Author Topic: Numpad with Buckling Springs?  (Read 2899 times)
Offline chuckster
« on: Wed, 28 January 2015, 01:00:59 »
Hello all, in another thread, I professed my love for BS and the need for a numpad to supplement my Leopold F660cM, (the lack of the numpad just became too much, and I can't bear selling such a wonderful board; at least not until the Smart68 becomes a reality). Of course, the Leo 21-key numpad was the obvious first choice, but then I also began thinking about the venerable old buckling spring.
I checked over Unicomp's stock, but didn't see any standalone number-pads, are there any out there that use BS? Any specific models you guys can recommend or at least point me toward for more research?
On a side note, is there a compact keyboard with a numpad but possibly moving the arrow cluster and the keys above them (pg up/down, del, ins, etc.) to an fn layer or somehow compacting them? I know I've seen them, but just don't know what to search for on that front.
Offline MGH
Re: Numpad with Buckling Springs?
« Reply #1 on: Wed, 28 January 2015, 01:03:16 »
Good luck finding one, I'm also on the lookout for one ;D
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #2 on: Wed, 28 January 2015, 07:54:08 »
Yeah, these only came with the split layout BS boards, which are pretty rare themselves. Be prepared to spend a pretty penny if you do find one
Offline 0100010
  • Not Sure
« Reply #3 on: Wed, 28 January 2015, 08:15:10 »
Here are some Model M options : https://geekhack.org/index.php?topic=50000.msg1086173#msg1086173
From memory I think there may be a Model F / M hybrid one as well.
Offline jabbon
« Reply #4 on: Thu, 29 January 2015, 00:49:30 »
cool stuff
« Reply #5 on: Fri, 30 January 2015, 03:12:01 »
