Author Topic: Good citation generator recommendations?  (Read 1914 times)
Offline Psybin
  • of Rallos Zek
« on: Thu, 22 January 2015, 18:41:33 »
I normally use Bibme or Citation machine, but both are full of annoying web ads, as are most similar generators I've tried.
Does anyone have a good recommendation they regularly use?
Offline exitfire401
  • The Force is Re/\l
Re: Good citation generator recommendations?
« Reply #1 on: Thu, 22 January 2015, 18:43:23 »
I've been using citation machine for years. Guess I just haven't noticed the ads due to adblock.
Offline Psybin
  • of Rallos Zek
« Reply #2 on: Thu, 22 January 2015, 18:44:28 »
I cant run any plug-ins at work  :(
Offline exitfire401
« Reply #3 on: Thu, 22 January 2015, 18:49:07 »
Offline sethk_
  • Grand Master Wizard Pizza
  • www.kbdhub.com
    • My webstore
« Reply #4 on: Thu, 22 January 2015, 18:50:03 »
If this is for like citing sources, then easybib.com , if not, I am really confused.
Offline Psybin
  • of Rallos Zek
« Reply #5 on: Thu, 22 January 2015, 18:52:11 »
Yup, I'll give easybib a try tomorrow. I'm looking for a nice one that is more accurate than bibme and with less adds and nonsense without having to use a plug in.
« Reply #6 on: Thu, 22 January 2015, 18:53:38 »
I just used the one built into MS Word.
Offline Psybin
  • of Rallos Zek
« Reply #7 on: Thu, 22 January 2015, 18:55:06 »
I never noticed that, nice, that may be the way to go at work. Thanks!
Offline byker
  • Literally Canada
« Reply #8 on: Thu, 22 January 2015, 19:00:54 »
Yeah the one in word is really nice, especially because you can have it put the info at the end of quote, and them automatically update the bibliography, etc.
Offline Psybin
  • of Rallos Zek
« Reply #9 on: Thu, 22 January 2015, 19:02:20 »
I'm going to start using it. I probably came across it at one point and completely forgot about it after I started using the online tools.
« Reply #10 on: Thu, 22 January 2015, 19:03:56 »
It's not perfect, but it is good. I used it for my thesis.
« Reply #11 on: Thu, 22 January 2015, 21:07:15 »
Easybib is fairly solid. I've used it for a long time.
Offline Smasher816
  • HHKB Master
« Reply #12 on: Thu, 22 January 2015, 21:12:02 »
I'v also used easybib for a few years. It's auto pulling is decent, and if it is missing anything than you can fill it in yourself and get something formatted correctly.
