Author Topic: [GB] Gateron Switch (CLOSED)  (Read 1110898 times)
Offline ideus
  • Björkö.
Re: [GB] Gateron Switches
« Reply #450 on: Tue, 24 February 2015, 12:32:37 »
In other words, you can use the Gateron blacks stock, and they will feel almost like 68g (Korean) lubed MX blacks. Or you can lube them, and they will feel like lubed vintage blacks. :)
Wow! Go blacks!
Offline Zeal
    • Zeal Generation Inc.
« Reply #451 on: Tue, 24 February 2015, 12:55:27 »
Blacks are a couple hundred away from hitting 20k...
Offline joey
« Reply #452 on: Tue, 24 February 2015, 12:56:21 »
Will the OP be updated with numbers soon? :)
« Reply #453 on: Tue, 24 February 2015, 12:59:59 »
I hope so because black will be up to 20K or over!
Offline samsonite727
« Reply #454 on: Tue, 24 February 2015, 13:02:46 »
Wanna change my order.
Just 100 blacks please.
I already pm'd hdwood do I have to refill the order form again?
EDIT: Read the first page, PM is all that is needed.
« Last Edit: Tue, 24 February 2015, 14:14:29 by samsonite727 »
Offline strict
  • TKL Zealot
« Reply #455 on: Tue, 24 February 2015, 13:05:24 »
All this talk of clears being unusable with stock springs is dis-concerning, it sounds like they are ALOT lighter than the cherry reds.
They are. You don't want clears unless you are prepared to spring swap.
+1 ... I like Cherry Reds and typed on them for 7 months straight, but the springs in Gateron Clears are noticeably lighter than Reds. Basically to the point of being unusably light.
Offline Zeal
« Reply #456 on: Tue, 24 February 2015, 13:08:57 »
You upped it past 20k.
« Reply #457 on: Tue, 24 February 2015, 13:09:36 »
You upped it to 20k.
I tried!
Offline VanGhost
« Reply #458 on: Tue, 24 February 2015, 15:14:09 »
I'm going to be using 78g Korean springs on Stricts recommendation. What would be a good lube to complete the ultimate linear?
« Reply #459 on: Tue, 24 February 2015, 15:27:51 »
Krytox.
If you buy it premixed, you want thin.
Offline Ngt
« Reply #460 on: Tue, 24 February 2015, 15:33:59 »
Krytox.
What about the red lube sold by EK? I'm asking because I have it so I wonder what it is worth.
EDIT: https://elitekeyboards.com/products.php?sub=access,misc&pid=mechlube_2
« Reply #461 on: Tue, 24 February 2015, 15:40:40 »
Krytox.
NOTHING BUT KRYTOX.
« Reply #462 on: Tue, 24 February 2015, 15:42:11 »
Krytox.
NOTHING BUT KRYTOX.
But superlube is ok right jd?
« Reply #463 on: Tue, 24 February 2015, 15:42:40 »
Krytox.
NOTHING BUT KRYTOX.
:llama:
Offline VanGhost
« Reply #464 on: Tue, 24 February 2015, 15:49:21 »
Krytox.
NOTHING BUT KRYTOX.
Is there a specific one that you could recommend? I thought that they evaporated after some time and left behind residue making the switch even stickier - any truth to that? Also could I use the same lube for the springs? I'm trying to protect my wallet!
« Reply #465 on: Tue, 24 February 2015, 15:53:37 »
http://techkeys.us/collections/accessories/products/krytox-switch-lurbricant
Sold out on geekhackers.org, and [CTRL]ALT store is down. But you can always PM BunnyLake to order, too.
Krytox doesn't evaporate, so you never need to reapply. You COULD use Krytox for springs, but it is expensive for that purpose. I recommend Victorinox Multi Tool Oil.
Offline wlhlm
« Reply #466 on: Tue, 24 February 2015, 15:55:41 »
Krytox.
