Author Topic: Difference Between B.thumb and B.face  (Read 3037 times)
Offline limitz
  • "the old gods stir and will not let me sleep..."
« on: Thu, 22 January 2015, 17:20:03 »
They look identical, and both are 60% PCB and case. What is the difference between the 2 cases and the PCB?
Mmm... machined aluminum
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
Re: Difference Between B.thumb and B.face
« Reply #1 on: Thu, 22 January 2015, 17:40:09 »
Looking at both I can't find absolutely anything different about the two. They both are USB/PS2, same layout, both support macro and key mapping, RGB LED, NKRO, and Mac compatible. I really don't see any other way they could be different
Offline sethk_
  • Grand Master Wizard Pizza
  • www.kbdhub.com
    • My webstore
« Reply #2 on: Thu, 22 January 2015, 17:43:19 »
I have been wondering the same exact thing.
Offline Zeal
    • Zeal Generation Inc.
« Reply #3 on: Fri, 23 January 2015, 16:15:31 »
Bthumb uses surface mount Micro USB, whereas Bface uses surface mount Mini USB.
Offline evolveS
  • ಠ_ಠ
« Reply #4 on: Fri, 23 January 2015, 16:20:46 »
B.thumb owner, can confirm. I'd recommend the B.Face so you wouldn't have to use a little adapter on your usb cable, but that's personal preference.
"money comes and goes, but doubleshots are forever"
-a petty thief
Offline limitz
« Reply #5 on: Fri, 23 January 2015, 16:38:33 »
Thanks. Very minute difference, but a difference nonetheless.
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #6 on: Fri, 23 January 2015, 16:44:56 »
And don't micro break a lot easier?
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #7 on: Fri, 23 January 2015, 18:49:00 »
yeah, just since the connector is thinner it can bend and break really easily
Offline MaNiFeX
  • Wu Tang Killa Keebs
    • MaNiFeX.net
« Reply #8 on: Tue, 27 January 2015, 10:53:23 »
