Author Topic: Gaterons  (Read 16226 times)
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
Gaterons
« on: Thu, 15 January 2015, 21:36:17 »
So I want to try Gateron switches, I've heard good things about the smoothness, but I can't find much information on them so far, or where to find all the colors. So far I know that:
gateron red=slightly lighter reds
gateron blue=slightly heavier blues
gateron yellow=pretty much super blacks
I'm not sure about Gateron blacks or clears though. Thoughts on these or any general points on the switches?
Offline Zeal
    • Zeal Generation Inc.
Re: Gaterons
« Reply #1 on: Thu, 15 January 2015, 21:45:50 »
I just ordered ~200x Gateron white/clears. They're apparently super light & smooth reds (35g vintage black?). Will report back once I receive them. :)
Offline Sniping
Re: Gaterons
« Reply #2 on: Fri, 16 January 2015, 00:14:33 »
The clears I tried felt weird. I'm not sure if they were a special batch but they had this very slight tactile bump that was a bit odd.
They're very smooth, but the switch top got a bit loose after I opened the switch. Be wary of that when trying to mod the switches.
Offline hwood34
  • underwater squad
  • #1 CL stan
Re: Gaterons
« Reply #3 on: Fri, 16 January 2015, 11:42:24 »
It'll be a small sample size, but I just ordered 15 blues, 10 blacks, and 10 yellows.
Re: Gaterons
« Reply #4 on: Fri, 16 January 2015, 11:42:56 »
Where do you find these?  Every time I saw them go up, they were gone almost immediately.
Offline hwood34
  • underwater squad
  • #1 CL stan
Re: Gaterons
« Reply #5 on: Fri, 16 January 2015, 11:43:43 »
Taobao. It looks like they only have 200 or so in stock at a time
Re: Gaterons
« Reply #6 on: Fri, 16 January 2015, 11:47:47 »
link?
Offline Defect
Re: Gaterons
« Reply #7 on: Fri, 16 January 2015, 11:52:41 »
Wish the tops were more transparent like the ones I bought a while ago
Yellow stems look nice.  Everyone seems to say the plastic allows for smoother action...I'm more curious about the durability.
Offline hwood34
  • underwater squad
  • #1 CL stan
Re: Gaterons
« Reply #8 on: Fri, 16 January 2015, 12:33:35 »
link?
Reds
just search gateron and they'll all pop up
Offline Zeal
Re: Gaterons
« Reply #9 on: Sat, 24 January 2015, 00:21:56 »
Just going to throw pictures here. Hopefully you don't mind. :P
Tops off
Disassembled a Gateron White & MX Red.
Gateron's 35g spring is like a penis with erectile dysfunction. No kidding. Just look at it! However, the "35g" spring does have an interesting bottom out feeling to it. The force curve feels really "bouncy" after actuation. Maybe it's the bendy spring giving that feeling? Not sure. I like it.
Switch stem comparison:
Bottom housings:
Underneath:
PCB Mount Gaterons do not fit properly in the PCB I had. I had to shave a bit of the leg for it to fit snugly. Haven't measured it yet, but the PCB supports are either too thick, or aren't far appart enough.
In summary, I really love how smooth they feel for stock switches. The Gateron has the feet lubed slightly, while reds are not, surprisingly. I'd have to say stock Gateron Whites are smoother than worn in blacks (Using my small sample size of ~8 lubed, WYSE blacks) The slider has a slipperier feeling when you rub your nail against it vs Reds. Gateron sliders in stock MX Switches do feel better than stock Reds (way smoother), but still not as smooth as in the original Gateron housing.
« Last Edit: Sat, 24 January 2015, 00:25:45 by Zeal »
Offline sethk_
  • Grand Master Wizard Pizza
  • www.kbdhub.com
    • My webstore
Re: Gaterons
« Reply #10 on: Sat, 24 January 2015, 00:24:24 »
Tops off
Bottom housings:
Underneath:
Can you swap the housing? This would be a cheap alternative to clear switch tops.
Offline intelli78
Re: Gaterons
« Reply #11 on: Sat, 24 January 2015, 00:26:23 »
Today I learned my pen0r is like a 35g Gateron switch! :)
Now that's a bit odd. Everything ok with the plate mount versions / pin spacing?
Offline Zeal
Re: Gaterons
« Reply #12 on: Sat, 24 January 2015, 00:26:55 »
Tops off
Bottom housings:
Underneath:
Was in middle of editing my reply :P
I haven't tried using the top on a cherry housing. I don't see why it wouldn't fit though. Will double check tomorrow.
Offline Zeal
Re: Gaterons
« Reply #13 on: Sat, 24 January 2015, 00:28:46 »
I'd take PCB mount switches over plate mount anyday. :P
I only got PCB mount, so no plate mounted Gaterons to try. But the pin alignments fit no problem. Shaving the PCB supports isn't that much of a hassle. But it for sure would not force itself into the PCB. I had to remove the switch and look at the "scraped" off plastic and then shave that off.