I tried it for Ergo Clears and it resulted in making the switch mushier, it is pretty thick. Maybe I used too much , but I feel like it's more for stabilizers than switches.
Offline Ngt
« Reply #467 on: Tue, 24 February 2015, 15:58:45 »
Damn I tried to find some Krytox lube when I was looking for some. I wasn't able to put my hands on some. I guess I didn't look well enough.
Considering the Mecklube 2, have you ever tried it and can speak from experience that it is not good enough? Or have you only tried Krytox, as you know it works well you recommend it?
« Reply #468 on: Tue, 24 February 2015, 16:05:41 »
I haven't tried Mechlube 2, but I don't think anything can come close to Krytox. There was a post by mkawa that explains its properties. I'll see if I can find it.
Edit: here it is https://geekhack.org/index.php?topic=58312.0
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #469 on: Tue, 24 February 2015, 16:08:35 »
updated
Offline Ngt
« Reply #470 on: Tue, 24 February 2015, 16:15:20 »
Damn that was informative but it was not the kind of explanation I thought it would be. Thanks for the link.
I feel like you cannot find Krytox in Europe. Last time I checked the only offer were from the US.
« Reply #471 on: Tue, 24 February 2015, 16:16:24 »
Send BunnyLake a PM. I believe he has some stock, even though his store is offline.
Offline Ngt
« Reply #472 on: Tue, 24 February 2015, 16:17:06 »
Alright I'll check that out. Thanks.
Offline i3oilermaker
  • techkeys.us
    • TechKeys
« Reply #473 on: Tue, 24 February 2015, 16:28:07 »
TechKeys Ships to Europe and with free shipping on orders over $50
Offline Ngt
« Reply #474 on: Tue, 24 February 2015, 16:32:15 »
Yeah JD posted it a few posts ago. I'm not sure I'll be ordering more than $50 so I'll be paying $9 for the delivery. I'll just go for the cheapest one I can find considering it is the same product.
Offline VanGhost
« Reply #475 on: Tue, 24 February 2015, 16:45:36 »
To apply lube with a syringe, would you just put a dot in the recommended areas or would you still use a brush or something to spread it out?
Offline Zeal
« Reply #476 on: Tue, 24 February 2015, 16:46:55 »
I prefer using the yellow brush tip to place an even coating on the friction points.
Offline Ngt
« Reply #477 on: Tue, 24 February 2015, 16:48:05 »
Yellow brush tip?
Offline azhdar
  • Praise the AZERTY god
« Reply #478 on: Tue, 24 February 2015, 16:49:16 »
Yellow brush tip?
http://zealpc.net/collections/accessories/products/geekhackers-v2-lube-kit
first time lubing, and I gotta say it's a great tool to manage a consitent lubing
Azerty Propagandiste
Offline Ngt
« Reply #479 on: Tue, 24 February 2015, 16:51:26 »
Yellow brush tip?
Thank you. Wouldn't a thin paint brush do the trick too?
Offline azhdar
« Reply #480 on: Tue, 24 February 2015, 16:53:39 »
Yellow brush tip?
ofc why wouldn't it.
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #481 on: Tue, 24 February 2015, 17:11:58 »
Yellow brush tip?
Yes, I use a small nylon brush.  Keep in mind that is actually pretty easy to over lube.  If you put too much lube the switches will feel mushy for about a month or so.  I use a paint brush and I paint on a SUPER thin layer.  I am mixing my own Krytox lube (I have both oil and grease), so I had to play with it a bit before I got a mixture that I liked.
Offline meow a cat
  • Resistance is futile.
« Reply #482 on: Tue, 24 February 2015, 18:14:00 »
So, today a package from Zeal arrived, and inside of it he included a lubed Gateron clear with a 62g spring. I de-soldered the Cherry escape switch off of my Phantom, and replaced it with the Gateron.
It is a REALLY smooth switch, as everyone has been saying. I'm definitely glad I joined this GB now that I've had a chance to sample one switch.  :thumb:
It's like.. plastic butter.
