Author Topic: Need Advice for a High Quality keyboard  (Read 2602 times)
Offline ManicMatt1125
« on: Wed, 21 January 2015, 15:31:45 »
Hello, I am in the market for a high quality keyboard. Currently I have a Ducky SHine 3, MX blues, Which I like But I want to upgrade to a TKL. I was thinking KMAC but I cannot seem to find them anywhere. Any suggestions for high end keyboards? I have no objection to customs if the meet my criteria ( MX Blue, MX Clear or Topre)
Offline monotagary
  • Keycaps > Rent
Re: Need Advice for a High Quality keyboard
« Reply #1 on: Wed, 21 January 2015, 15:36:57 »
High Quality? TKL? Topre?
Sounds like you need a Realforce 87u 55g.
Offline Defect
« Reply #2 on: Wed, 21 January 2015, 15:40:27 »
Realforce is good quality.  Not high quality.  Plastic case, abs space bar, inconsistent domes.  Nice caps and nice feel, but digilog cases are expensive and hard to come by.
« Reply #3 on: Wed, 21 January 2015, 16:03:02 »
digilog cases can be found on ebay
Offline Hellcatz
« Reply #4 on: Wed, 21 January 2015, 16:38:35 »
If u want a Korean keyboard then try getting a gon. But be ready to blow $350
Offline Sygaldry
  • Edema Ruh
« Reply #5 on: Wed, 21 January 2015, 16:40:47 »
RF87U with Digilog case.
If you don't mind going to a smaller form factor -> HHKB (won't find anything better)
null
Offline intelli78
« Reply #6 on: Wed, 21 January 2015, 16:41:34 »
I... can't agree with that. RFs are on par with any other premium brand out there. Filco, Ducky, KUL, Leopold... Maybe they are not "high quality" compared to a metal custom, but that's not a fair comparison...
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #7 on: Wed, 21 January 2015, 18:35:16 »
I mean, if you're looking for a korean board, you might as well look for others. GON would be the most readily accessible and easiest to obtain board you could find, though you could also get a PCB proxied from winkeyless and find a case seperately
Offline Firebolt1914
  • POM Overlord
« Reply #8 on: Wed, 21 January 2015, 19:45:18 »
Also consider building one yourself if you want an 'end game' keyboard. The experience alone may make it more valuable than other keyboards.
Offline limitz
  • "the old gods stir and will not let me sleep..."
« Reply #9 on: Wed, 21 January 2015, 22:02:26 »
Screw that. HHKB is a **** layout, and has a huge circlejerk surrounding it. It has the symmetrical aesthetics going for it and that's about it.
75% or TKL is so much more efficient.
« Last Edit: Wed, 21 January 2015, 22:07:11 by limitz »
Mmm... machined aluminum
Offline Sygaldry
  • Edema Ruh
« Reply #10 on: Wed, 21 January 2015, 22:06:46 »
Screw that. HHKB is a **** layout. It has the symmetrical aesthetics going for it and that's about it.
You're a **** layout
null
Offline Oobly
« Reply #11 on: Thu, 22 January 2015, 01:55:44 »
GON NS NerD TKL with lubed 62g Clears.... Don't get higher quality than that: http://www.gonskeyboardworks.com/custom-kbds-w-assembly/66-gon-ns-nerd-tkl-w-tuningassembly.html#/4_tuning_leds-side_led_onlyon_off/1_anodizing-hardgrey_dark_grey_only_black_steel_bolts/2_switch_type-new_mx_clears/3_tuning_switches-lub_stickers_62g_springs
It's a custom with a lot of options and incredible attention to detail and build quality. You can save money by buying parts and building it up yourself, but GON's work is second to none.
There are other top quality options, lots of customs out there (LZ, KMAC, 356L N CL, etc.)
I've had fun building up my own board from a GON NerD60 PCB, Vortex aluminium case, the PuLSE SA keycap set and switches sourced from a Cherry G80 (modified with Korean 62g springs from Sprit and "trampoline" silicone balls from IMSTO), which feels simply awesome to type on:
88227-0
All Topre boards are overpriced (and overrated, IMHO). There are practically no aftermarket keycap options (and only two keycap profiles, something like OEM profile and a tall spherical top profile, but you can't put tall caps on a normal board or normal caps on a tall profile board, they use different housings) and very few modding options (you can add lube and flattened dampening pads to make a normal board something like the silenced version). They don't support LED backlighting. There are only 2 variants (unless you consider the Realforce variable), 45g and 55g. Some layouts only come in one switch type (HHKB and FC660C for example only have 45g version, the only uniform 55g version is Realforce). They're all standard, factory-made products, no customs. No aluminium or acrylic case versions available. They're okay if you want the best rubber dome board money can buy.  :p
Buying more keycaps,
it really hacks my wallet,
but I must have them.
« Reply #12 on: Thu, 22 January 2015, 19:41:52 »
Thank you all for the response. I have decided to go with a tkl gon, and now have a whole slew of other options avail. Has anyone bought from them that is able to help me decide on which options to choose?