Offline hwood34
  • underwater squad
  • #1 CL stan
Re: Gaterons
« Reply #14 on: Sat, 24 January 2015, 00:31:28 »
Thanks for the pics Zeal! I'm still waiting on the blacks and blues I ordered.
Offline Evo_Spec
  • (╯°ヮ°)╯︵⌨
Re: Gaterons
« Reply #15 on: Sat, 24 January 2015, 00:58:24 »
Tops off
Bottom housings:
Underneath:
Even though i already submitted my entry, this doesn't help me at all determining which stems were Gaterons.....
GON NerD TKL DTA Edition
Re: Gaterons
« Reply #16 on: Sat, 24 January 2015, 01:08:16 »
If anyone here could loan me a few just for me to check out, I'd be really grateful. Really curious about these and I'm still kicking myself for not picking up that Gateron tester off Massdrop.
Thanks for the great pictures Zeal :D.
Offline mouse.the.lucky.dog
Re: Gaterons
« Reply #17 on: Sat, 24 January 2015, 01:10:21 »
Are the stems of the blue's sheathed like on a Cherry?
Offline Zeal
Re: Gaterons
« Reply #18 on: Sat, 24 January 2015, 02:00:09 »
Hopefully someone near you can hook you up with a tester soon!
I think I'll be doing a 60% build soon w/ these switches to get a better realistic feeling on a board.
Not sure if I follow. What do you mean?
Tops off
Bottom housings:
Underneath:
Haha! You can submit an entry everyday! Might as well take a guess and increase your odds of winning from RNG! :D
Offline byker
  • Literally Canada
Re: Gaterons
« Reply #19 on: Sat, 24 January 2015, 02:01:37 »
Those pictures are great Zeal!!
I am really tempted to try the yellows, if they are like super blacks!  8)
Re: Gaterons
« Reply #20 on: Sat, 24 January 2015, 02:03:08 »
So, when are one of you sending me a switch to play around with?
Offline Zeal
Re: Gaterons
« Reply #21 on: Sat, 24 January 2015, 02:06:27 »
When (and if) you get picked by the RNG gods at the end of the month for my giveaway / when you guess the right switch(es). :p
Re: Gaterons
« Reply #22 on: Sat, 24 January 2015, 02:12:13 »
RNGanesha hates me :(
Offline Evo_Spec
  • (╯°ヮ°)╯︵⌨
Re: Gaterons
« Reply #23 on: Sat, 24 January 2015, 03:46:18 »
I didn't catch that part, awesome.
« Last Edit: Sat, 24 January 2015, 20:00:53 by Evo_Spec »
Offline Hak Foo
  • Make America Clicky Again!
Re: Gaterons
« Reply #24 on: Sat, 24 January 2015, 11:41:25 »
How's the sound on the blues?
The thing I could never get my head around, as a fan of ALPS switches, is how plasticky Cherry Blue and Green sound.
Overton130, Box Pale Blues.
Offline Zeal
Re: Gaterons
« Reply #25 on: Sat, 24 January 2015, 13:11:50 »
I didn't buy any Gateron blues, so I can't comment. Hopefully hwood will receive his purchase soon!
Regarding how "plasticky" Cherry blues sound -- it really depends on the batch they were made, and how much factory lube was applied on the feet. I've had ones that sounded really quiet compared to other blues. For example, the middle "lighter" blue has a nice softer click than the one on the left.
Offline JDBear
Re: Gaterons
« Reply #26 on: Thu, 05 March 2015, 17:13:18 »
Where did you find yellows? I can only find this page http://item.taobao.com/item.htm?spm=a230r.1.14.134.UiQACx&id=41317703873&ns=1#detail
but they are out of stock :/
Offline hwood34
  • underwater squad
  • #1 CL stan
Re: Gaterons
« Reply #27 on: Thu, 05 March 2015, 18:23:52 »
Yeah, the only sellers I find on there are him and love_q, both of which have stopped stocking gaterons
Offline hking0036
Re: Gaterons
« Reply #28 on: Thu, 05 March 2015, 18:47:20 »
what's the orange? Is that just a different angle yellow, or is that orange like I think it is?
Realforce RF87UB 45g Uniform | Leopold FC660C w/ TMK | IBM Model M - 3/24/1997 | IBM Model F 122 - 11/25/1985 ANSI'd w/ TMK | IBM Model F XT in a box
Offline hwood34
  • underwater squad
  • #1 CL stan
Re: Gaterons
« Reply #29 on: Thu, 05 March 2015, 20:26:32 »
I think they changed the color from orange to yellow at some point, but both are 150g
