Author Topic: Good evening!  (Read 1759 times)
Offline Shanghaied
Good evening!
« on: Mon, 26 January 2015, 15:22:12 »
Hello there!
I'm relatively new to this mechanical keyboard thing, having gotten my first one late last year, and have been lurking here ever since (although having worked retail in the past, I just found out that I've used MX blacks for years without knowing). Looking forward to bleeding money for bits of plastic!
Offline whentheclouds
Re: Good evening!
« Reply #1 on: Mon, 26 January 2015, 15:29:10 »
once it starts bleeding it won't stop. when you file for bankruptcy, you can pinpoint this exact moment as where things started going downhill. but welcome!
Offline byker
  • Literally Canada
Re: Good evening!
« Reply #2 on: Mon, 26 January 2015, 16:52:40 »
Hello and welcome to Geekhack! There are a lot of great people and a lot of knowledge to learn here! Feel free to ask if you have any questions! :)
Offline Evo_Spec
  • (╯°ヮ°)╯︵⌨
Re: Good evening!
« Reply #3 on: Mon, 26 January 2015, 20:03:15 »
Welcome to GH!
unless you don't work there anymore you should see if your company has any extras or old boards that you can maybe have!
GON NerD TKL DTA Edition
Re: Good evening!
« Reply #4 on: Wed, 28 January 2015, 03:50:31 »
Welcome to Geekhack!
Which keyboard have you got now?
I used a terminal keyboard for a couple of years without realising it had MX blacks in it!  After learning that, I had to check all my other old keyboards, but sadly no more mechanical switches.  Although I did find some (mostly) MX-compatible keycaps on an old Gateway keyboard.
Offline Shanghaied
Re: Good evening!
« Reply #5 on: Wed, 28 January 2015, 07:17:08 »
Thank you for the warm welcome!
No idea what they use nowadays, since I'm not there anymore, but it was part of the POS system, with a built-in card reader. It said "Made in UK" on the bottom and weighed about two kilos, despite being quite compact and having a plastic shell. The double-shot enter key was worn through to the white plastic.
I pulled  off a key once out of boredom and saw that it had a switch quite unlike the scissor switch on my laptop, and said "Cherry" on it, which I thought was a very odd name, in a kitschy 80s Asian trademark kind of way, à la Lucky Goldstar. Only recently did I realise it was Cherry MX black.
« Last Edit: Wed, 28 January 2015, 07:20:50 by Shanghaied »
Re: Good evening!
« Reply #6 on: Fri, 30 January 2015, 02:42:10 »
Probably a thick plate, and lots of electronics (especially for the card reader).
Cherry = German company :)
