  As others have said, mechanical is far more comfortable to me, but I also believe it enabled me to gain a faster typing speed because it is comfortable enough to practice on for long hours and easier to do so on.
Offline 1391406
« Reply #37 on: Mon, 19 January 2015, 09:37:30 »
I typed faster on my old rubber dome keyboard.
Offline Sencha
  • HHKB Pro
  • MX Reds <3
« Reply #38 on: Mon, 19 January 2015, 09:59:57 »
Probably about the same but mechanical boards are about joy and comfort to me.
Offline user 18
« Reply #39 on: Mon, 19 January 2015, 10:13:07 »
I type between 80 and 90 wpm on all my keyboards, cherry (blue, clear), topre (novatouch), buckling spring (model M), scissor switch (samsung and HP laptops). I tend to get in the low to mid 80s, but getting faster than that depends more on the words I'm typing than the board I'm using.
I don't have a rubber dome around to test with at the moment, but my best wpm score ever was on a Dell rubber dome (91). Usually though, I'm in the same range with that board as I am with my mechs.
I do find mech boards to be a more enjoyable and less fatiguing experience than other boards though, with rubber domes being the least comfortable, then topre, then buckling spring, with cherry mx clicky and tactile switches giving the best experience.
Avatar by ashdenej
Offline slickmamba
« Reply #40 on: Mon, 19 January 2015, 10:21:42 »
I havent had a rubber some in close to a decade, but I type much faster on my mech boards than my laptop. About 15 wpm faster
Hi :)
Offline aceps00
« Reply #41 on: Mon, 19 January 2015, 14:56:17 »
The fastest keyboard that Ive typed on would sadly be a chiclet keyboard, great for speed (for me) but sacrifices comfort.
Type Heaven / IBM Model M
Offline Bakgrund
« Reply #42 on: Mon, 19 January 2015, 15:18:05 »
I type like 10wpm faster on my laptop as it has very short travel-distance, however I found it more comfortable to write on my mechanical keyboard, speed isn't everything that counts.
Quickfire Rapid    Quickfire Rapid
Mx Browns          Mx Reds
Ducky thick PBT   Stock caps
Offline drewba
« Reply #43 on: Tue, 20 January 2015, 12:22:03 »
I received a new keyboard yesterday with MX clears and my average typing speed went up ~10 WPM and I hit a new personal record (136 WPM). All within hours of using clears.
I found these results after roughly 40 races on typeracer so take it with a grain of salt. But to answer your question, right now I'm saying yes.
« Reply #44 on: Tue, 20 January 2015, 12:29:38 »
I get an increase of like 30-40 wpm typing on my LZ-S compared to say my DT-35, even though I love the DT more I just type faster and more efficiently on a mechanical. Haven't done any serious typing since I put the hobby on hold though ^_^
EDIT: did one real quick (wow I haven't played since May! meh.)
http://i.imgur.com/6aS7gx6.png
I know I only hit like 100-120~ on a rubber dome.
« Last Edit: Tue, 20 January 2015, 12:32:54 by Sifo »
Offline spale
« Reply #45 on: Tue, 20 January 2015, 12:42:17 »
I just received my Topre Realforce 87U, I cant say I am quicker but I suddenly feel more manly. I think thats the real thing  :thumb:
Offline MOZ
  • KING OF THE NEWBIES
  • Busy making stuff
« Reply #46 on: Wed, 21 January 2015, 06:58:04 »
I type fastest on my laptop's scissor-switches, however it hurts after awhile and the experience is horrendous. I like mechs for the comfirt they provide, not the speed.
Offline ideus
  • Björkö.
« Reply #47 on: Wed, 21 January 2015, 07:34:04 »
Who told you that people get a mechanical keyboard to type faster?  :))
Offline ander
  • I type, therefore I am
« Reply #48 on: Mon, 13 April 2015, 06:57:21 »
I type somewhat faster on mechanicals. I don't think the keys are actually faster; for me, it's the sounds they make. I'm a musician, so I tune in to the clicky/sproingy sounds, and that helps me stay out of my own way. Which is what good typing is about, of course—and playing music, and doing all kinds of things.
Offline Dihedral
  • Mostly Harmless
« Reply #49 on: Mon, 13 April 2015, 07:10:59 »
Well, if this thread is coming back, then no. But it's more fun :P