Boards:
Offline TheCultOfKaos
« Reply #483 on: Tue, 24 February 2015, 18:14:33 »
Just ordered 100 blues, 100 browns.
Thanks a ton! Building my first keyboard for my birthday next month and was looking for a good deal. Got my waterjet class next friday so Im hoping to cut the plates these will go in soon too!
Offline sethk_
  • Grand Master Wizard Pizza
  • www.kbdhub.com
    • My webstore
« Reply #484 on: Tue, 24 February 2015, 18:15:36 »
If you haven't already, you should check out builder.swillkb.com for building your plate w/ a case.
Offline wlhlm
« Reply #485 on: Tue, 24 February 2015, 18:17:17 »
Wow, awesome tool! Didn't know it existed.
Offline VanGhost
« Reply #486 on: Tue, 24 February 2015, 19:09:25 »
Can anyone who is already using the switches comment on whether or not they ping the same way as MX?
« Reply #487 on: Tue, 24 February 2015, 19:15:57 »
Switches are not what causes ping. The case and plate materials and construction are what causes ping. MX switches can be used in a quality keyboard with zero ping. And I have an IBM keyboard with tee Alps that pings like crazy. Topre don't really ping, due to the nature of the slider mechanism in the plate. That's why they thock. :)
Offline Zeal
« Reply #488 on: Tue, 24 February 2015, 19:39:41 »
Some customs springs w/o lube can also ping at times.
Offline LXXXIX
  • Just remember all caps when you spell the man name
« Reply #489 on: Tue, 24 February 2015, 19:41:08 »
In addition, I believe the material and thickness of keycaps also minimally contributes to "pinging." Correct me if I'm wrong please.
Offline awhitedev
« Reply #490 on: Tue, 24 February 2015, 20:44:44 »
Looks like clears and blacks are now above 20k! Awesome! Sounds like this is a done deal then.
Have you guys spoken to Gateron about these quantities? I'm sure they are more than happy to sell you this many switches... but how's their stock? Do they envision their being supply issues?
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #491 on: Tue, 24 February 2015, 20:48:53 »
The amounts we're getting right now are on the lower end of the spectrum of order size for Gateron. They can crank out a hell of a lot more than this is not a lot of time
Offline vindaon
« Reply #492 on: Tue, 24 February 2015, 22:10:55 »
Down for a 100 each clears and blacks. I was curious if it was possible that I could submit payment now, as they both seem to have hit the 20k mark and I like to have my affairs sorted ASAP.
Offline ideus
  • Björkö.
« Reply #493 on: Tue, 24 February 2015, 22:14:13 »
Now blues should reach the 20k.
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #494 on: Tue, 24 February 2015, 22:14:13 »
All invoices will be going out at the same time, sorry.
Offline awhitedev
« Reply #495 on: Tue, 24 February 2015, 22:15:52 »
Good to know! Thanks for clarifying.
Offline vindaon
« Reply #496 on: Tue, 24 February 2015, 22:16:29 »
That's fine, I was expecting that answer. Figured it wouldn't hurt to ask. :thumb:
Offline alex952
« Reply #497 on: Wed, 25 February 2015, 02:42:00 »
Could someone advise on a place to get some springs for the clears? Also, what would be your choice of spring for these switches?
Offline Moralless
« Reply #498 on: Wed, 25 February 2015, 02:48:14 »
Here you go mate: http://zealpc.net/collections/accessories/products/18k-gold-plated-springs-100pcs
Offline Ngt
« Reply #499 on: Wed, 25 February 2015, 03:10:27 »
Yellow brush tip?
If you put too much of it, is it possible to wash it away? It seems that the Krytox doesn't evaporate so it means that if you put too much, it will still have to much of it no matter what. Or perhaps I'm missing something.
What does "pinging" mean for a keyboard? Sorry for the stupid question but that's the first time I'm seeing this word used about keyboards.
