Author Topic: I'm looking for a Cherry mx KEY sampler,any recommendations guys?  (Read 1639 times)
Offline Nikelu
  • Don't read this!
« on: Wed, 11 February 2015, 08:23:30 »
I want to buy a cherry mx red keyboard and I am not 100% sure if that's my switch .I would like to try 3-4 switches more.I saw max keyboard has a 8 switch sampler,WASD has 6 switch,havent checked others yet.Any opinions or suggestions
Re: I'm looking for a Cherry mx KEY sampler,any recommendations guys?
« Reply #1 on: Wed, 11 February 2015, 08:27:53 »
A couple of years ago there were a couple of samplers that went on tour.
Whoever has them might be convinced to send them out again.
This https://geekhack.org/index.php?topic=31341.msg597368#msg597368 was one of them.
« Last Edit: Wed, 11 February 2015, 08:30:24 by fohat.digs »
- D Trump 2026-10-24
Offline Ludovician
« Reply #2 on: Wed, 11 February 2015, 08:32:24 »
The ones you've already seen are probably the best you're going to get. The most common switches you'd find in every vendor's store would be Red, Brown, Black and Blue. The sampler I got only had those four options, so the others you mentioned sound like they would be better.
Typing speed:
My collection:
HHKB Pro 2 (Blank, white) | HHKB Pro 2 Type-S (Blank, white) | Topre Realforce 87UB silent-modded (not currently functional) | Das Keyboard Model S Professional Silent (MX Brown) | IBM Model M 1391401 - 9th January 1991 (Bolt+Floss-modded) | Apple keyboard m0116 (Orange Alps) | Unidentified DIN Keyboard (White Alps) | ADDS 1010 (Green Alps) | AEK II (Linear-modded, USB-converted) | IBM PC-AT Model F | Noppoo Choc Mini (MX Black) | Amstrad PC2286 | BigKeys LX | IBM Model M 1391401 - 6th September 1990 | IBM Model M2 1395300 - 28th February 1991 | Leopold FC660C | Cherry G80-11802 (MX Brown) | Matias Tactile Pro (Simplfied grey Alps) | Razer Blackwidow (MX Blue) | Novatouch 55g | Focus FK-2001 (White alps) | DSE Multitech (Blue alps) | Dell AT101W (Matias quiet) | Pok3r (White w/Clears) | KBP V80 (Blue Alps)
Pending:
Infinity kit
Offline drewba
« Reply #3 on: Wed, 11 February 2015, 09:32:17 »
I have a MAX Keyboard 8 switch sampler - I'd only recommend that one if you're at all interested in MX Clear, White or Grey. You could also purchase the MAX 4 switch tester & buy individual switches (for instance, clear, white or grey) to test them out. I'm sure that isn't cost effective, but you're able to do that if you like. MAX switch samplers come unassembled so you need to install each switch in to the base yourself. This lets you be in charge of your switch orientation and lets you swap switches if you like in the future.
I believe you can also do that with the WASD switch tester but I'm not 100% sure because I do not own one.
« Last Edit: Wed, 11 February 2015, 09:34:13 by drewba »
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #4 on: Wed, 11 February 2015, 10:51:18 »
Those readily testers would be fine for what you want. There's also a pretty comprehensive tester one Taobao that includes stuff like Nixdorfs
Offline Dihedral
  • Mostly Harmless
« Reply #5 on: Wed, 11 February 2015, 12:40:20 »
Just buy a switch tester. There's a few to choose from and they're all essentially the same. WASD's one is probably a good option (the one with a steel mount).
