Author Topic: HHKB layout issues  (Read 2135 times)
Offline JunkFace
HHKB layout issues
« on: Fri, 30 January 2015, 07:38:57 »
Hey I just got a HHKB Pro finally after using a lite which I got pretty used to.  There are a couple problems thought, my dip switches don't seem to be working.
What I would like is for left alt and the diamond key to switch,  and for the *old* alt key to be fn.  I'm not sure if this is possible either but I would like my right diamond key to be the windows key so it looks like this:
                                       fn    alt                                      Space                                           windows    alt
no matter which combination of dipswitches I throw and how many times I restart it doesn't want to cooperate.
Maybe someone around here can help me out?
Offline Keybatant
  • topre and cigar
Re: HHKB layout issues
« Reply #1 on: Fri, 30 January 2015, 07:58:31 »
Switch nr 4 (on) will change left diamond key to FN
then switch nr 5 (on) will change diamond keys to alt
I use similar what you trying to achieve.
1,3,4,5 on - so Lite mode on, Delete as BS etc
Remember to unplug keyb every time you make changes
Otherwise it can be firmware/hardware issue or you can try another operating system...
« Last Edit: Fri, 30 January 2015, 08:00:23 by Keybatant »
« Reply #2 on: Fri, 30 January 2015, 07:59:45 »
Not sure if it will help but when changing dip switches you want to unplug the board, change the dip switch, then plug it back in.
Offline JunkFace
« Reply #3 on: Fri, 30 January 2015, 08:30:52 »
Wow, unplug it, I had been restarting my PC this whole time and it didn't work.  Thank you guys so much 1000x better :)
« Last Edit: Fri, 30 January 2015, 08:40:54 by JunkFace »
« Reply #4 on: Sat, 31 January 2015, 01:29:26 »
It's often the little things that are overlooked ;)
Offline Novus
  • Formerly the1onewolf
  • Mondai nothing~
« Reply #5 on: Sat, 31 January 2015, 03:39:30 »
lol hahhaha.
How hard did you whack yourself =P
