Author Topic: gray vs clear  (Read 3900 times)
Offline Jixr
gray vs clear
« on: Sun, 08 February 2015, 21:34:21 »
I'm a bit confused and looking for an answer.
Is the mx gray ( tactile ) stem the same as clears or browns?
Offline Synjin
Re: gray vs clear
« Reply #1 on: Sun, 08 February 2015, 21:34:45 »
Same as clears with a heavier spring.
  • Live long and prosper
Re: gray vs clear
« Reply #2 on: Sun, 08 February 2015, 21:41:08 »
there are tactile greys and linear greys
tp thread is tp thread
Offline Synjin
Re: gray vs clear
« Reply #3 on: Sun, 08 February 2015, 21:41:48 »
Thought ilhe was asking specifically about the tactiles.
Re: gray vs clear
« Reply #4 on: Sun, 08 February 2015, 21:43:11 »
Yes there are.  In either case, greys are heavier than Clears, be they linear or tactile.
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
Re: gray vs clear
« Reply #5 on: Sun, 08 February 2015, 21:44:30 »
OP specified tactile greys. So yes, the same
Re: gray vs clear
« Reply #6 on: Sun, 08 February 2015, 21:48:55 »
derp
how did i miss that...
Offline rand77
Re: gray vs clear
« Reply #7 on: Sun, 08 February 2015, 22:42:06 »
Just some observations from my switch tester.  The gray feels MUCH heavier due to the heavier spring.
As others said, it seems to be the same mold ( and hence shape) for the slider.   The difference is in the spring and color of plastic for the stem.
Offline spiritistz
  • Daily Driver: RF 87U 55g
    • http://bgm.tv/
Re: gray vs clear
« Reply #8 on: Tue, 10 February 2015, 09:36:32 »
From heaviest:
Grey > Clear > Brown
Filco NINJA Brown Switch for sale.
Offline Bromono
  • Wanabe Cicerone
  • HHKB > Your Opinion
Re: gray vs clear
« Reply #9 on: Tue, 10 February 2015, 11:48:37 »
From heaviest:
Why do ergo clears feel so much better then browns then X|
Offline Synjin
Re: gray vs clear
« Reply #10 on: Tue, 10 February 2015, 11:53:17 »
I believe that the location of the tactile bump is different. Definitely gritty compared to the clears.
Re: gray vs clear
« Reply #11 on: Tue, 10 February 2015, 11:54:59 »
not location, size
browns have a very slight tactile bump, where as clears/greys have a much more pronounced bump
Offline Bromono
  • Wanabe Cicerone
Re: gray vs clear
« Reply #12 on: Tue, 10 February 2015, 12:01:13 »
not location, size
So there is potential for ergo greys then?
Re: gray vs clear
« Reply #13 on: Tue, 10 February 2015, 12:01:52 »
not location, size
greys and clears have identical stems, just different colors
so yes
Offline Synjin
Re: gray vs clear
« Reply #14 on: Tue, 10 February 2015, 12:01:56 »
Yeah but most people agree that the bump feels gritty and scratchy.
Offline Synjin
Re: gray vs clear
« Reply #15 on: Tue, 10 February 2015, 12:02:48 »
I should stop talking. I don't know what I'm talking about now.
Offline Oobly
Re: gray vs clear
« Reply #16 on: Wed, 11 February 2015, 03:46:55 »
not location, size
Ergo greys = ErgoClears, assuming it's the tactile greys. Same slider mold, same big tactile bump. Great feeling switch :)
The bump doesn't necessarily feel gritty or scratchy. The sliders of all modern MX switches are scratchy when new. They need to be worn in and this goes away. Some compare the tactile bump on browns to there being a grain of rice in a Red switch and some are a lot harsher with their description of how they feel and say it feels like a dirty / scratchy Red switch.
In general, stronger springs make the bump feel smaller, lighter make it feel bigger. It's really just a reduction in relative tactility due to the ratios of forces, but the result is they feel more tactile with lighter springs.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline Anole
Re: gray vs clear
« Reply #17 on: Wed, 11 February 2015, 19:05:15 »
Super blacks > Blacks
Grays > Clears
Offline katushkin
  • Too Keycool for School
  • Just the guy
Re: gray vs clear
« Reply #18 on: Wed, 11 February 2015, 19:09:35 »
I've got a big pack of greys that I want to put into my KC108 but I need someone to solder them in for me :(
I really want to try them.
Re: gray vs clear
« Reply #19 on: Wed, 11 February 2015, 19:10:28 »
Grays > Clears
You can't really type on super blacks.
Grays are heavy but usable.
Re: gray vs clear
« Reply #20 on: Wed, 11 February 2015, 19:18:09 »
Is Britbong anywhere near England?
Offline katushkin
  • Just the guy
Re: gray vs clear
« Reply #21 on: Wed, 11 February 2015, 19:19:21 »
It is very near England :)
