Author Topic: Anyone still interested in these Pingsavers?  (Read 3726 times)
« on: Thu, 29 January 2015, 08:54:38 »
NIB IBM Japanese Lettering Typing Computer 102 Keyboard Letter Type 6112884
Yes, new in box.
Currently BIN $24.95 plus shipping. Seller has 10 left.
Uses tee Alps switches, which ring and ping with every keystroke! Can be converted to work with a modern PC.
Re: Anyone still interested in these Pingsavers?
« Reply #1 on: Thu, 29 January 2015, 08:57:42 »
Same seller has them in Chinese too.  I bought mine off of him via e-mail.  Very nice and easy person to work with.
Offline berserkfan
« Reply #2 on: Thu, 29 January 2015, 10:01:18 »
just for anyone interested, the Pingsavers have smooth alps with high actuation.
I don't know why but to me they feel pretty awful. So this is very subjective, and YMMV is the best way to look at it.
« Reply #3 on: Thu, 29 January 2015, 10:16:47 »
They're fun keyboards, the kind you pull out for a lark.
Offline berserkfan
« Reply #4 on: Thu, 29 January 2015, 10:19:47 »
I would be happy to sell mine, but shipping would cost too much. Really, as I'd said, YMMV.
Offline Touch_It
« Reply #5 on: Thu, 29 January 2015, 10:20:48 »
Yes.  I'm having a hard time justifying any purchase atm though, beings I have keyboards yet to touch/convert and just spent a boat load of money on my 107.  Been wanting to try these switches + the keyboard looks pretty cool.
« Reply #6 on: Thu, 29 January 2015, 10:24:53 »
I kind of want one for wall decor.
Offline 1391406
« Reply #7 on: Thu, 29 January 2015, 11:44:40 »
Personally, I think they look pretty cool. I'm curious how the switches feel and if they're really that bad. Clicky? Actuation force? I don't know. I wish I had an extra $45 laying around to give one a whirl.
« Reply #8 on: Thu, 29 January 2015, 11:46:52 »
The switches are linear green tee Alps, right? I haven't pulled a cap off mine, yet. :)
It's worth the $50 just to be able to open a NIB vintage IBM keyboard, IMO. You break that seal (tape) and open the foam for the first time, take a whiff of pristine plastic and metal....hnnnnng!
Offline engicoder
« Reply #9 on: Thu, 29 January 2015, 12:23:19 »
With these Pingsavers...the whiff is likely to make you a little light headed, at least the one I bought did...years worth or outgassing I guess. If there is a new keyboard smell, these have it!!
Offline 1391406
« Reply #10 on: Thu, 29 January 2015, 12:26:40 »
Ideally I'd buy two. One to use and another to stow away as a collectors item.
« Reply #11 on: Thu, 29 January 2015, 13:23:28 »
Those caps look like they may fit an MX switch, do they? I'd buy it for the caps if this is the case.
Offline MGH
« Reply #12 on: Thu, 29 January 2015, 13:43:41 »
I've been eyeing it for a while but I'm not sure if I need it :-\
Offline orihalcon
« Reply #13 on: Thu, 29 January 2015, 17:07:40 »
What would all be required to convert them to USB? Doubt they have the same type of pinouts or detachable controllers as the regular 4704's to use an xWhatsit without special wiring?
« Reply #14 on: Thu, 29 January 2015, 17:18:25 »
Didn't photoelectric convert hers with a Soarer's converter? I thought it was possible, if I'm remembering correctly.
Offline HPE1000
  • Keycap Paparazzo
« Reply #15 on: Thu, 29 January 2015, 17:18:29 »
All you need is a teensy afaik
I do not believe they fit on MX swtiches.
Offline Xonar
  • Cathode Ray Tubes
    • Winnebago
« Reply #16 on: Thu, 29 January 2015, 20:44:11 »
I'll pick up at least one of these. :) I was totally unaware of this auction until now. I had my eyes on another NIB example of one of these for $125, but I sure am glad I passed on that before I saw this.
IBM Model M SSK Industrial (Mopar) | Ellipse Model F77 (Industrial) | IBM Model F XT 5291 Bigfoot x2 | Unicomp UN4KPHA JP Spacesaver M | IBM Model M 3270 APL 122-Key | SHARP X68000 | Silicon Graphics AT-101 |  Samsung TH-5539 FAME Blue Alps | IBM Japanese Pingmaster | IBM Model M 1392595, 6/4/1990 | IBM Model M 1391401, 2/2/1988 | Lexmark-branded 1398601 Model M, 8/18/1995 | Apple Extended Keyboard II | Unicomp UB40T5A 122-Key, 5/20/2011 | Sun Type 4 | Sun Type 5c | DEC LK-401AA
Offline jacobolus
« Reply #17 on: Thu, 29 January 2015, 22:21:02 »
These have been posted at least 5-6 times. Neat boards, great keycaps.
These are tee-mount Alps. The caps are not compatible with MX switches.
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #18 on: Thu, 29 January 2015, 23:13:46 »
Just a tip, the pinging and most of the noise from the boards can be fixed by taking out the PCB and handwiring it. Not a particularly easy solution, but it works nonetheless
« Reply #19 on: Thu, 29 January 2015, 23:19:20 »
But the pinging is half the fun!
Offline orihalcon
« Reply #20 on: Thu, 29 January 2015, 23:28:41 »
Yeah, if you were to hand wire and use diodes, it can be NKRO with a teensy, but I've been waiting for someone to try it with a hand wired Xwhatsit instead. Xwhatsit says his controllers will work that way too. I'd prefer that for the ease of programming over the Teensy, but have still yet to get around to actually trying it. Need to trying it with a few switches with diodes as a proof of concept before going after a whole board.
Idea is similar to this Apple M0110 (which also uses T-Alps interestingly enough) and also has a sound clip showing how much quieter it is without the PCB, though they also changed out the springs as well:
http://deskthority.net/workshop-f7/the-apple-m0110-today-t1067.html
« Last Edit: Fri, 30 January 2015, 00:26:27 by orihalcon »
