Author Topic: MJ2 rings when bottoming out.  (Read 1771 times)
Offline oledome
  • not batman
« on: Sun, 18 January 2015, 09:36:15 »
After some deliberation I decided to go with what seemed like a safe bet - the Filco Majestouch 2 Ninja, with Browns. Now I've read some Brown hate around here but I really like how these feel, my first mechanical keyboard and I have almost only good things to say.
My one complaint, and it is quite a big one, is that when bottoming out the keyboard rings, I assume it's the metal plate inside but if anyone could give me a solution to this I would appreciate it, I have light tinnitus in one ear I don't normally hear but this ring is the exact same tone so it manages to draw my attention. I guess O-Rings would help dampen the sound, is there anything I need to know about O-rings as far as quality? O-rings are O-rings right?
Re: MJ2 rings when bottoming out.
« Reply #1 on: Sun, 18 January 2015, 09:38:03 »
It's called ping.  It's a filco feature.
Offline oledome
  • not batman
« Reply #2 on: Sun, 18 January 2015, 09:57:45 »
Put in a couple of O-rings from my switch tester set and that seems to help.
« Reply #3 on: Sun, 18 January 2015, 10:16:15 »
Could also open it up and put some rubber drawer liner under the PCB.
Offline oledome
  • not batman
« Reply #4 on: Sun, 18 January 2015, 10:52:58 »
Interesting, thanks! I'll have to take a look at that. Have you done this yourself?
Offline Dreamre
    • kbdlife
« Reply #5 on: Sun, 18 January 2015, 11:40:18 »
I've done it and it works. Dampens the keyboard all together. This "ringing" is overrated...don't worry too much about it.
Offline oledome
  • not batman
« Reply #6 on: Tue, 10 February 2015, 06:20:37 »
Ok I've tried not to worry about it but it's been nearly a month and this ping is driving me nuts.
Is this the product I'm looking for?
Offline Polymer
« Reply #7 on: Tue, 10 February 2015, 08:09:50 »
Its actually happening on the way up so outside of shortening the travel distance, o-rings, IMO, don't do much. The liner DOES help though...
