Author Topic: How to open an unopenable IBM M  (Read 4731 times)
Offline Spyre
« on: Sun, 08 February 2015, 16:09:16 »
second time writing this, i hope this works now
So, i got myself a cannon screw 7/32", but my keyboard was so ****ed lame, that i couldn't open with it.
btw, that wasn't cheap. I bought it for 16R$, that's 7$US.
inb4, i saw some random guy on the internet laughing about using a pen to open the keyboard, but, yolo, i tried.
Guys, it worked out. LIKE ****ING MAGIC. Seriously, 5 days and 16R$ after...
You need: -Heat
               -Cheap pen (I stole mine from my sister, IT'S FREE)
               -Heavy Metal
Take the tube of the pen, or whatever that stuff is called, and heat the edge, but not that much. Then, put into the screw, and
apply some pressure. Wait till it gets cold, and be happy with the cheapest 7/32" in the world. No drills, no money spent.
SWEET.
My first real topic here, and i apologize for my horrendous english. Correct me, please.
I hope i could help, and this should work with other Keyboards and stuff lol
Offline o0002
Re: How to open an unopenable IBM M
« Reply #1 on: Sun, 08 February 2015, 16:13:15 »
Thanks for sharing that with us  ;D
Are you going to attempt a bolt mod?
Dell AT102w, Chicony 5192
Offline Spyre
« Reply #2 on: Sun, 08 February 2015, 16:19:15 »
Not really. I think i can't do it by myself :P And i can't make someone get the job done, because no one here can do it either. XD
Offline o0002
« Reply #3 on: Sun, 08 February 2015, 16:23:00 »
These YouTube videos make it look easy:
« Reply #4 on: Sun, 08 February 2015, 16:25:09 »
Ha Ha Ha
You are young, am I right?
Acquire tools all your life. It is a pain to cart them around with you, but they make every task easier.
- D Trump 2026-10-24
Offline Spyre
« Reply #5 on: Sun, 08 February 2015, 16:27:52 »
Ha Ha Ha
I am! :D Only 16. Yes, that is the kind of tip that i want to hear. Thank you very much :d
I didn't know that i can find that stuff on YouTube lol This make my life easier, at some point. Thanks for sharing :d
Offline o0002
« Reply #6 on: Sun, 08 February 2015, 16:33:16 »
I have not yet managed to acquire a Model M but I'm looking forward to attempting a bolt mod. It doesn't actually look too difficult. Or am I being overconfident?
Offline Spyre
« Reply #7 on: Sun, 08 February 2015, 16:49:14 »
Well, at least for me, looks like if i touch the rivets, the keyboard will be dead forever and ever. I am kinda scared to repair this keyboard, i know i can't find another one XD
« Reply #8 on: Sun, 08 February 2015, 16:49:28 »
If you can drill several dozen very small holes very accurately there are no other significant problems.
Offline Spyre
« Reply #9 on: Sun, 08 February 2015, 16:55:47 »
NOT EVEN SCARED. /irony
Offline o0002
« Reply #10 on: Sun, 08 February 2015, 17:05:38 »
In that first YouTube video that I posted the chap uses some sort of fixed drill (that's the technical term  :p) to make the holes. Obviously I don't own one of them but I have managed to drill many holes into walls over the years without too many mishaps. Is it possible to drill freehand as it were?
Offline o0002
Offline Spyre
« Reply #12 on: Sun, 08 February 2015, 17:55:08 »
Maybe i'll do it, maybe i won't. If i get money enough for a drill :P
« Reply #13 on: Sun, 08 February 2015, 17:57:31 »
What he skips over briefly at the 7 minute mark is the crucial aspect of the whole affair.
Without a drill press, you need to use a tool like a Dremel, with a sharp fresh bit, at the slowest possible setting, held with both hands, wearing safety glasses and moving in very close, to drill straight down.
Having a "starter" to keep the drill from "walking" is of utmost importance. The best method is to create a small depression with a tiny spherical burr tip on your Dremel. The 2nd best is to use a pointed tip on your soldering iron to make a crater at the center of what was previously the shaft of the rivet.
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« Reply #14 on: Sun, 08 February 2015, 18:03:16 »
Oh wow! Thanks, I haven't been able to open up my Model Ms due to not having the nut driver yet, definitely giving this a try soon :D .
Do you have to do this with a loose 7/32" screw, or can you do it into a Model M channel directly?
