Author Topic: Active PS/2 male to USB female  (Read 6069 times)
Offline Conditioned
« on: Sat, 14 February 2015, 03:56:11 »
Hey,
So I'm trying to figure out a way to connect my Topre 105/u via the ps/2 port. A regular usb f to ps/2-m won't do, apparently the adaptor has to be active. However during my search I have only found active adaptors that work the other way around, ie usb m to ps/2 f.
Do you know a specific one that works the way I describe, that is active ps/2 male and usb female?
Thanks in advance!
Antec p183, I5@4.01 ghz, 6Gb Kingston Ram,1200w Corsair psu, Intel 80 gb ssd, 3TB Storage (Seagate), Asus Essence STX with AKG K701, Gigabyte 480 gtx, Dell 2048 WFP 24" + Benq xl2410t 120hz 23,6", Razer Deathadder 3g with Goliathus Control, Netgear Wnr 3500 running Tomato USB w/ 500 gb storage
Offline Daniel Beardsmore
  • RIP
    • Boring twaddle
Re: Active PS/2 male to USB female
« Reply #1 on: Sat, 14 February 2015, 08:16:04 »
You have a computer too old to have USB ports? An old laptop to which you can't fit a USB PCI card?
Bore Awards
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #2 on: Sat, 14 February 2015, 13:27:57 »
I don't think I've ever seen an active converter, though I don't think I've ever seen anyone with your problem
Offline Conditioned
  • RIP
    • Boring twaddle
« Reply #4 on: Sat, 14 February 2015, 15:12:46 »
Bore Awards
Offline 0100010
  • Not Sure
Offline Conditioned
« Reply #6 on: Thu, 19 February 2015, 15:23:17 »
Thanks for your reply. Ouch that is pricey indeed.
Offline wyatt8740
  • Machine code enthusiast
« Reply #7 on: Thu, 19 February 2015, 17:05:00 »
I've read about people using an arduino to communicate with a computer PS/2 port (act as a PS/2 keyboard). With a USB host shield for one you could probably make the adaptor.
I don't usually collect things, but when I do, they're from the 70's, 80's, and 90's. My typing speed: 79 WPM
IBM Model M 1386303, 1987 / IBM Model M 1391401, 1993 / IBM Model M 59G7980, 1993 / Unicomp "Mini M" UT40E7A (modded), 2021 / Dell AT101W, 1994 (Black Alps) / Apple Extended Keyboard (Orange Alps), 1987 / Sun Type 5, unknown year (Rubber Dome)
Offline FrostyToast
  • Litshoard
« Reply #8 on: Thu, 19 February 2015, 17:07:54 »
I want to know why you are so keen on using your board with PS/2.
I mean, there is sort of the benefit that PS/2 is "faster" however that really shouldn't matter to anyone IMO.
Since the PS/2 port isn't simply plug-and-play, it just makes it that much less convenient to use.
Quote from: elton5354
Offline hwood34
  • underwater squad
  • #1 CL stan
Offline FrostyToast
  • Litshoard
« Reply #10 on: Thu, 19 February 2015, 17:16:00 »
http://deskthority.net/keyboards-f2/how-to-connect-usb-keyboard-to-ps-2-socket-t8426.html
Summary: The converter exists, but a KVM is cheaper.
http://www.startech.com/Server-Management/KVM-Switches/PS-2-to-USB-Keyboard-and-Mouse-Adapter~PS22USB
Nice!  Did not know such a thing existed.  Indeed very pricy.
WOW :eek:
I am not experience in any way whatsoever with these sorts of things, but could an active converter really cost that much?
Is there anyone here who has done a DIY project for this?
Offline 0100010
  • Not Sure
« Reply #11 on: Tue, 24 March 2015, 17:15:26 »
Found another item like this - a bit cheaper though.
Tripp Lite Minicom PS/2 to USB Converter  http://www.tripplite.com/products/series/sid/1019
Offline orihalcon
« Reply #12 on: Wed, 25 March 2015, 23:26:38 »
Most high end mechanical keyboards will work with a passive USB to PS/2 adapter.  Most of them actually require that to get NKRO.  Usually the description will mention something like NKRO over PS/2 or 6 KRO over USB. My guess is that the PS/2 adapter you are using is for mice and not keyboards.  Keyboard ones tend to be purple in color. Mice are green. Not sure on your specific model, but it seems to say that it is PS/2 compatible for the 105/ub, though not sure what the B in the part number means.
Offline Conditioned
« Reply #13 on: Tue, 21 April 2015, 16:35:46 »
No I've tried purple, thanks though. I tested another keyboard so I know the ps/2 converter and the ps/2 port are working fine. May I ask where you find info on the 105u supporting ps/2 through a converter?
« Last Edit: Wed, 22 April 2015, 00:46:53 by Conditioned »