Offline Spyre
« Reply #15 on: Sun, 08 February 2015, 18:11:45 »
Into the Model M :) The plastic doesn't stuck if it's cold, and you can easily remove. And no residues. :3
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #16 on: Sun, 08 February 2015, 18:22:27 »
That certainly is an odd way of doing it ^-^
Offline Oobly
« Reply #18 on: Mon, 09 February 2015, 02:36:26 »
Ha Ha Ha
If you don't mind me adding my thoughts on this: Buy good quality tools. Good tools will be useful your whole life and it's worth spending a bit to get decent quality ones. You don't need to get Snap-On / Stahlwille when you're young and can't afford it, but don't get non-branded junk. It's better to get one great screwdriver that'll do the job forever than a set of cheaper drivers that won't last.
On the other hand, this is a rather non-standard tool size and will not likely be needed again (unless you get into modding model M's as a living?), so the makeshift tool is absolutely fine in this situation.
« Last Edit: Mon, 09 February 2015, 02:55:18 by Oobly »
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline Snowdog993
  • Grace Under Pressure
  • Justifiably Clueless.
« Reply #19 on: Mon, 09 February 2015, 02:52:17 »
If you have a Home Depot or Lowe's nearby, you can also get a 1/4" 5.5mm deep socket.  The Kobalt version shown in the picture is actually attached to a plastic key-type mold that works perfectly as a do-it-yourself 5.5mm (or 7/32") driver.
It's about $3 at Lowes, but you can find them at any hardware store that sells them.
Edit: Had to show off the tool!
« Last Edit: Thu, 12 March 2015, 10:22:53 by Snowdog993 »
Offline bueller
  • MX baller
  • Church of the Ergo Clear
« Reply #20 on: Mon, 09 February 2015, 02:57:25 »
Ha Ha Ha
This. I saw tools as disposable when I was younger and would constantly lose them, now that I have a good tool box I find doing DIY tasks so much easier with the right hardware. It does cost a little bit to get set up but if you buy bits and pieces slowly within a couple of years you should have most stuff covered.
Offline pr0ximity
« Reply #21 on: Mon, 09 February 2015, 07:33:00 »
If you have patience, this is not as intimidating as it sounds. I bolted mine by hand with a dremel and only one of the holes I drilled was off-center enough not to use, the rest were within the needed tolerance. I found the old soldering iron method was best for me, a spherical tip on the dremel moved around too much by itself on the uneven rivet stub, but one with steadier mitts than me might have more luck.
« Reply #22 on: Mon, 09 February 2015, 08:01:49 »
I use chisel tips on an Xacto knife. I use an older imperfect blade to cut off the rivet heads to separate the plates.
Then I switch to a fresh clean sharp blade and carefully trim the cut shafts into "flat-topped mesas"
I would not even try to drill out the shafts without this step! (note: I have a couple of dozen bolt-mods, all by hand)
After drilling the holes, I use my chisel tip Xacto for the 3rd time, to trim and flatten each one yet again.
In every case, I try to leave the shaft as long as possible (after all, those shafts have been going through the holes all along).
I put on my reading glasses to get very close, use both hands on the knife, resting my wrists on the surface, and push the chisel point straight away from me.
Offline XMIT
  • formerly jsoltren
« Reply #23 on: Mon, 09 February 2015, 13:08:14 »
I keep a 5.5mm deep socket driver in a drawer just for keyboard work. I've probably used it to open a dozen keyboards at this point. I'm going to invest in a 4mm shallow socket driver for bolt mod work as well. Even if I already have the tool in the garage it is nice to have a dedicated one.
I will second everything that everyone said before me about acquiring tools, particularly quality ones. For most jobs the correct tool costs about as much as the labor to ask someone else to do it, and then you learn something, can do it again for free, and can charge others for your services.
In particular, maintainable tools are really excellent. If you have an Allen key (hex key) and the tip gets rounded, you can just grind it down to get a fresh tip. Not so many tools are serviceable like this but some are.
As for removing rivets for bolt mods - I recently got a chisel tool, with a sharp leading edge and a big sturdy handle. I have not used it yet but I suspect it will work really well. (I can re-sharpen it in the future if need be.)
Offline o0002
« Reply #24 on: Mon, 09 February 2015, 14:41:08 »
Reading about people's experiences in bolt modding is really helpful. Gives me a lot more confidence.
